Функциональность Keenetic DECT
Помогите разобраться. Звонок  с трубки 105-MAX-G на номер 89851584758 прерван, по какой причине, стало часто происходить. Лог:
Jul 26 17:33:14ndhcps
_WEBADMIN_GUEST_AP: DHCPREQUEST received (STATE_INIT) for 10.1.30.37 from e8:39:df:95:76:81.
_WEBADMIN_GUEST_AP: sending ACK of 10.1.30.37 to e8:39:df:95:76:81.
Jul 26 17:33:20wmond
WifiMaster0/AccessPoint0: (MT76x2) STA(a4:b8:05:c9:ec:94) had associated successfully.
Jul 26 17:33:21wmond
WifiMaster0/AccessPoint0: (MT76x2) STA(a4:b8:05:c9:ec:94) set key done in WPA2/WPA2PSK.
Jul 26 17:33:22ndhcps
_WEBADMIN: DHCPDISCOVER received from a4:b8:05:c9:ec:94.
_WEBADMIN: making OFFER of 192.168.1.38 to a4:b8:05:c9:ec:94.
Jul 26 17:33:23ndhcps
_WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.134 from a4:b8:05:c9:ec:94.
_WEBADMIN: client IP and lease IP mismatch.
_WEBADMIN: sending NAK to a4:b8:05:c9:ec:94.
Jul 26 17:33:25ndm
Nvox::CallInfo: Line "105-MAX-G": incoming call from sip:102@actiondj.onpbx.ru.
Jul 26 17:33:38ndm
Nvox::CallInfo: Line "105-MAX-G": incoming call from sip:102@actiondj.onpbx.ru answered on HS "ТРУБКА II".
Jul 26 17:34:08ndm
Nvox::CallInfo: Line "103-KARP": outgoing call from HS "ТРУБКА III" to sip:89858915191@actiondj.onpbx.ru.
Jul 26 17:34:20nvox
Call voice failure for call 0
Jul 26 17:34:22ndm
Nvox::CallInfo: Line "103-KARP": outgoing call from HS "ТРУБКА III" to sip:89858915191@actiondj.onpbx.ru answered.
Jul 26 17:34:24ndm
Nvox::CallInfo: Line "105-MAX-G": incoming call from sip:102@actiondj.onpbx.ru finished.
Jul 26 17:34:35ndm
Nvox::CallInfo: Line "105-MAX-G": outgoing call from HS "ТРУБКА II" to sip:89851584758@actiondj.onpbx.ru.
Jul 26 17:34:41ndm
Nvox::CallInfo: Line "105-MAX-G": outgoing call from HS "ТРУБКА II" to sip:89851584758@actiondj.onpbx.ru incomplete, response "486 Busy Here".
Jul 26 17:35:05ndm
Jul 26 17:35:15ndm
Nvox::CallInfo: Line "105-MAX-G": outgoing call from HS "ТРУБКА II" to sip:89851584758@actiondj.onpbx.ru answered.
Jul 26 17:35:57nvox
Call voice failure for call 1
Jul 26 17:35:59ndm
Nvox::CallInfo: Line "103-KARP": outgoing call to sip:89858915191@actiondj.onpbx.ru finished.
Jul 26 17:36:00ndm
Jul 26 17:36:08ndm
Jul 26 17:36:21nvox
Call voice failure for call 3
Jul 26 17:36:24ndm
Nvox::CallInfo: Line "105-MAX-G": outgoing call to sip:89851584758@actiondj.onpbx.ru finished.
Jul 26 17:36:42ndm
Jul 26 17:36:49ndm
Jul 26 17:36:55nvox
Call voice failure for call 4
Jul 26 17:37:00ndm
Jul 26 17:37:03ndm
Nvox::CallInfo: Line "103-KARP": incoming call from sip:79858915191@actiondj.onpbx.ru.
Jul 26 17:37:03ndm
Nvox::CallInfo: Line "103-KARP": incoming call from sip:79858915191@actiondj.onpbx.ru answered on HS "ТРУБКА III".
Jul 26 17:37:19nvox
Call voice failure for call 7
Jul 26 17:37:21ndm
Jul 26 17:37:49ndm
Nvox::CallInfo: Line "105-MAX-G": incoming call from sip:79851584758@actiondj.onpbx.ru.
Jul 26 17:37:54ndm
Nvox::CallInfo: Line "105-MAX-G": incoming call from sip:79851584758@actiondj.onpbx.ru answered on HS "ТРУБКА II".
