Quectel EM12-G разрывает соединение на версии 3.9.8 и 3.8.5 и 3.8.4. А на 3.7.1 работает стабильно.
FM
Приветствую вас!
Являюсь обладателем Keenetic Ultra II пару лет назад перешел на прошивки канала обновлений delta. Интернет подключался только через мобильную сеть с модемом Quectel EM12-G Примерно год-полтора назад с этим модемом невозможно стало работать он постоянно разрывал соединения с разной периодичностью аптайма от 5 секунд до минуты.  В логах было у него это:
[E] Dec  9 21:42:39 ndm: UsbQmi::Device: "UsbQmi0": operation timeout.
[C] Dec  9 21:42:39 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd0eed].
[I] Dec  9 21:42:39 ndm: UsbQmi::Interface: "UsbQmi0": connection lost.
[I] Dec  9 21:42:41 kernel: usb 1-2: USB disconnect, device number 8
[I] Dec  9 21:42:41 kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[I] Dec  9 21:42:41 kernel: option 1-2:1.0: device disconnected
[I] Dec  9 21:42:41 kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[I] Dec  9 21:42:41 kernel: option 1-2:1.1: device disconnected
[I] Dec  9 21:42:41 kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[I] Dec  9 21:42:41 kernel: option 1-2:1.2: device disconnected
[I] Dec  9 21:42:41 kernel: option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[I] Dec  9 21:42:41 kernel: option 1-2:1.3: device disconnected
[I] Dec  9 21:42:41 kernel: qmi_wwan 1-2:1.4 wwan0: unregister 'qmi_wwan' usb-xhci-mtk-2, WWAN/QMI device
[E] Dec  9 21:42:42 ndm: UsbQmi::Device: unable to read data: no such device.
[C] Dec  9 21:42:42 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd0262], unable to read response header: operation failed.
[C] Dec  9 21:42:42 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd130e].
[C] Dec  9 21:42:42 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd0232], unable to write request: operation failed.
[C] Dec  9 21:42:42 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd0e77].
[I] Dec  9 21:42:42 ndm: Network::Interface::Usb: "UsbQmi0": interface "UsbQmi0" is unplugged.
[I] Dec  9 21:42:42 ndm: Network::Interface::Ip: "UsbQmi0": IP address cleared.
[I] Dec  9 21:42:42 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[I] Dec  9 21:42:45 ndm: Http::Nginx: loaded SSL certificate for "xxxxxxxxxxxx.keenetic.io".
[I] Dec  9 21:42:45 ndm: Http::Nginx: loaded SSL certificate for "xxxxxx.keenetic.pro".
[I] Dec  9 21:42:46 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Dec  9 21:42:46 ndm: Core::Session: client disconnected.
[I] Dec  9 21:42:46 ndm: Http::Manager: updated configuration.
[I] Dec  9 21:42:49 kernel: usb 1-2: new high-speed USB device number 9 using xhci-mtk
[I] Dec  9 21:42:49 kernel: usb 1-2: New USB device found, idVendor=2c7c, idProduct=0512, bcdDevice= 3.18
[I] Dec  9 21:42:49 kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[I] Dec  9 21:42:49 kernel: usb 1-2: Product: EM12-G
[I] Dec  9 21:42:49 kernel: usb 1-2: Manufacturer: Quectel
[I] Dec  9 21:42:49 kernel: usb 1-2: SerialNumber: 0123456789ABCDEF
[I] Dec  9 21:42:49 kernel: option 1-2:1.0: GSM modem (1-port) converter detected
[I] Dec  9 21:42:49 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB0
[I] Dec  9 21:42:49 kernel: option 1-2:1.1: GSM modem (1-port) converter detected
[I] Dec  9 21:42:49 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB1
[I] Dec  9 21:42:49 kernel: option 1-2:1.2: GSM modem (1-port) converter detected
[I] Dec  9 21:42:49 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB2
[I] Dec  9 21:42:49 kernel: option 1-2:1.3: GSM modem (1-port) converter detected
[I] Dec  9 21:42:49 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB3
[I] Dec  9 21:42:49 kernel: qmi_wwan 1-2:1.4: cdc-wdm0: USB WDM device
[I] Dec  9 21:42:49 kernel: qmi_wwan 1-2:1.4 wwan0: register 'qmi_wwan' at usb-xhci-mtk-2, WWAN/QMI device, 8a:10:xx:xx:xx:xx
[I] Dec  9 21:42:49 ndm: Network::Interface::Usb: "UsbQmi0": interface "UsbQmi0" is plugged (port 1).
