1 Peak DSL (KN-2510) router/modem mode. Internet connection over vdsl pppoe. Keenetic Os Version: 4.3.0 preview.
7 Speedster (KN-3010) devices as mesh mode. Keenetic Os Version: 4.3.0 preview.
i seen under Keenetic OS; Web Interface / Diagnostics / Active Connections / Router PPPoE connected list and mesh devices connected list too many IP addresses connected. This IP addresses; 65.21.196.130, 78.46.134.143, 95.217.199.2, 135.181.129.158, 157.90.158.183, 168.119.198.59 and protocol/ports; TCP/80, TCP/443, UDP/40xx, UDP/56xx, UDP/9 .
When I query the blocks of all these IP addresses subnet /24 on the internet, the result is ASN AS24940 Hetzner Online GmbH. The query was made via the ipinfo.io website. Since I thought these IP addresses were related to Keenetic cloud services and Keenetic mobile application, I removed the Service for mobile application and Cloud services agent modules from the component options from all devices. Also Automatic updates and Product Improvement Programmedisabled in System Settings.
After rebooting all devices, connections continued to be established over the same IP addresses. Then I tried blocking the same IP addresses and protocols/ports for Internet (PPPoE) and Local Segment from Keenetic Firewall but rules did not work. Same IP addresses continued to connect. I believe Keenetic devices collect sensitive data and transmit it to their servers. Since these Keenetic devices are located in a corporate company, we do not want any devices information and/or any of its connections to be transmitted to any Keenetic Cloud System, Keenetic Hosts/Servers/RMM and Keenetic Mobile App etc.
I urgently request detailed technical support regarding this issue. We are concerned about system and network security. I am also leaving a screenshot of these connections. In addition, the same IP addresses connection also occurs on 7 Speedster (KN-3010) devices connected to the Peak DSL (KN-2510) router as a mesh. The same problem exists in the Keenetic Os 4.2.6.3 stable version.
alasedo
Hello,
Devices:
When I query the blocks of all these IP addresses subnet /24 on the internet, the result is ASN AS24940 Hetzner Online GmbH. The query was made via the ipinfo.io website. Since I thought these IP addresses were related to Keenetic cloud services and Keenetic mobile application, I removed the Service for mobile application and Cloud services agent modules from the component options from all devices. Also Automatic updates and Product Improvement Programme disabled in System Settings.
Thank you very much. @admin @ndm @Le ecureuil @hellonow @slomblobov
Best regards.
Edited by alasedoadded more details
2 answers to this question
