Posted (edited)
Hello Keenetic development team.
I would like to receive information whether a fix for the problem of connecting the backup Internet via WISP will be considered. I have a case of a problem with 40+ routers, if the Internet disappears and the backup access point works, then the reconnection goes normally. If the Internet disappears, and the backup access point (phone or 4G modem) is turned on later, the router does not connect (even when I set the reconnection timeout to 30-60 seconds instead of 600). Only rebooting the router helps. It seems that the router will check several times for a backup Wi-Fi network (on demand) and then stop looking for it. The problem is in firmware 4.3.7, 4.3.8 and 5.0.12 and is always reproduced in everyday work. Unfortunately, the routers are installed in different cities, I can't copy the log, as the routers reboot and the log is erased.
Edited by Eug Family
1 answer to this question
