lan ports on extender
Posted
Hello
is it possible to put a lan port on a extender in a vlan. (i want to put my solaredge converter in the guest segment)
cant find a way do it in the interface of the main router or the extender.
kind regards
4 answers to this question
Posted
since 4.2.1
  • You can now assign Network ports on Extender devices to any configured network segment using the Command Line Interface (CLI). Alternatively, you may wish to disable the Network ports for security reasons. [NDM-3162]
    • mws member {member} port {port} [no] access {interface} — assign {port} on a {member} node to access an {interface} segment;
    • mws member {member} port {port} [no] disable — disable {port} on a {member} node.
Posted
On 1/17/2025 at 11:04 AM, Leshiyart said:
since 4.2.1
thank you for this info , to bad it cant be done in the web interface yet.
Posted
just saw that in 4.3 beta 1 this in implemented in the gui,what is the expected date that 4.3 will be released to the main release?