[I] Dec  9 21:43:23 ndm: Mobile::Mvno: "UsbQmi0": matched 25002, APN: "internet".
[I] Dec  9 21:43:23 ndm: UsbQmi::Interface: "UsbQmi0": device initialized.
[I] Dec  9 21:43:28 ndm: UsbQmi::Interface: "UsbQmi0": network ready.
[I] Dec  9 21:43:28 ndm: UsbQmi::Interface: "UsbQmi0": connection initialized.
[I] Dec  9 21:43:29 ndm: UsbQmi::Interface: "UsbQmi0": connection established.
Я тогда вместо него подключил обычный Huawei 8372 и он стабильно работал все время.
На днях решил разобраться с Quectel EM12-G стал откатывать на доступные мне версии прошивок Keenetic OS и выяснил, что на версии прошивки 3.7.1 модем работает стабильно без разрывов. Вероятно я ранее не связал обновление прошивки роутера с начавшимися проблемами в виде разрыва интернета.
Готов помочь в поиске проблем на более свежих версиях прошивок Keenetic OS. На тематических форумах есть много пользователей с аналогичными проблемами
6 answers to this question
1 час назад, FM сказал:
EM12-G
Какая версия прошивки у вашего EM12-G? Очень спорный модуль получился у Quectel, много жалоб на нестабильную работу. Я в итоге перешёл на EM160R-GL.
Edited by drugold
15 минут назад, drugold сказал:
на прошивке 3.9.8 проверял разные версии прошивки модема и 18 и 19 и 21 нескольких подверсий. потом вернулся на изначальную с покупки EM12GPAR01A20M4G_01.001.01.001 сделал сброс всех настроек модема и стал менять версии на Keenetic-e и он стабильно заработал лишь на KeeneticOS 3.7.1.
Забыл сказать, что модем настроен в режиме только 4G, только band 7. Аггрегация b7+b7.  Ping Check отключен
Просмотрел на различия между 3.7.1 и 3.9, в том числе произведена сверка согласно предоставленному логу. Пока не удалось понять, какие именно запросы приводят к тому, что модем перестаёт отвечать на совершенно стандартный запрос информации об активной несущей. По мере получения диагностики в виде логов перед и во время потери связи буду проводить проверки.
Приветствую! У меня Keenetic Giga  KN-1011 и модем EM-12G   прошивка EM12GPAR01A21M4G   пользуюсь  больше года. Сначала все работало стабильно.
Потом как-то начались  периодические потери связи модема, нужно было зайти в веб интерфейс и перезагрузить модем. На прошивке   4.05 при этом стал зависать веб интерфейс  Кинетика (вводишь пароль, войти и нет ответа), и через telnet  его удавалось перезагрузить.   Сейчас версия ОС 4.1.3  веб интерфейс не зависает, но потери связи модема участились до 10 раз в сутки. Соединение кабеля и питание модема проверил. Уровень сигнала сети хороший.  При проверке speedtest модем выдает максимальную для моего тарифа скорость. Режим только 4G. Агрегация В7+В7+В3 пробовал включить только В7+В7 результат аналогичный.
Есть ли смысл ставить прошивку 3.7.1 ?  Где её взять?
Лог очень похожий:
[E] Apr 12 11:27:24 ndm: UsbQmi::Device: "UsbQmi0": operation timeout.
[C] Apr 12 11:27:24 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd0ef6].
[I] Apr 12 11:27:24 ndm: UsbQmi::Connection: "UsbQmi0": connection lost.
[I] Apr 12 11:27:24 ndm: Network::Interface::Base: "UsbQmi0": "qmi" changed "link" layer state "running" to "connecting".
[I] Apr 12 11:27:26 kernel: usb 1-2: USB disconnect, device number 64
[I] Apr 12 11:27:26 kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[I] Apr 12 11:27:26 kernel: option 1-2:1.0: device disconnected
[I] Apr 12 11:27:26 kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[I] Apr 12 11:27:26 kernel: option 1-2:1.1: device disconnected
[I] Apr 12 11:27:26 kernel: option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[I] Apr 12 11:27:26 kernel: option 1-2:1.2: device disconnected
[I] Apr 12 11:27:26 kernel: option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[I] Apr 12 11:27:26 kernel: option 1-2:1.3: device disconnected
[I] Apr 12 11:27:26 kernel: qmi_wwan 1-2:1.4 wwan0: unregister 'qmi_wwan' usb-xhci-mtk-2, WWAN/QMI device
[E] Apr 12 11:27:27 ndm: UsbQmi::Device: "UsbQmi0": operation timeout.
