Keenetic Omni II отваливается интернет.
Кирилл куз
Используется вместе с модемом мегафона. Подключен напрямую.
Ошибка:[E] Apr  2 11:34:13 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Apr  2 11:34:13 ndm: FileSystem::Repository: failed to create a new filesystem.
Вот лог.
[I] Jan  1 00:00:03 ndm: kernel: Linux version 3.4.113 (developers@ndmsystems.com) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-ndm-18 - NDMS Toolkit 1.0.0) ) #1 Mon Feb 19 21:26:34 MSK 2018
[I] Jan  1 00:00:03 ndm: kernel: MediaTek SoC: MT7620N, RevID: 0206, RAM: DDR1, XTAL: 20MHz
[I] Jan  1 00:00:03 ndm: kernel: CPU/OCP/SYS frequency: 580/193/193 MHz
[I] Jan  1 00:00:03 ndm: kernel: CPU revision is: 00019650 (MIPS 24KEc)
[I] Jan  1 00:00:03 ndm: kernel: Determined physical RAM map:
[I] Jan  1 00:00:03 ndm: kernel:  memory: 04000000 @ 00000000 (usable)
[I] Jan  1 00:00:03 ndm: kernel: Zone PFN ranges:
[I] Jan  1 00:00:03 ndm: kernel:   Normal
[I] Jan  1 00:00:03 ndm: kernel: 0x00000000 -> 0x00004000
[I] Jan  1 00:00:03 ndm: kernel: Movable zone start PFN for each node
[I] Jan  1 00:00:03 ndm: kernel: Early memory PFN ranges
[I] Jan  1 00:00:03 ndm: kernel:     0: 0x00000000 -> 0x00004000
[I] Jan  1 00:00:03 ndm: kernel: On node 0 totalpages: 16384
[I] Jan  1 00:00:03 ndm: kernel: free_area_init_node: node 0, pgdat 80302430, node_mem_map 81000000
[I] Jan  1 00:00:03 ndm: kernel:   Normal zone: 128 pages used for memmap
[I] Jan  1 00:00:03 ndm: kernel:   Normal zone: 0 pages reserved
[I] Jan  1 00:00:03 ndm: kernel:   Normal zone: 16256 pages, LIFO batch:3
[I] Jan  1 00:00:03 ndm: kernel: Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[I] Jan  1 00:00:03 ndm: kernel: Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[I] Jan  1 00:00:03 ndm: kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[I] Jan  1 00:00:03 ndm: kernel: pcpu-alloc: [0] 0
[I] Jan  1 00:00:03 ndm: kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[I] Jan  1 00:00:03 ndm: kernel: Kernel command line: console=ttyS0,57600n8 rdinit=/sbin/init
[I] Jan  1 00:00:03 ndm: kernel: PID hash table entries: 256 (order: -2, 1024 bytes)
[I] Jan  1 00:00:03 ndm: kernel: Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[I] Jan  1 00:00:03 ndm: kernel: Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[I] Jan  1 00:00:03 ndm: kernel: Writing ErrCtl register=0005c2d8
[I] Jan  1 00:00:03 ndm: kernel: Readback ErrCtl register=0005c2d8
[I] Jan  1 00:00:03 ndm: kernel: Memory: 61600k/65536k available (2572k kernel code, 3936k reserved, 510k data, 180k init, 0k highmem)
[I] Jan  1 00:00:03 ndm: kernel: NR_IRQS:40
[I] Jan  1 00:00:03 ndm: kernel: console [ttyS0] enabled
[I] Jan  1 00:00:03 ndm: kernel: Calibrating delay loop... 385.02 BogoMIPS (lpj=770048)
[I] Jan  1 00:00:03 ndm: kernel: pid_max: default: 32768 minimum: 301
[I] Jan  1 00:00:03 ndm: kernel: Mount-cache hash table entries: 512
[I] Jan  1 00:00:03 ndm: kernel: NET: Registered protocol family 16
[I] Jan  1 00:00:03 ndm: kernel: bio: create slab <bio-0> at 0
[I] Jan  1 00:00:03 ndm: kernel: Switching to clocksource MIPS
[I] Jan  1 00:00:03 ndm: kernel: NET: Registered protocol family 2
[I] Jan  1 00:00:03 ndm: kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[I] Jan  1 00:00:03 ndm: kernel: TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[I] Jan  1 00:00:03 ndm: kernel: TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[I] Jan  1 00:00:03 ndm: kernel: TCP: Hash tables configured (established 2048 bind 2048)
[I] Jan  1 00:00:03 ndm: kernel: TCP: reno registered
[I] Jan  1 00:00:03 ndm: kernel: UDP hash table entries: 256 (order: 0, 4096 bytes)
[I] Jan  1 00:00:03 ndm: kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher
[I] Jan  1 00:00:03 ndm: kernel: msgmni has been set to 120
[I] Jan  1 00:00:03 ndm: kernel: io scheduler noop registered (default)
[I] Jan  1 00:00:03 ndm: kernel: Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[I] Jan  1 00:00:03 ndm: kernel: serial8250: ttyS0 at MMIO 0x10000c00 (irq = 20) is a 16550A
[I] Jan  1 00:00:03 ndm: kernel: Registering NDM partitions parser
[I] Jan  1 00:00:03 ndm: kernel: Ralink SPI flash driver, SPI clock: 24MHz
[I] Jan  1 00:00:03 ndm: kernel: SPI flash chip: W25Q64BV (ef 40170000) (8192 Kbytes)
[I] Jan  1 00:00:03 ndm: kernel: 9 ndmpart partitions found on MTD device raspi
[I] Jan  1 00:00:03 ndm: kernel: Creating 9 MTD partitions on "raspi":
[I] Jan  1 00:00:03 ndm: kernel: 0x000000000000-0x000000030000: "U-Boot"
[I] Jan  1 00:00:03 ndm: kernel: 0x000000030000-0x000000040000: "U-Config"
[I] Jan  1 00:00:03 ndm: kernel: 0x000000040000-0x000000050000: "RF-EEPROM"
[I] Jan  1 00:00:03 ndm: kernel: 0x000000050000-0x000000180000: "Kernel"
[I] Jan  1 00:00:03 ndm: kernel: 0x000000180000-0x000000770000: "RootFS"
[I] Jan  1 00:00:03 ndm: kernel: mtd: device 4 (RootFS) set to be root filesystem
[I] Jan  1 00:00:03 ndm: kernel: 0x000000050000-0x000000770000: "Firmware"
[I] Jan  1 00:00:03 ndm: kernel: 0x000000770000-0x000000780000: "Config"
[I] Jan  1 00:00:03 ndm: kernel: 0x000000780000-0x000000800000: "Storage"
[I] Jan  1 00:00:03 ndm: kernel: 0x000000000000-0x000000800000: "Full"
[I] Jan  1 00:00:03 ndm: kernel: tun: Universal TUN/TAP device driver, 1.6
[I] Jan  1 00:00:03 ndm: kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[I] Jan  1 00:00:03 ndm: kernel: PPP generic driver version 2.4.2
[I] Jan  1 00:00:03 ndm: kernel: PPP MPPE Compression module registered
[I] Jan  1 00:00:03 ndm: kernel: NET: Registered protocol family 24
[I] Jan  1 00:00:03 ndm: kernel: PPTP driver version 0.8.5
[I] Jan  1 00:00:03 ndm: kernel: nf_conntrack version 0.5.0 (16384 buckets, 32768 max)
[I] Jan  1 00:00:03 ndm: kernel: xt_time: kernel timezone is -0000
[I] Jan  1 00:00:03 ndm: kernel: Bridge firewalling registered
[I] Jan  1 00:00:03 ndm: kernel: ubridge: Tiny bridge driver, 1.1
[I] Jan  1 00:00:03 ndm: kernel: IPv4 over IPv4 tunneling driver
