Модем смартфона не хочет работать с кинетиком.
Petrak
KN 2010, к нему подключаю POCO m5s в режиме модема, он его видит но статус не готов.
[I] Jun 28 18:32:49 kernel: usb 1-2: new high-speed USB device number 19 using xhci-mtk
[I] Jun 28 18:32:49 kernel: usb 1-2: New USB device found, idVendor=0e8d, idProduct=2004, bcdDevice=
[I] Jun 28 18:32:49 kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[I] Jun 28 18:32:49 kernel: usb 1-2: Product: 2207117BPG
[I] Jun 28 18:32:49 kernel: usb 1-2: Manufacturer: Xiaomi
[I] Jun 28 18:32:49 kernel: usb 1-2: SerialNumber:
[I] Jun 28 18:32:49 kernel: rndis_host 1-2:1.0 usb0: register 'rndis_host' at usb-xhci-mtk-2, RNDIS device, 8e:x5:аf:3a:52:10
[I] Jun 28 18:32:49 ndm: Network::Interface::Usb: "CdcEthernet0": interface "CdcEthernet0" is plugged (port 1).
[I] Jun 28 18:32:53 ndm: Network::Interface::Base: "CdcEthernet0": interface is up.
[I] Jun 28 18:32:53 ndm: Core::System::StartupConfig: saving (http/rci).
[I] Jun 28 18:32:54 ndm: Network::Interface::Base: "CdcEthernet0": "ethernet" changed "link" layer state "pending" to "running".
[I] Jun 28 18:32:54 ndm: Network::Interface::UsbEthernet: "CdcEthernet0": link up.
[I] Jun 28 18:32:56 ndhcpc: CdcEthernet0: NDM DHCP Client, v3.2.56.
[I] Jun 28 18:32:56 ndhcpc: CdcEthernet0: created PID file "/var/run/ndhcpc-cdc_br0.pid".
[I] Jun 28 18:32:57 ndhcpc: CdcEthernet0: received OFFER for 192.168.246.158 from 192.168.246.159.
[I] Jun 28 18:32:57 ndhcpc: CdcEthernet0: received ACK for 192.168.246.158 from 192.168.246.159 lease 3599 sec.
[I] Jun 28 18:32:57 ndm: Dhcp::Client: configuring interface CdcEthernet0.
[I] Jun 28 18:32:57 ndm: Network::Interface::Ip: "CdcEthernet0": IP address is 192.168.246.158/24.
[I] Jun 28 18:32:57 ndm: Dhcp::Client: obtained IP address 192.168.246.158/24.
[I] Jun 28 18:32:57 ndm: Dhcp::Client: interface "CdcEthernet0" is global, priority 64510.
[I] Jun 28 18:32:57 ndm: Dhcp::Client: adding a default route via 192.168.246.159.
[W] Jun 28 18:32:57 ndm: Dns::InterfaceSpecific: name server 192.168.246.159 is ignored.
[I] Jun 28 18:32:57 ndm: Network::Interface::Base: "CdcEthernet0": "dhcp-client" changed "ipv4" layer state "pending" to "running".
[I] Jun 28 18:32:58 ndm: Core::System::StartupConfig: configuration saved.
[I] Jun 28 18:32:58 ndm: Http::Nginx: loaded SSL certificate for "xxx.keenetic.pro".
[I] Jun 28 18:32:58 ndm: Http::Nginx: loaded SSL certificate for "xxxx.keenetic.io".
[I] Jun 28 18:32:58 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Jun 28 18:32:58 ndm: Core::Session: client disconnected.
[I] Jun 28 18:32:58 ndm: Http::Manager: updated configuration.
[I] Jun 28 18:32:59 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Jun 28 18:32:59 ndm: Core::Session: client disconnected.
8 answers to this question
5 часов назад, vst сказал:
позже поправим
Спасибо, заработало, а вы не знаете почему скорость во много раз ниже чем по Wi FI?
В 29.06.2024 в 08:11, Petrak сказал:
Какой у вас ОПСОС ( оператор сотовой связи) ? какой значек мобильной сети на телефоне? 4G+ , 4G, 3G, 2G ? Влияет еще загруженность БС( базовой станции) ОПСОСа .
Местность. Удаленность от БС ОПСОСа.
Вдобавок ОПСОС может замедлять скорость если видит раздачу . А видит он по TTL и по анализу трафика.
P.S. Скорей всего, кинетик ,в данном случае,  вообще не причем.
Edited by krass
  • Y'r wrong 1
5 minutes ago, krass said:
@vst поясните,пожалуйста, в чем я ошибаюсь?
Проблема несовместимости поддерживаемых модемов и смартфонов на чипах mediatek, которые имеют одни и те же usb идентификаторы. Обходится с помощью команды, которая указана выше.
2 часа назад, krass сказал:
Я имею ввиду, что когда подключаюсь с кинетика к точке доступа телефона по wi fi то скорость где-то 30-40мбит, а в режиме когда телефон подключён к кинетику кабелем в качестве модема то скорость 3-5мбит.
2 минуты назад, Petrak сказал:
Да я уже понял что был неправ. VST выше всё прояснил. Сам с таким не сталкивался. Предположил, исходя из  проблем с которыми сталкивались знакомые...