[C] Apr 12 11:27:27 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd13d2].
[E] Apr 12 11:27:27 kernel: qmi_wwan 1-2:1.4: Tx URB error: -19
[E] Apr 12 11:27:27 ndm: UsbQmi::Device: unable to write data: no such device.
[C] Apr 12 11:27:27 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd024b], unable to write request: operation failed.
[C] Apr 12 11:27:27 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd0ef6].
[I] Apr 12 11:27:27 ndm: Network::Interface::Usb: "UsbQmi0": interface "UsbQmi0" is unplugged.
[E] Apr 12 11:27:30 ndm: Io::File: unable to open "/proc/resetnds": no such file or directory.
[C] Apr 12 11:27:30 ndm: Network::Interface::Stats: "UsbQmi0": system failed [0xcffd004b], unable to reset statistics for qmi_br0: no such file or directory.
[C] Apr 12 11:27:30 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd024b], unable to write request: operation failed.
[C] Apr 12 11:27:30 ndm: UsbQmi::Device: "UsbQmi0": system failed [0xcffd1253].
[E] Apr 12 11:27:30 ndm: Mobile::Sms::Manager: "UsbQmi0": unable to get messages.
[I] Apr 12 11:27:30 ndm: Network::Interface::Ip: "UsbQmi0": IP address cleared.
[I] Apr 12 11:27:30 ndm: Network::Interface::Ip: "UsbQmi0": removing default route via UsbQmi0.
[I] Apr 12 11:27:31 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[I] Apr 12 11:27:31 ndm: Http::Nginx: loaded SSL certificate for "ххххххххххххххх.keenetic.io".
[I] Apr 12 11:27:31 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Apr 12 11:27:31 ndm: Core::Session: client disconnected.
[I] Apr 12 11:27:32 ndm: Http::Manager: updated configuration.
[I] Apr 12 11:27:32 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Apr 12 11:27:32 ndm: Core::Session: client disconnected.
[E] Apr 12 11:27:33 ndm: Core::Ndss: [15516] no registered connection.
[I] Apr 12 11:27:34 kernel: usb 1-2: new high-speed USB device number 65 using xhci-mtk
[I] Apr 12 11:27:34 kernel: usb 1-2: New USB device found, idVendor=2c7c, idProduct=0512, bcdDevice= 3.18
[I] Apr 12 11:27:34 kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[I] Apr 12 11:27:34 kernel: usb 1-2: Product: EM12-G
[I] Apr 12 11:27:34 kernel: usb 1-2: Manufacturer: Quectel
[I] Apr 12 11:27:34 kernel: usb 1-2: SerialNumber: 0123456789ABCDEF
[I] Apr 12 11:27:34 kernel: option 1-2:1.0: GSM modem (1-port) converter detected
[I] Apr 12 11:27:34 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB0
[I] Apr 12 11:27:34 kernel: option 1-2:1.1: GSM modem (1-port) converter detected
[I] Apr 12 11:27:34 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB1
[I] Apr 12 11:27:34 kernel: option 1-2:1.2: GSM modem (1-port) converter detected
[I] Apr 12 11:27:34 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB2
[I] Apr 12 11:27:34 kernel: option 1-2:1.3: GSM modem (1-port) converter detected
[I] Apr 12 11:27:34 kernel: usb 1-2: GSM modem (1-port) converter now attached to ttyUSB3
[I] Apr 12 11:27:34 kernel: qmi_wwan 1-2:1.4: cdc-wdm0: USB WDM device
[I] Apr 12 11:27:34 kernel: qmi_wwan 1-2:1.4 wwan0: register 'qmi_wwan' at usb-xhci-mtk-2, WWAN/QMI device, хх:хх:хх:хх:хх:хх
[I] Apr 12 11:27:34 ndm: Network::Interface::Usb: "UsbQmi0": interface "UsbQmi0" is plugged (port 2).
[I] Apr 12 11:27:48 ndm: Mobile::Mvno: "UsbQmi0": matched 25002, APN: "internet".