[I] Jan  1 00:00:03 ndm: kernel: gre: GRE over IPv4 demultiplexor driver
[I] Jan  1 00:00:03 ndm: kernel: Fast NAT loaded
[I] Jan  1 00:00:03 ndm: kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
[I] Jan  1 00:00:03 ndm: kernel: TCP: cubic registered
[I] Jan  1 00:00:03 ndm: kernel: NET: Registered protocol family 10
[I] Jan  1 00:00:03 ndm: kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
[I] Jan  1 00:00:03 ndm: kernel: IPv6 over IPv4 tunneling driver
[I] Jan  1 00:00:03 ndm: kernel: NET: Registered protocol family 17
[I] Jan  1 00:00:03 ndm: kernel: 8021q: 802.1Q VLAN Support v1.8
[I] Jan  1 00:00:03 ndm: kernel: Registering the dns_resolver key type
[I] Jan  1 00:00:03 ndm: kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[I] Jan  1 00:00:03 ndm: kernel: Freeing unused kernel memory: 180k freed
[I] Jan  1 00:00:03 ndm: Core::Main: ***
[I] Jan  1 00:00:03 ndm: Core::Main: *** Network Device Manager v2.08(AAUS.8)C2.
[I] Jan  1 00:00:03 ndm: Core::Main: *** Built Feb 19 2018 21:22:03.
[I] Jan  1 00:00:05 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_nat_proto_gre.ko.
[I] Jan  1 00:00:05 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usb-common.ko.
[I] Jan  1 00:00:05 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/aead.ko.
[I] Jan  1 00:00:06 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/scsi_mod.ko.
[I] Jan  1 00:00:06 ndm: kernel: SCSI subsystem initialized
[I] Jan  1 00:00:06 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_DSCP.ko.
[I] Jan  1 00:00:06 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_statistic.ko.
[I] Jan  1 00:00:06 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_conntrack_sip.ko.
[I] Jan  1 00:00:06 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/zlib_inflate.ko.
[I] Jan  1 00:00:06 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_CLASSIFY.ko.
[I] Jan  1 00:00:06 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ip_gre.ko.
[I] Jan  1 00:00:07 ndm: kernel: ip_gre: GRE over IPv4 tunneling driver
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ipt_ROUTE.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_conntrack_ftp.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_length.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/mbcache.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/phr.ko.
[W] Jan  1 00:00:07 ndm: kernel: phr: module license 'Proprietary' taints kernel.
[I] Jan  1 00:00:07 ndm: kernel: phr: I/O peripheral driver. (C) 2013-2018, NDM Systems Inc., v2.0.13
[I] Jan  1 00:00:07 ndm: kernel: phr: "kn_rf" platform driver loaded
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_conntrack_proto_gre.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_dscp.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/pppol2tp.ko.
[I] Jan  1 00:00:07 ndm: kernel: L2TP kernel driver, v1.5-1
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_hl.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nls_base.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/jbd2.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/zlib_deflate.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/rt_timer_wdg.ko.
[I] Jan  1 00:00:07 ndm: kernel: Load Ralink WDG Timer Module
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ipt_ECN.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_ecn.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_comment.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/mtdoops_proc.ko.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/resetnds.ko.
[I] Jan  1 00:00:07 ndm: kernel: resetnds: Module loaded.
[I] Jan  1 00:00:07 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/cdrom.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/xt_string.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_conntrack_pptp.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usbcore.ko.
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver usbfs
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver hub
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new device driver usb
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_nat_pptp.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usbserial.ko.
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver usbserial
[I] Jan  1 00:00:08 ndm: kernel: usbserial: USB Serial Driver core
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ftdi_sio.ko.
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver ftdi_sio
[I] Jan  1 00:00:08 ndm: kernel: USB Serial support registered for FTDI USB Serial Device
[I] Jan  1 00:00:08 ndm: kernel: ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_nat_ftp.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ehci-hcd.ko.
[I] Jan  1 00:00:08 ndm: kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[I] Jan  1 00:00:08 ndm: kernel: ehci-platform ehci-platform: Generic Platform EHCI Controller
[I] Jan  1 00:00:08 ndm: kernel: ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[I] Jan  1 00:00:08 ndm: kernel: ehci-platform ehci-platform: irq 26, io mem 0x101c0000
[I] Jan  1 00:00:08 ndm: kernel: ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00, overcurrent ignored
[I] Jan  1 00:00:08 ndm: kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[I] Jan  1 00:00:08 ndm: kernel: usb usb1: Product: Generic Platform EHCI Controller
[I] Jan  1 00:00:08 ndm: kernel: usb usb1: Manufacturer: Linux 3.4.113 ehci_hcd
[I] Jan  1 00:00:08 ndm: kernel: usb usb1: SerialNumber: ehci-platform
[I] Jan  1 00:00:08 ndm: kernel: hub 1-0:1.0: USB hub found
[I] Jan  1 00:00:08 ndm: kernel: hub 1-0:1.0: 1 port detected
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver cdc_wdm
[I] Jan  1 00:00:08 ndm: kernel: jffs2: version 2.2. (NAND) В© 2001-2006 Red Hat, Inc.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/cdc-wdm.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/jffs2.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/pl2303.ko.