Jul 26 17:38:55ndm
Nvox::CallInfo: Line "103-KARP": incoming call from sip:79858915191@actiondj.onpbx.ru finished.
Jul 26 17:40:11ndm
Nvox::CallInfo: Line "105-MAX-G": incoming call from sip:79851584758@actiondj.onpbx.ru finished.
@maximosдавайте отладочный лог такого звонка. Возможно, что-то с кодеками. С другими трубками все ок?
Проблема появилась просто так, или после какого-то обновления?
Edited by des
спросил про обновление
  • 5 weeks later...
Исправили следующую проблему с Астериском:
  1. Входящий интерком с Гигасета на CAT-iq 2 трубку.
  2. Входящий звонок с Астериска, у которого включены несколько кодеков, в числе которых G722.
  3. Принять ожидающий звонок на CAT-iq 2 трубке.
  4. Переключение звонков (call toggle) на CAT-iq 2 трубке.
  5. Переключение звонков на CAT-iq 2 трубке.
  6. Шум.
Call toggle ставит на удержание внешний звонок. Когда звонок снимается с удержания, Астериск присылает не тот кодек, который был ранее выбран для звонка (в нашем случае PCMA вместо G722). Мы эту ситуацию не обрабатывали.
Еще есть следующие наработки:
  • Early Media - в тестировании. Вероятно, на следующей неделе выложим, если не будет много багов.
  • Автоинтерком - если зарегистрировано всего 2 трубки, нажатие кнопки int на одной должно автоматом звонить на другую. Выпустим вместе с Early Media.
  • Экспорт истории звонков в CSV файл. Пока нет вебки.
  • Фильтры для истории звонков. Тоже нет вебки.
Вебщики сейчас на 100% загружены. Через пару недель у них должно начать освобождаться немного времени - тогда будут улучшения истории звонков.
Кстати про G722.. Столкнулся со следующим, на обоих роутерах актуальные драфты 2.10:
- Ultra II, трубка S850HX (номер 3), в Entware стоит астериск, прописаны простейшие линии, типа
[office]
exten => _X,1,Dial(SIP/${EXTEN})
[internal](!)
type=friend
insecure=port
context=office
host=dynamic
allow=all
qualify=yes
canreinvite=yes
nat=no
directmedia=yes
[1](internal)
secret=
[2](internal)
secret=
[3](internal)
secret=
- удаленная Giga II, трубка A420H (номер 1), подключена по IPIP-туннелю к Ultra II.
Адрес SIP-сервера в обоих случаях - туннельный IP ультры.
Если в кодеках стоит только G722, звонок 3->1 проходит. При обратном вызове 1->3 на S850HX нажатие "поднять трубку" просто ничего не дает, трубка продолжает звонить.
Если в разрешенных кодеках стоит 722 и 711, то соединение в обоих случаях вроде бы успешно устанавливается на 711.
Может чего где не усмотрел я. Как будет возможность протестировать - скину все селфтесты и прочие дампы с подробностями, это пока сильно сумбурное впечатление от первых экспериментов с G722.
Edited by KorDen
Выпуск версии с Early Media затягивается - в 2.10 страшно отдавать, а 2.11 пока недостаточно работоспособна. В эту пятницу обновления еще не будет.
  • 2 weeks later...
Опять сломали тест правил набора номера, как минимум начиная с 2.09.
Сегодня должны выложить сборку 2.11. В ней будет поддержка early media (музыка с сервера вместо длинных гудков) и автоматического интеркома (когда зарегистрировано ровно 2 трубки).
В 2.11.A.1.0-0 на S850HX не сбрасывается уведомление о пропущенном вызове, в логе "Unsupported attempt to (un)mark entries for list 1"
Очищаем журнал вызовов, делаем пропущенный вызов, просматриваем его с трубки - индикатор уведомления остается, как и значок пропущенного вызова.
По крайней мере на 2.10.A.7.0-0 работало корректно
  • Thanks 2
В 2.11 был добавлен движок телефонной книги, но для него еще нет вебки. Видимо, зацепило. Спасибо, что нашли!
  • 2 weeks later...
Только сейчас обратил внимание: Есть две S850HX, 02B6D8**** определяется корректно, вторая 02B6AD**** - вебинтерфейс кинетика считает ее C620H.
PS: поигрался с телефонной книгой, вроде работает, но до перезагрузки - как я понимаю, сохранение в файл еще не доделали? Как скоро планируется?