[I] Apr 12 11:27:48 ndm: UsbQmi::Connection: "UsbQmi0": device initialized.
[I] Apr 12 11:27:54 ndm: UsbQmi::Connection: "UsbQmi0": network ready.
[I] Apr 12 11:27:54 ndm: UsbQmi::Connection: "UsbQmi0": connection initialized.
[I] Apr 12 11:27:55 ndm: UsbQmi::Connection: "UsbQmi0": connection established.
[I] Apr 12 11:27:55 ndm: Network::Interface::Ip: "UsbQmi0": IP address is 100.84.ххх.ххх/30.
[I] Apr 12 11:27:55 ndm: Network::Interface::Ip: "UsbQmi0": interface "UsbQmi0" is global, priority 33117.
[I] Apr 12 11:27:55 ndm: Network::Interface::Ip: "UsbQmi0": adding default route via UsbQmi0 (100.84.ххх.ххх).
[I] Apr 12 11:27:55 ndm: Dns::InterfaceSpecific: "UsbQmi0": adding name server 10.153.3.ххх.
[I] Apr 12 11:27:55 ndm: Dns::InterfaceSpecific: "UsbQmi0": name server 10.153.3.ххх added, domain (default).
[I] Apr 12 11:27:55 ndm: Network::Interface::Base: "UsbQmi0": "qmi" changed "link" layer state "connecting" to "running".
[I] Apr 12 11:27:55 ndm: Network::Interface::Base: "UsbQmi0": "mobile" changed "ctrl" layer state "connecting" to "running".
[I] Apr 12 11:27:55 ndm: Dns::Manager: name server 10.153.3.ххх added, domain (default).
[I] Apr 12 11:27:55 ndm: Network::InterfaceFlusher: flushed IPv4 UsbQmi0 conntrack and route cache.
[I] Apr 12 11:27:56 ndm: Http::Nginx: loaded SSL certificate for "ххххххххххххххх.keenetic.io".
[I] Apr 12 11:27:56 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Apr 12 11:27:56 ndm: Core::Session: client disconnected.
[I] Apr 12 11:27:56 ndm: Http::Manager: updated configuration.
[I] Apr 12 11:28:00 ndm: Network::InternetChecker: Internet access detected.
Posted (edited)
Пишу сюда так как лень новую тему делать. Имею в наличие Keenetic Hopper DSL. Та же самая проблема причём у меня в наличии Quectel Em12 SGAD и MSFT3  версии, Quectel Em160-GL, T77W968 он же  DW5821e, Fibocom L860-GL и все кроме последнего вылетают на приём(хотя вроде и он один раз вылетел точно уже не помню). Фото прилагаю как отображается в мониторе кинетика. Сначало думал что коряво работает Qmi режим на Quectel. Поставил EM12- MSFT3 версию которая была подключена в композиции AT+QCFG="usbnet",1  ECM  работающия в интерфейсе CdcEthernet0. То же самое. причём эта хрень возникает при резкой нагрузке на приём модема. Например при нескольких закачках крупных файлах или включение торрентов а может возникнуть если открыть с 10 вкладок браузера. Уже мучаюсь не один месяц. У меня антенна работает в MIMO 2x2 кабель 12 м 8d-fb CAA. Грешил что не хватает питания роутера в USB 3.0 поменял блок с 12V 1,5 A на 12v 2,5 A не помогло. Прошивал на всех выше перечисленных модемах прошивки кроме Fibocom 860 его не трогал. Не помогло. Отключал USB 3.0 порт в USB 2.0. Не помогло. Включал и выключал в настройках аппаратное ускорение. Не помогло. Менял адаптеры с доп питанием USB. Не помогло. От отчаяния пришёл сюда и зарегался может тут кто напишет что можно сделать и побороть эту напасть. Версия Keenetic 4.1.3
Edited by dikor1989
Добавил фото
В 13.05.2024 в 21:51, dikor1989 сказал:
Здравствуйте.
Использую Keenetic Ultra (1811) c T77W968. У меня один в один падает скорость в ноль при нагрузке, например, при видеоконференции или сразу большом количестве торрентов.
Поэтому хотел купить себе EM 160-GL для борьбы с отвалами, но продавец с Aliexpress предупредил, что Quectel сейчас все заблокированы с 23го года. Вы как то смогли разблокировать EM 160-GL?
Но при этом, как я понмимаю, 160-й отваливается точно также как и 968-й ?
Edited by Nomads_Land