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver pl2303
[I] Jan  1 00:00:08 ndm: kernel: USB Serial support registered for pl2303
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/tntfs.ko.
[I] Jan  1 00:00:08 ndm: kernel: Tuxera NTFS driver 3016.10.24.1d [Flags: R/W MODULE].
[I] Jan  1 00:00:08 ndm: kernel: Built against headers 3.4.113 mips
[I] Jan  1 00:00:08 ndm: kernel: Running on kernel 3.4.113 #1 Mon Feb 19 21:26:34 MSK 2018 mips
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nls_cp866.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nf_nat_sip.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/tfat.ko.
[I] Jan  1 00:00:08 ndm: kernel: Tuxera FAT 12/16/32 driver version 3015.1.29 [Flags: R/W MODULE].
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ext4.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usbnet.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/sg.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/sierra.ko.
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver sierra
[I] Jan  1 00:00:08 ndm: kernel: USB Serial support registered for Sierra USB modem
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/hw_cdc_net.ko.
[I] Jan  1 00:00:08 ndm: kernel: usbcore: registered new interface driver huawei_ether
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nls_cp437.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/sr_mod.ko.
[I] Jan  1 00:00:08 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ohci-hcd.ko.
[I] Jan  1 00:00:09 ndm: kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[I] Jan  1 00:00:09 ndm: kernel: ohci-platform ohci-platform: Generic Platform OHCI Controller
[I] Jan  1 00:00:09 ndm: kernel: ohci-platform ohci-platform: new USB bus registered, assigned bus number 2
[I] Jan  1 00:00:09 ndm: kernel: ohci-platform ohci-platform: irq 26, io mem 0x101c1000
[I] Jan  1 00:00:09 ndm: kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[I] Jan  1 00:00:09 ndm: kernel: usb usb2: Product: Generic Platform OHCI Controller
[I] Jan  1 00:00:09 ndm: kernel: usb usb2: Manufacturer: Linux 3.4.113 ohci_hcd
[I] Jan  1 00:00:09 ndm: kernel: usb usb2: SerialNumber: ohci-platform
[I] Jan  1 00:00:09 ndm: kernel: hub 2-0:1.0: USB hub found
[I] Jan  1 00:00:09 ndm: kernel: hub 2-0:1.0: 1 port detected
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver dm9601
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/sd_mod.ko.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/dm9601.ko.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usblp.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver usblp
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/cdc-acm.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver cdc_acm
[I] Jan  1 00:00:09 ndm: kernel: cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[I] Jan  1 00:00:09 ndm: kernel: Initializing USB Mass Storage driver...
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usb-storage.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver usb-storage
[I] Jan  1 00:00:09 ndm: kernel: USB Mass Storage support registered.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nls_cp1251.ko.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/thfsplus.ko.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/kalmia.ko.
[I] Jan  1 00:00:09 ndm: kernel: Tuxera HFS+ driver 3016.7.4
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver kalmia
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/nls_utf8.ko.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usbextras.ko.
[I] Jan  1 00:00:09 ndm: kernel: USB extras loaded
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/usb_wwan.ko.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/cdc_ncm.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver cdc_ncm
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/option.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver option
[I] Jan  1 00:00:09 ndm: kernel: USB Serial support registered for GSM modem (1-port)
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/asix.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver asix
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/huawei_cdc_ncm.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver huawei_cdc_ncm
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/cdc_ether.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver cdc_ether
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/rndis_host.ko.
[I] Jan  1 00:00:09 ndm: kernel: usbcore: registered new interface driver rndis_host
[I] Jan  1 00:00:09 ndm: FileSystem::Temp: mounting /var/...
[I] Jan  1 00:00:09 ndm: FileSystem::Storage: mounting "/storage"...
[I] Jan  1 00:00:09 ndm: Core::Authenticator: MD5 generator created.
[I] Jan  1 00:00:09 ndm: Core::Authenticator: NT generator created.
[I] Jan  1 00:00:09 ndm: Core::Authenticator: "readonly" tag registered.
[I] Jan  1 00:00:09 ndm: Core::System::Timezone: building a timezone list...
[I] Jan  1 00:00:09 ndm: Core::System::Timezone: scanning done, 138 timezone available.
[I] Jan  1 00:00:09 ndm: Core::System::Timezone: timezone reset to default.
[I] Jan  1 00:00:09 ndm: Telnet::Server: bruteforce detection is enabled.
[I] Jan  1 00:00:09 ndm: Ntp::Client: configuration reset.
[I] Jan  1 00:00:09 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/rtsoc_eth.ko.
[I] Jan  1 00:00:09 ndm: kernel: rtsoc_eth: Ethernet switch driver for Ralink SoCs
[I] Jan  1 00:00:10 ndm: kernel: rtsoc_eth: (C) 2016-2018, NDM Systems Inc., v1.1.53
[I] Jan  1 00:00:10 ndm: kernel: rtsoc_eth: MT7620 SoC, TX/RX buffers: 512/512, poll budget 32
[I] Jan  1 00:00:10 ndm: kernel: rtsoc_eth: e4:18:6b:58:6f:34 address assigned to eth2
[I] Jan  1 00:00:10 ndm: kernel: rtsoc_eth: MT7620 switch initialized
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0": interface is down.
[I] Jan  1 00:00:10 ndm: Network::Interface::Mac: backed up the default address e4:18:6b:58:6f:34 of "FastEthernet0" before changing.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/0": interface is down.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/0": interface is up.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/0": renamed to "0".
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/1": interface is down.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/1": interface is up.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/1": renamed to "1".
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/2": interface is down.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/2": interface is up.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/2": renamed to "2".
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/3": interface is down.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/3": interface is up.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/3": renamed to "3".
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/4": interface is down.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/4": interface is up.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "FastEthernet0/4": renamed to "4".
