r13 Posted November 5 Share Posted November 5 @admin На 4.1A16 появился перезапрос ip адресв серверов dns перезапуск dot/doh клиентов при продлении dhcp аренды у провайдера, думаю это лишнее действие. Quote Link to comment Share on other sites More sharing options...
0 vasek00 Posted November 6 Share Posted November 6 11 час назад, r13 сказал: @admin На 4.1A16 появился перезапрос ip адресв серверов dns перезапуск dot/doh клиентов при продлении dhcp аренды у провайдера, думаю это лишнее действие. Это так же на Скрытый текст <release>4.00.C.5.0-2</release> <sandbox>stable</sandbox> <title>4.0.5</title> <arch>mips</arch> [I] Oct 26 00:03:52 ndhcpc: GigabitEthernet1: received ACK for хх.хх.хх.хх from хх.хх.хх.1 lease 600 sec. [I] Oct 26 00:03:52 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": adding a host route to name server 77.88.8.8 (via хх.хх.хх.1). [I] Oct 26 00:03:52 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": host route for name server 77.88.8.8 added. И ранее Скрытый текст <release>4.00.C.0.0-1</release> <sandbox>draft</sandbox> <title>4.0.0</title> <arch>mips</arch> [I] Nov 5 14:40:48 ndhcpc: GigabitEthernet1: received ACK for хх.хх.хх.226 from хх.хх.хх.73 lease 10800 sec. [I] Nov 5 14:40:48 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": adding a host route to name server 8.8.8.8 (via хх.хх.хх.хх). [I] Nov 5 14:40:48 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": host route for name server 8.8.8.8 added. Quote Link to comment Share on other sites More sharing options...
0 r13 Posted November 6 Author Share Posted November 6 9 минут назад, vasek00 сказал: Это так же на Скрыть содержимое <release>4.00.C.5.0-2</release> <sandbox>stable</sandbox> <title>4.0.5</title> <arch>mips</arch> [I] Oct 26 00:03:52 ndhcpc: GigabitEthernet1: received ACK for хх.хх.хх.хх from хх.хх.хх.1 lease 600 sec. [I] Oct 26 00:03:52 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": adding a host route to name server 77.88.8.8 (via хх.хх.хх.1). [I] Oct 26 00:03:52 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": host route for name server 77.88.8.8 added. И ранее Скрыть содержимое <release>4.00.C.0.0-1</release> <sandbox>draft</sandbox> <title>4.0.0</title> <arch>mips</arch> [I] Nov 5 14:40:48 ndhcpc: GigabitEthernet1: received ACK for хх.хх.хх.226 from хх.хх.хх.73 lease 10800 sec. [I] Nov 5 14:40:48 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": adding a host route to name server 8.8.8.8 (via хх.хх.хх.хх). [I] Nov 5 14:40:48 ndm: Dns::InterfaceSpecific: "GigabitEthernet1": host route for name server 8.8.8.8 added. не, это другое - bootstrap dot/doh при каждом продлении: Скрытый текст [I] Nov 5 22:06:39 ndhcpc: GigabitEthernet0/Vlan50: received ACK for 10.73.162.195 from 10.72.0.1 lease 3600 sec. [I] Nov 5 22:06:49 ndm: Dns::Secure::Tools: unable to obtain addresses for "dns.google". [I] Nov 5 22:06:49 ndm: Dns::Secure::Tools: unable to obtain addresses for "1dot1dot1dot1.cloudflare-dns.com". [I] Nov 5 22:06:49 ndm: Dns::Secure::Tools: unable to obtain addresses for "dns.quad9.net". [I] Nov 5 22:06:49 ndm: Dns::Manager: rescheduling DNS-over-TLS bootstrap. [I] Nov 5 22:06:49 ndm: Dns::Manager: updating DNS-over-HTTPS servers addresses. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "System": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "Policy1": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "Policy0": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "Policy3": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "Policy2": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "Policy4": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "Policy5": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:49 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:49 ndm: Dns::Secure::DohConfigurator: "Policy6": using "common.dot.dns.yandex.net:443:2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Manager: updating DNS-over-TLS servers addresses. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "System": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "System": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "System": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "System": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy1": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy1": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy1": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy1": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy0": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy0": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy0": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy0": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy3": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy3": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy3": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy3": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy2": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy2": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy2": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy2": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy4": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy4": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy4": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy4": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy5": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy5": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy5": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy5": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy6": using "dns.google:853:8.8.8.8,8.8.4.4,2001:4860:4860::8844,2001:4860:4860::8888" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy6": using "1dot1dot1dot1.cloudflare-dns.com:853:1.1.1.1,1.0.0.1,2606:4700:4700::1111,2606:4700:4700::1001" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy6": using "dns.quad9.net:853:9.9.9.9,149.112.112.112,2620:fe::fe,2620:fe::9" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Secure::DotConfigurator: "Policy6": using "common.dot.dns.yandex.net:853:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 ndm: Dns::Manager: updating DNS-over-HTTPS servers addresses. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "System": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "Policy1": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "Policy0": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "Policy3": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "Policy2": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "Policy4": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "Policy5": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. [I] Nov 5 22:06:59 https-dns-proxy: Shutting down gracefully. To force exit, send signal again. [I] Nov 5 22:06:59 ndm: Dns::Secure::DohConfigurator: "Policy6": using "common.dot.dns.yandex.net:443:77.88.8.8,77.88.8.1,2a02:6b8:0:1::feed:ff,2a02:6b8::feed:ff" as upstream. Quote Link to comment Share on other sites More sharing options...
r13
@admin
2 answers to this question
