Linear - Call Forwarding Issue
Hello,
I created a rule to call my cell phone if there is no answer for 5-10 seconds. The log also shows that he forwarded the call and called.
But I am not receiving calls to the phone I forwarded.
I also contacted my SIP provider. They also checked the required settings.  He was said that there is no obstacle for the forwarding function to not work.
But I didn't get any results.
Can you help me?
@sips
Hello,
In order to investigate the call forwarding issue, could you, please collect diagnostics on your Keenetic and share it?
Collect the diagnostics by following the steps below:
  1. go to GUI>Management>Diagnostics>Debug and click “Restart system in debug mode”;
  2. make an incoming call that should be forwarded to your cell phone;
  3. go to GUI>Management>Diagnostics>Debug and click “Stop debugging”;
  4. download the self-test_*.txt file to your PC and attach it here with your next message.
On 12/21/2023 at 5:06 PM, sips said:
Hello,
Hello,
I am sharing the self-test file in the next message for review.
Thank you.
After studying the self-test provided, I see that in 5 seconds after receiving INVITE sip:xxxxxxxxx507@xxx.xxx.xxx.232:5060, Keenetic responds with 302 Moved Temporarily message containing SIP URI sip:xxxxxxxxx969@xxx.xxx.xxx.10 in the Contact field.
Receiving the 302 message, the calling party should send INVITE to sip:xxxxxxxxx969@xxx.xxx.xxx.10, but, as I understand, it didn't happen. Most probably, the reason is AVENCOM doesn’t allow call forwarding with 302 messages in such scenarios. You can check with AVENCOM technical support if it is so.