[I] Jan  1 00:00:10 ndm: Core::Authenticator: "printers" tag registered.
[I] Jan  1 00:00:10 ndm: Core::Authenticator: "cifs" tag registered.
[I] Jan  1 00:00:10 ndm: Cloud::Agent: "cloud" component registered.
[I] Jan  1 00:00:10 ndm: Cloud::Agent: "control" component registered.
[I] Jan  1 00:00:10 ndm: Http::Manager: bruteforce detection is enabled.
[I] Jan  1 00:00:10 ndm: Core::Authenticator: "http" tag registered.
[I] Jan  1 00:00:10 ndm: Cloud::Agent: "ndns" TTP component registered.
[I] Jan  1 00:00:10 ndm: Cloud::Agent: "ndns" component registered.
[I] Jan  1 00:00:10 ndm: PingCheck::Profile: profile "default" add host "google.com" for testing.
[I] Jan  1 00:00:10 ndm: PingCheck::Profile: profile "default" add host "yahoo.com" for testing.
[I] Jan  1 00:00:10 ndm: PingCheck::Profile: profile "default" add host "facebook.com" for testing.
[I] Jan  1 00:00:10 ndm: PingCheck::Profile: profile "default" update interval is changed to 10 seconds.
[I] Jan  1 00:00:10 ndm: PingCheck::Profile: profile "default" uses connect mode.
[I] Jan  1 00:00:10 ndm: PingCheck::Profile: profile "default" uses port 443 for testing.
[I] Jan  1 00:00:10 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/ntc.ko.
[I] Jan  1 00:00:10 ndm: kernel: ntc: NDM traffic control module v2.1.4
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: description saved.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "UsbDsl0": interface is down.
[I] Jan  1 00:00:10 ndm: Network::Interface::Base: "UsbDsl0": interface is up.
[I] Jan  1 00:00:11 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/mt76x2_ap.ko.
[I] Jan  1 00:00:11 ndm: kernel: MT76x2 AP Driver version: 3.0.5.0
[I] Jan  1 00:00:11 ndm: Network::Interface::Rtx::WifiMaster: PHY mode set.
[I] Jan  1 00:00:11 ndm: Network::Interface::Rtx::WifiMaster: country code set.
[I] Jan  1 00:00:11 ndm: Network::Interface::Rtx::WifiMaster: channel bandwidth settings reset to default.
[I] Jan  1 00:00:11 ndm: Network::Interface::Radio: the radio switch state is changed to off, software state is down [WifiMaster0].
[I] Jan  1 00:00:11 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint2": interface is down.
[I] Jan  1 00:00:11 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint1": interface is down.
[I] Jan  1 00:00:11 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": SSID reset.
[I] Jan  1 00:00:11 ndm: Network::Interface::Wifi: WPA PSK set.
[I] Jan  1 00:00:11 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": interface is down.
[I] Jan  1 00:00:11 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint3": interface is down.
[I] Jan  1 00:00:11 ndm: Network::Interface::IP: "WifiMaster0/AccessPoint2": security level set to "private".
[I] Jan  1 00:00:11 ndm: Network::Interface::Base: "WifiMaster0/WifiStation0": interface is down.
[I] Jan  1 00:00:11 ndm: Network::Interface::IP: "WifiMaster0/AccessPoint1": security level set to "private".
[I] Jan  1 00:00:12 ndm: Module::Manager: loaded 33 modules.
[I] Jan  1 00:00:12 ndm: Network::Interface::IP: "WifiMaster0/AccessPoint3": security level set to "private".
[I] Jan  1 00:00:12 ndm: Network::Interface::Radio: the radio switch state is changed to on, software state is down [WifiMaster0].
[I] Jan  1 00:00:12 ndnproxy: ndnproxy 1.2.3b10 started.
[I] Jan  1 00:00:12 ndnproxy: PID file: /var/ndnproxymain.pid.
[I] Jan  1 00:00:12 ndnproxy: stats. file: /var/ndnproxymain.stat.
[I] Jan  1 00:00:12 ndm: FileSystem::Proc: system setting saved.
[I] Jan  1 00:00:12 ndm: Core::Syslog: last message repeated 13 times.
[I] Jan  1 03:00:12 ndm: Core::System::Timezone: timezone set to "Europe/Moscow".
[I] Jan  1 03:00:12 ndm: Core::System::Domainname: the system domain name set.
[I] Jan  1 03:00:12 ndm: Core::System::Hostname: the host name set.
[I] Jan  1 03:00:12 ndm: Ntp::Client: server "0.pool.ntp.org" has been added.
[I] Jan  1 03:00:12 ndm: Ntp::Client: server "1.pool.ntp.org" has been added.
[I] Jan  1 03:00:12 ndm: Ntp::Client: server "2.pool.ntp.org" has been added.
[I] Jan  1 03:00:12 ndm: Ntp::Client: server "3.pool.ntp.org" has been added.
[I] Jan  1 03:00:12 ndm: Command::LogResponse: applied.
[I] Jan  1 03:00:12 ndm: Core::Authenticator: password has been set for user "admin".
[I] Jan  1 03:00:12 ndm: Core::Authenticator: user "admin" tagged with "cli".
[I] Jan  1 03:00:12 ndm: Core::Authenticator: user "admin" tagged with "http".
[E] Jan  1 03:00:12 ndm: Command::Base: argument parse error.
[I] Jan  1 03:00:12 ndm: Core::Authenticator: user "admin" tagged with "cifs".
[I] Jan  1 03:00:12 ndm: Core::Authenticator: user "admin" tagged with "printers".
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0": interface is up.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/0": renamed to "0".
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/0": access mode enabled.
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/0": set access VLAN ID: 2.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/0": interface is up.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/1": renamed to "1".
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/1": access mode enabled.
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/1": set access VLAN ID: 1.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/1": interface is up.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/2": renamed to "2".
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/2": access mode enabled.
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/2": set access VLAN ID: 1.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/2": interface is up.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/3": renamed to "3".
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/3": access mode enabled.
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/3": set access VLAN ID: 1.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/3": interface is up.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/4": renamed to "4".
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/4": access mode enabled.
[I] Jan  1 03:00:12 ndm: Network::Interface::Switch: "FastEthernet0/4": set access VLAN ID: 1.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/4": interface is up.