Edited by KorDen
спасибо, обновил
вебщики полностью загружены новым интерфейсом. Как только его приведут в какой-то порядок, смогут заняться визардом для импорта телефонной книги из CSV файла. Без него толку от телефонной книги все равно мало - не вбивать же ее вручную.
По той же причине "зависли" экспорт истории звонков в CSV и фильтры для истории звонков - там все кроме вебки готово (вроде бы).
  • 2 weeks later...
2 hours ago, T@rkus said:
Попытка сохранить журнал звонков весит вэбморду роутера. Сохранение возможно только на USB носитель?
Какой там текст? Сохранить куда? Можно подробнее, а то тут 2 похожих вещи:
1) Выбор пути для храниения истории звонков. Это должна быть флешка или временная директория на роутере. Читать этот файл не удобно - формат не предназначен для импорта в эксель.
2) Экспорт истории звонков в .csv файл. Он должен быть читаемым, затягиваемым в эксель или опен офис, но да, при этом вис роутер, и на вебке не должно было быть доступа к экспорту пока проблему не исправили.
24 минуты назад, des сказал:
Второе
Edited by T@rkus
  • 2 weeks later...
Начиная с 2,09 добавили историю вызовов в мобильном приложении (Андроид и iPhone). Причем, кликнув на звонке, можно на этот номер позвонить с мобильного.
Не соединяется на нестандартный порт сип-сервера, указывал как написано в инструкции: https://help.keenetic.net/hc/ru/articles/214471525
Сервер регистрации SIP: 82.*******:50600
Прокси-сервер SIP: 82.*******:50600
Еще вопрос, можно ли и как использовать DECT в астериске?
Можно поставить Астериск на роутер и подключить к нему K+DECT как к серверу. Работать с DECT донглом напрямую Астериск не умеет.
https://help.keenetic.net/hc/ru/articles/115001054729-Установка-IP-АТС-Asterisk-11-на-интернет-центр-Keenetic
У нас проблема не воспроизвелась. Надо как минимум отладочный лог попытки подключения https://help.keenetic.net/hc/ru/articles/214470945-Выполнение-диагностики-отладки-для-решения-вопросов-настройки-или-устранения-неисправностей
Как максимум - кроме отладочного лога дамп трафика на внешнем интерфейсе Кинетика с фильтром
"ip host x.x.x.x"
где x.x.x.x - IP-адрес SIP-сервера.
Статья о том, как захватить трафик: https://help.keenetic.net/hc/ru/articles/213966089-Использование-встроенного-модуля-захвата-сетевых-пакетов
Захват выполнять следующим образом:
1)    выключить DECT-базу на странице веб-конфигуратора Телефонная станция>DECT-база;
2)    включить захват трафика. Подождать 1 минуту
3)   включить DECT-базу
4)    выполнить исходящий вызов;
5)    выключить захват трафика.
6)    прислать нам полученный дамп трафика.
Edited by des
добавил пункт "включить DECT базу"
12 minutes ago, GanjaKyp said:
Отправил вам в личку лог
Запросы на регистрацию отправляются на сервер, но ответы на них к нам не приходят. Делайте захват трафика на внешнем порту роутера.
Попробую, но при этом если поменять на этом сервере и в кинетике порт на 5060 то соединение проходит. И зойпер на порт 50600 соединяется
Я сделал, что смог - посмотрел лог приложения телефонии. Оно не видит ответа от сервера. Теперь надо смотреть на уровень выше - что приходит на роутер. И это не ко мне вопрос - я там ничего не знаю. В захвате трафика специалисты по сетям увидят, есть физически ответ или нет, и на какой порт он идет. И будут разбираться или советовать что-то. Может, у меня где-то проблема, но надо хотя бы понять, на каком она уровне, то есть, где именно этот ответ теряется.
В настройках линии стоит таймаут регистрации в 1800 сек, keepalive 15, NAT нет.  При этом на сервер летят регистрации приблизительно каждые 2 минуты. self-test/дампы скину при необходимости позже.
Edited by KorDen
У сервера может быть меньше таймаут, если я правильно помню стандарт. Должен выбираться минимальный таймаут килента или сервера.
1 час назад, des сказал:
У сервера таймаут однозначно больше, либо его вообще нет - не помню сходу, сколько там стоит, но по крайней мере другие SIP-железки с таймаутом 3600 нормально обновляют регу только раз в час.
Edited by KorDen
Попросил проверить эксперта в SIP. Но уже на следующей неделе, так как все по домам разбежались.
