Установка не удалась. В журнале вот такие записи:
Spoiler
Jun 17 00:42:34	ndm       kernel: EXT4-fs (sda1): re-mounted. Opts: (null)
Jun 17 00:42:34	ndm       Opkg::Manager: /tmp/mnt/Transcend mounted to /tmp/mnt/Transcend.
Jun 17 00:42:34	ndm       Opkg::Manager: /tmp/mnt/Transcend mounted to /opt/.
Jun 17 00:42:34	npkg      inflating "mipsel-installer-3x.tar.gz".
Jun 17 00:42:36 ndm       Opkg::Manager: /tmp/mnt/Transcend initialized.
Jun 17 00:42:36 ndm       Opkg::Manager: init script reset to default: /opt/etc/initrc.
Jun 17 00:42:36 ndm       Opkg::Manager: invalid initrc "/opt/etc/initrc": no such file or directory, trying /opt/etc/init.d/.
Jun 17 00:42:36 installer Info: Раздел пригоден для установки.
Jun 17 00:42:36 installer [1/5] Начало развёртывания системы Entware-3x...
Jun 17 00:42:36 installer Info: Создание папок...
Jun 17 00:42:36 ndm       Core::ConfigurationSaver: saving configuration...
Jun 17 00:42:36 installer [2/5] Загрузка и установка базовых пакетов...
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: wget: bad address 'entware-3x.zyxmon.org'.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: Collected errors:
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall:  * opkg_download: Failed to download http://entware-3x.zyxmon.org/binaries/mipsel/Packages.gz, wget returned 1.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: Downloading http://entware-3x.zyxmon.org/binaries/mipsel/Packages.gz.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: *** Failed to download the package list from http://entware-3x.zyxmon.org/binaries/mipsel/Packages.gz.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall:  * opkg_install_cmd: Cannot install package opt-ndmsv2.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall:  * opkg_install_cmd: Cannot install package dropbear.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall:  * opkg_install_cmd: Cannot install package ndmq.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: Unknown package 'opt-ndmsv2'.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: Unknown package 'dropbear'.
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: Unknown package 'ndmq'.
Jun 17 00:42:38 installer Critical error: Ошибка загрузки? Нет соединения с интернетом? Сервер не отвечает?
Jun 17 00:42:38 installer Выход из установки...
Jun 17 00:42:38 ndm       Opkg::Manager: /opt/etc/init.d/doinstall: exit code 1.
Jun 17 00:42:39 ndm       Core::ConfigurationSaver: configuration saved.
При этом сайт http://entware-3x.zyxmon.org не пингуется:
$ ping http://entware-3x.zyxmon.org
ping: unknown host http://entware-3x.zyxmon.org
Интернет работает, другие сайты грузятся.
Как с этим бороться?
во вкладке Сегменты смотри, чтоб маска подсети и у Home и у Guest были 255.255.255.0.
Либо чтоб были
Home VLAN 192.168.1.1 255.255.255.0
Guest VLAN 10.1.30.1 255.0.0.0
Если Guest'a другая маска подсети, то почему-то блокируется интернет в локалной сети 127.0.0.1
Вот же ж я вляпался...
Главное, что я ничего не менял в этих подсетях. А теперь ещё одна дополнительная проблемка нарисовалась, из-за которой я не могу зайти в веб-интерфейс кинетика. Я поменял его порт на 81 и теперь не могу туда попасть чтобы проверить настройку подсетей. Я ввёл в адресной строке: http://my.keenetic.net:81 и на запрос логина и пароля ввёл все данные как обычно, но в браузере вывалилась 502 ошибка:  502 Bad Gateway
Пожалуйста, помогите разобраться.
Никакого отношения к entware последний пост не имеет. Чините свои косяки посредством telnet, надеюсь там порт не меняли...
Справедливое замечание, хотя и не очень дружелюбное, но я пока не понял как и где мне нужно было правильно задать вопрос, чтобы не потерять связность изложения.
8 минут назад, Panasoft сказал:
Пуск-выполнить-cmd. telnet 192.168.1.1
Admin-pass. Читаем мануал до просветления и меняем порт 81 на родной 80. Профит...
Спасибо за быстрый дружелюбный ответ. :-)
Если я правильно понял, то последующее обсуждение конфигурирования через telnet, следует проводить в другой ветке форума, поэтому перешёл туда с новым вопросом.
Edited by Panasoft
Либо чтоб были
Наконец-то смог посмотреть что у меня с сегментами.
Их установлено только два, причём последний отключен:
Guest access point   10.1.30.1    255.255.255.0
Так что тут дело в чём-то другом.
Edited by Panasoft
Вколи ей сыворотку правды
сурово произнес админ
и мы узнаем что нажала
и почему оно само