[I] Jan  1 03:00:12 ndm: Network::Interface::Base: "FastEthernet0/Vlan1": interface is down.
[I] Jan  1 03:00:12 ndm: Network::Interface::Repository: created interface FastEthernet0/Vlan1.
[I] Jan  1 03:00:13 ndm: Network::Interface::Base: "FastEthernet0/Vlan1": description saved.
[I] Jan  1 03:00:13 ndm: Network::Interface::IP: "FastEthernet0/Vlan1": security level set to "private".
[I] Jan  1 03:00:13 ndm: Dhcp::Client: FastEthernet0/Vlan1 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:13 ndm: Dhcp::Client: FastEthernet0/Vlan1 DHCP name servers are enabled.
[I] Jan  1 03:00:13 ndm: Network::Interface::Base: "FastEthernet0/Vlan1": interface is up.
[I] Jan  1 03:00:13 ndm: Network::Interface::Base: "FastEthernet0/Vlan2": interface is down.
[I] Jan  1 03:00:13 ndm: Network::Interface::Repository: created interface FastEthernet0/Vlan2.
[I] Jan  1 03:00:14 ndm: Network::Interface::Base: "FastEthernet0/Vlan2": renamed to "ISP".
[I] Jan  1 03:00:14 ndm: Network::Interface::Base: "FastEthernet0/Vlan2": description saved.
[I] Jan  1 03:00:14 ndm: Network::Interface::IP: "FastEthernet0/Vlan2": security level set to "public".
[I] Jan  1 03:00:14 ndm: Dhcp::Client: started DHCP client on FastEthernet0/Vlan2.
[I] Jan  1 03:00:14 ndm: Dhcp::Client: FastEthernet0/Vlan2 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:14 ndm: Dhcp::Client: FastEthernet0/Vlan2 DHCP name servers are enabled.
[I] Jan  1 03:00:14 ndm: Network::Interface::IP: "FastEthernet0/Vlan2": global priority is 700.
[I] Jan  1 03:00:14 ndm: kernel: device eth2 entered promiscuous mode
[I] Jan  1 03:00:14 ndm: Igmp::Proxy: upstream role assigned to FastEthernet0/Vlan2.
[I] Jan  1 03:00:14 ndm: Network::Interface::Base: "FastEthernet0/Vlan2": interface is up.
[I] Jan  1 03:00:14 ndm: Network::Interface::Base: "FastEthernet0/Vlan3": interface is down.
[I] Jan  1 03:00:14 ndm: Network::Interface::Repository: created interface FastEthernet0/Vlan3.
[I] Jan  1 03:00:15 ndm: Network::Interface::Base: "FastEthernet0/Vlan3": description saved.
[I] Jan  1 03:00:15 ndm: Network::Interface::IP: "FastEthernet0/Vlan3": security level set to "private".
[I] Jan  1 03:00:15 ndm: Dhcp::Client: FastEthernet0/Vlan3 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:15 ndm: Dhcp::Client: FastEthernet0/Vlan3 DHCP name servers are enabled.
[I] Jan  1 03:00:15 ndm: Network::Interface::Base: "FastEthernet0/Vlan3": interface is up.
[I] Jan  1 03:00:15 ndm: Network::Interface::Rtx::WifiMaster: country code set.
[I] Jan  1 03:00:15 ndm: Network::Interface::Rtx::WifiMaster: "WifiMaster0": PHY mode set.
[I] Jan  1 03:00:15 ndm: Network::Interface::Base: "WifiMaster0": interface is up.
[I] Jan  1 03:00:15 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": renamed to "AccessPoint".
[I] Jan  1 03:00:15 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": description saved.
[I] Jan  1 03:00:15 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": ACL type set.
[I] Jan  1 03:00:15 ndm: Network::Interface::IP: "WifiMaster0/AccessPoint0": security level set to "private".
[I] Jan  1 03:00:15 ndm: Network::Interface::Rtx::Wps: "WifiMaster0/AccessPoint0": WPS enabled.
[I] Jan  1 03:00:15 ndm: Network::Interface::Wifi: WPA PSK set.
[I] Jan  1 03:00:15 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": wireless encryption enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WPA2 algorithms enabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint0 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint0 DHCP name servers are enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Wireless: SSID saved.
[I] Jan  1 03:00:16 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint0": WMM extensions enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint0": interface is up.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint1": renamed to "GuestWiFi".
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint1": description saved.
[I] Jan  1 03:00:16 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint1": ACL type set.
[I] Jan  1 03:00:16 ndm: Network::Interface::IP: "WifiMaster0/AccessPoint1": security level set to "private".
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint1 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint1 DHCP name servers are enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint1": WMM extensions enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint1": interface is down.
[I] Jan  1 03:00:16 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint2": ACL type set.
[I] Jan  1 03:00:16 ndm: Network::Interface::IP: "WifiMaster0/AccessPoint2": security level set to "private".
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint2 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint2 DHCP name servers are enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint2": interface is down.
[I] Jan  1 03:00:16 ndm: Network::Interface::Rtx::AccessPoint: "WifiMaster0/AccessPoint3": ACL type set.
[I] Jan  1 03:00:16 ndm: Network::Interface::IP: "WifiMaster0/AccessPoint3": security level set to "private".
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint3 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/AccessPoint3 DHCP name servers are enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "WifiMaster0/AccessPoint3": interface is down.
[I] Jan  1 03:00:16 ndm: Network::Interface::IP: "WifiMaster0/WifiStation0": security level set to "public".
[I] Jan  1 03:00:16 ndm: Network::Interface::Rtx::WifiStation: "WifiMaster0/WifiStation0": wireless encryption disabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/WifiStation0 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: WifiMaster0/WifiStation0 DHCP name servers are enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "WifiMaster0/WifiStation0": interface is down.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "UsbDsl0": description saved.
[I] Jan  1 03:00:16 ndm: Network::Interface::IP: "UsbDsl0": security level set to "public".
[I] Jan  1 03:00:16 ndm: Dhcp::Client: UsbDsl0 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:16 ndm: Dhcp::Client: UsbDsl0 DHCP name servers are enabled.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: opmode is set to ADSL2+, Annex A.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 8a.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 8b.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 8c.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 8d.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 12a.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 12b.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 17a.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: enabled profile(s): 30a.
[I] Jan  1 03:00:16 ndm: Network::Interface::Mt2311::UsbDsl: PSD mask not changed.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "UsbDsl0": interface is up.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "UsbLte0": interface is down.
[I] Jan  1 03:00:16 ndm: Network::Interface::Base: "UsbLte0": interface is up.
[I] Jan  1 03:00:16 ndm: Network::Interface::Repository: created interface UsbLte0.
[I] Jan  1 03:00:17 ndm: Network::Interface::Base: "UsbLte0": description saved.
[I] Jan  1 03:00:17 ndm: Network::Interface::Usb: "UsbLte0": device ID assigned.
[I] Jan  1 03:00:17 ndm: Network::Interface::IP: "UsbLte0": security level set to "public".
[I] Jan  1 03:00:17 ndm: Dhcp::Client: started DHCP client on UsbLte0.
[I] Jan  1 03:00:17 ndm: Dhcp::Client: UsbLte0 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:17 ndm: Dhcp::Client: UsbLte0 DHCP name servers are enabled.
[E] Jan  1 03:00:17 ndm: Command::Base: argument parse error.
[I] Jan  1 03:00:17 ndm: Network::Interface::IP: "UsbLte0": global priority is 400.
[I] Jan  1 03:00:17 ndm: Command::LogResponse: TTL adjustment enabled.
[I] Jan  1 03:00:17 ndm: PingCheck::Profile: interface "UsbLte0" added to profile "default".
[I] Jan  1 03:00:17 ndm: PingCheck::Client: set ping-check profile for interface "UsbLte0".
[I] Jan  1 03:00:17 ndm: Network::Interface::Base: "UsbLte0": interface is up.
[I] Jan  1 03:00:17 ndm: Network::Interface::Base: "Bridge0": interface is down.
[I] Jan  1 03:00:17 ndm: Network::Interface::Base: "Bridge0": interface is up.
[I] Jan  1 03:00:17 ndm: Network::Interface::Repository: created interface Bridge0.
[I] Jan  1 03:00:18 ndm: Network::Interface::Base: "Bridge0": renamed to "Home".
[I] Jan  1 03:00:18 ndm: Network::Interface::Base: "Bridge0": description saved.
[I] Jan  1 03:00:18 ndm: Network::Interface::Base: "Bridge0": interface is up.
[I] Jan  1 03:00:18 ndm: Network::Interface::Mac: backed up the default address f2:0b:b1:b4:a2:49 of "Home" before changing.
[I] Jan  1 03:00:18 ndm: Network::Interface::IP: "Bridge0": interface is non-global.
[I] Jan  1 03:00:18 ndm: kernel: device eth2.1 entered promiscuous mode
[I] Jan  1 03:00:18 ndm: kernel: br0: port 1(eth2.1) entered forwarding state
[I] Jan  1 03:00:18 ndm: kernel: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
[I] Jan  1 03:00:18 ndm: kernel: device ra0 entered promiscuous mode
[I] Jan  1 03:00:18 ndm: kernel: br0: port 2(ra0) entered forwarding state
[I] Jan  1 03:00:18 ndm: Network::Interface::Bridge: FastEthernet0/Vlan1 inherited in Bridge0.
[I] Jan  1 03:00:18 ndm: kernel: br0: port 2(ra0) entered disabled state
[I] Jan  1 03:00:18 ndm: kernel: br0: port 1(eth2.1) entered disabled state
[I] Jan  1 03:00:18 ndm: Network::Interface::Bridge: AccessPoint included in Bridge0.
[I] Jan  1 03:00:18 ndm: Network::Interface::IP: "Bridge0": security level set to "private".
[I] Jan  1 03:00:18 ndm: Network::Interface::IP: "Bridge0": IP address is 192.168.1.1/24.
[I] Jan  1 03:00:18 ndm: Dhcp::Client: Bridge0 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:18 ndm: Network::Interface::Switch: switch link up at port 1 (FastEthernet0/1).
[I] Jan  1 03:00:18 ndm: Dhcp::Client: Bridge0 DHCP name servers are enabled.
[I] Jan  1 03:00:18 ndm: Igmp::Proxy: added downstream interface Bridge0.
[I] Jan  1 03:00:18 ndm: Network::Interface::Base: "Bridge1": interface is down.
[I] Jan  1 03:00:18 ndm: Network::Interface::Base: "Bridge1": interface is up.
[I] Jan  1 03:00:18 ndm: Network::Interface::Repository: created interface Bridge1.
[I] Jan  1 03:00:19 ndm: kernel: br0: port 2(ra0) entered forwarding state
[I] Jan  1 03:00:19 ndm: kernel: br0: port 1(eth2.1) entered forwarding state
[I] Jan  1 03:00:19 ndm: Network::Interface::Base: "Bridge1": renamed to "Guest".
[I] Jan  1 03:00:19 ndm: Network::Interface::Base: "Bridge1": description saved.
[I] Jan  1 03:00:19 ndm: TrafficControl::Manager: "Bridge1" interface rate limited to 5120 kbit/s.
[I] Jan  1 03:00:19 ndm: Network::Interface::Base: "Bridge1": interface is up.
[I] Jan  1 03:00:19 ndm: Network::Interface::Mac: backed up the default address 4e:4d:60:9b:84:f5 of "Guest" before changing.
[I] Jan  1 03:00:19 ndm: Network::Interface::IP: "Bridge1": interface is non-global.
[I] Jan  1 03:00:19 ndm: kernel: device eth2.3 entered promiscuous mode
[I] Jan  1 03:00:19 ndm: kernel: br1: port 1(eth2.3) entered forwarding state
[I] Jan  1 03:00:20 ndm: kernel: ADDRCONF(NETDEV_CHANGE): br1: link becomes ready
[I] Jan  1 03:00:20 ndm: kernel: device ra1 entered promiscuous mode
[I] Jan  1 03:00:20 ndm: kernel: br1: port 1(eth2.3) entered disabled state
[I] Jan  1 03:00:19 ndm: Network::Interface::Bridge: FastEthernet0/Vlan3 inherited in Bridge1.
[I] Jan  1 03:00:20 ndm: kernel: br1: port 1(eth2.3) entered forwarding state
[I] Jan  1 03:00:20 ndm: Network::Interface::Bridge: GuestWiFi included in Bridge1.
[I] Jan  1 03:00:20 ndm: Network::Interface::IP: "Bridge1": security level set to "protected".
[I] Jan  1 03:00:20 ndm: Network::Interface::IP: "Bridge1": IP address is 10.1.30.1/24.
[I] Jan  1 03:00:20 ndm: Dhcp::Client: Bridge1 DHCP client DNS host routes are enabled.
[I] Jan  1 03:00:20 ndm: Dhcp::Client: Bridge1 DHCP name servers are enabled.
[I] Jan  1 03:00:20 ndm: Network::Interface::Base: "Bridge1": interface is up.
[I] Jan  1 03:00:20 ndm: Dhcp::Pool: pool "_WEBADMIN" range has been saved.
[I] Jan  1 03:00:20 ndm: Dhcp::Server: pool "_WEBADMIN" bound to interface Home.
[I] Jan  1 03:00:20 ndm: Dhcp::Server: pool "_WEBADMIN" is enabled.
[I] Jan  1 03:00:20 ndm: Dhcp::Pool: pool "_WEBADMIN_GUEST_AP" range has been saved.
[I] Jan  1 03:00:20 ndm: Dhcp::Server: pool "_WEBADMIN_GUEST_AP" bound to interface Guest.
[I] Jan  1 03:00:20 ndm: Dhcp::Server: pool "_WEBADMIN_GUEST_AP" is enabled.
[I] Jan  1 03:00:20 ndm: Http::Manager: security level unchanged.
[I] Jan  1 03:00:20 ndm: Http::Manager: bruteforce detection is reconfigured.
[I] Jan  1 03:00:20 ndm: Command::LogResponse: NAT rule added.
[I] Jan  1 03:00:20 ndm: Telnet::Server: security level unchanged.
[I] Jan  1 03:00:20 ndm: Telnet::Server: bruteforce detection is reconfigured.
[E] Jan  1 03:00:20 ndm: Command::Base: no such command: ftp.
[I] Jan  1 03:00:20 ndm: Hotspot::Manager: policy "permit" applied to interface "Home".
[I] Jan  1 03:00:20 ndm: Network::Interface::Rtx::Ppe: software PPE enabled.
[I] Jan  1 03:00:20 ndm: Network::Interface::Rtx::Ppe: hardware PPE enabled.
[I] Jan  1 03:00:20 ndm: UPnP::Manager: using LAN interface: Bridge0.
[I] Jan  1 03:00:20 ndm: Dhcp::Server: service enabled.
[I] Jan  1 03:00:20 ndm: Dns::Manager: DNS proxy enabled.
[I] Jan  1 03:00:20 ndm: Igmp::Proxy: IGMP proxy enabled.
[I] Jan  1 03:00:20 ndm: Http::Manager: HTTP service was enabled.
[I] Jan  1 03:00:20 ndm: Command::LogResponse: CIFS server enabled.
[I] Jan  1 03:00:20 ndm: Telnet::Server: telnet server enabled.
[I] Jan  1 03:00:20 ndm: Ntp::Client: NTP client enabled.
[I] Jan  1 03:00:20 ndm: Core::Hotplug::Manager: scanning hardware...
[I] Jan  1 03:00:20 ndm: Core::Hotplug::Manager: scanning hardware: done.
[I] Jan  1 03:00:20 ndm: Core::Init: system ready, core startup time is 20 seconds.
[I] Jan  1 03:00:20 ndm: Hotspot::Discovery::Explorer: Interface Bridge0 neighbour explorer started.
[I] Jan  1 03:00:20 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/igmpsn.ko.
[I] Jan  1 03:00:20 ndm: Hotspot::Discovery::Explorer: Interface Bridge1 neighbour explorer started.
[I] Jan  1 03:00:20 ndm: kernel: igmpsn: IGMP switch snooping module (C) 2015, 2016 NDM Systems Inc., v4.0.34
[I] Jan  1 03:00:20 ndm: Network::Interface::Rtx::WifiMaster: "WifiMaster0": auto channel mode set.
[I] Jan  1 03:00:20 ndm: kernel: br0: port 2(ra0) entered disabled state
[I] Jan  1 03:00:21 ndm: kernel: br1: port 1(eth2.3) entered forwarding state
[I] Jan  1 03:00:21 ndm: kernel: br0: port 2(ra0) entered forwarding state
[I] Jan  1 03:00:21 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/hw_nat.ko.
[I] Jan  1 03:00:21 ndm: kernel: Ralink/MTK HW NAT 5.0.2.0-5 Module Enabled, FoE Size: 16384
[I] Jan  1 03:00:21 ndm: Core::System::DriverManager: loading /lib/modules/3.4.113/fastvpn.ko.
[I] Jan  1 03:00:22 ndm: kernel: SWNAT sizeof(bind) = 200
[I] Jan  1 03:00:22 ndm: kernel: SWNAT sizeof(hashent) = 56
[I] Jan  1 03:00:22 ndm: kernel: SWNAT is registered
[I] Jan  1 03:00:22 ndm: kernel: SWNAT enabled
[I] Jan  1 03:00:22 ndm: kernel: SWNAT caps: L2TP, PPTP, PPPoE, IPoE, MC, USB CDC/DSL
[I] Jan  1 03:00:22 ndm: kernel: Fast VPN init, v4.0-86-8
[I] Jan  1 03:00:22 ndm: kernel: PPPoE/IPoE LAN software acceleration is disabled
[I] Jan  1 03:00:22 ndm: Http::Manager: new Web server configuration was applied.
[I] Jan  1 03:00:22 ndm: Ntp::Client: unable to communicate with "1.pool.ntp.org".
[I] Jan  1 03:00:22 ndm: Ntp::Client: could not synchronize, waiting...
[I] Jan  1 03:00:22 ndhcps: _WEBADMIN: NDM DHCP server (version 3.1.15) started.
[I] Jan  1 03:00:22 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Jan  1 03:00:22 ndm: Core::Server: client disconnected.
[I] Jan  1 03:00:22 telnetd: waiting for connections...
[I] Jan  1 03:00:23 ndm: kernel: br0: port 2(ra0) entered forwarding state
[I] Jan  1 03:00:23 ndhcps: _WEBADMIN_GUEST_AP: NDM DHCP server (version 3.1.15) started.
[I] Jan  1 03:00:23 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Jan  1 03:00:23 ndm: Core::Server: client disconnected.
[I] Jan  1 03:00:23 nimproxy: NDM IGMP/Multicast proxy (version 0.0.25) started.
[I] Jan  1 03:00:23 ndm: kernel: eth2: no IPv6 routers present
[I] Jan  1 03:00:23 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(14:a7:8b:95:bc:67) had associated successfully.
[I] Jan  1 03:00:24 ndm: kernel: eth2.1: no IPv6 routers present
[I] Jan  1 03:00:25 ndm: kernel: eth2.2: no IPv6 routers present
[I] Jan  1 03:00:26 ndm: kernel: eth2.3: no IPv6 routers present
[I] Jan  1 03:00:28 ndhcps: _WEBADMIN: DHCPDISCOVER received  from 00:15:65:f8:b1:80.
[I] Jan  1 03:00:28 ndhcps: _WEBADMIN: making OFFER of 192.168.1.57 to 00:15:65:f8:b1:80.
[I] Jan  1 03:00:29 ndm: kernel: ACS result: primary channel 8, 40 MHz spectrum min dirty (with CCA) = 295
[I] Jan  1 03:00:29 wmond: WifiMaster0/AccessPoint0: (MT76x2) BSS(ra0) channel switched to 8.
[I] Jan  1 03:00:29 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.57 from 00:15:65:f8:b1:80.
[I] Jan  1 03:00:29 ndhcps: _WEBADMIN: sending ACK of 192.168.1.57 to 00:15:65:f8:b1:80.
[I] Jan  1 03:00:29 ndm: kernel: br0: no IPv6 routers present
[I] Jan  1 03:00:30 ndm: kernel: br1: no IPv6 routers present
[I] Jan  1 03:00:31 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(14:a7:8b:95:bc:67) had associated successfully.
[I] Jan  1 03:00:31 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(14:a7:8b:95:bc:67) set key done in WPA2/WPA2PSK.
[I] Jan  1 03:00:31 ndm: kernel: usb 1-1: new high-speed USB device number 2 using ehci-platform
[I] Jan  1 03:00:31 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=14fe
[I] Jan  1 03:00:31 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Jan  1 03:00:31 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Jan  1 03:00:31 ndm: kernel: usb 1-1: SerialNumber: 0123456789ABCDEF
[I] Jan  1 03:00:31 ndm: kernel: scsi0 : usb-storage 1-1:1.0
[I] Jan  1 03:00:31 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(14:a7:8b:95:c4:53) had associated successfully.
[I] Jan  1 03:00:32 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(14:a7:8b:95:c4:53) set key done in WPA2/WPA2PSK.
[I] Jan  1 03:00:32 ndm: kernel: ra0: no IPv6 routers present
[I] Jan  1 03:00:33 ndhcps: _WEBADMIN: DHCPDISCOVER received  from 14:a7:8b:95:bc:67.
[I] Jan  1 03:00:33 ndhcps: _WEBADMIN: making OFFER of 192.168.1.41 to 14:a7:8b:95:bc:67.
[I] Jan  1 03:00:33 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.41 from 14:a7:8b:95:bc:67.
[I] Jan  1 03:00:33 ndhcps: _WEBADMIN: sending ACK of 192.168.1.41 to 14:a7:8b:95:bc:67.
[I] Jan  1 03:00:34 ndhcps: _WEBADMIN: DHCPDISCOVER received  from 14:a7:8b:95:c4:53.
[I] Jan  1 03:00:34 ndm: Ntp::Client: unable to communicate with "2.pool.ntp.org".
[I] Jan  1 03:00:34 ndm: Ntp::Client: could not synchronize, waiting...
[I] Jan  1 03:00:34 ndhcps: _WEBADMIN: making OFFER of 192.168.1.61 to 14:a7:8b:95:c4:53.
[I] Jan  1 03:00:34 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.61 from 14:a7:8b:95:c4:53.
[I] Jan  1 03:00:34 ndm: Cifs::ServerNQ: service started.
[I] Jan  1 03:00:34 ndhcps: _WEBADMIN: sending ACK of 192.168.1.61 to 14:a7:8b:95:c4:53.
[I] Jan  1 03:00:34 ndm: kernel: scsi 0:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[W] Jan  1 03:00:34 ndm: kernel: sr0: scsi-1 drive
[I] Jan  1 03:00:34 ndm: kernel: cdrom: Uniform CD-ROM driver Revision: 3.20
[I] Jan  1 03:00:34 ndm: kernel: sr 0:0:0:0: Attached scsi CD-ROM sr0
[I] Jan  1 03:00:34 ndm: kernel: sr 0:0:0:0: Attached scsi generic sg0 type 5
[I] Jan  1 03:00:34 ndm: kernel: scsi 0:0:0:1: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Jan  1 03:00:34 ndm: kernel: sd 0:0:0:1: Attached scsi generic sg1 type 0
[I] Jan  1 03:00:34 ndm: kernel: sd 0:0:0:1: [sda] Attached SCSI removable disk
[I] Jan  1 03:00:37 ndhcps: _WEBADMIN: DHCPINFORM received for 192.168.1.57 from 00:15:65:f8:b1:80.
[I] Jan  1 03:00:37 ndhcps: _WEBADMIN: sending INFORM to 00:15:65:f8:b1:80.
[I] Jan  1 03:00:40 ndhcps: _WEBADMIN: DHCPINFORM received for 192.168.1.57 from 00:15:65:f8:b1:80.
[I] Jan  1 03:00:40 ndhcps: _WEBADMIN: sending INFORM to 00:15:65:f8:b1:80.
[E] Jan  1 03:00:41 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Jan  1 03:00:41 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Jan  1 03:00:44 ndm: kernel: usb 1-1: USB disconnect, device number 2
[I] Jan  1 03:00:44 ndm: kernel: usb 1-1: new high-speed USB device number 3 using ehci-platform
[I] Jan  1 03:00:45 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=1506
[I] Jan  1 03:00:45 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Jan  1 03:00:45 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Jan  1 03:00:45 ndm: kernel: option 1-1:1.0: GSM modem (1-port) converter detected
[I] Jan  1 03:00:45 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[I] Jan  1 03:00:45 ndm: kernel: option 1-1:1.1: GSM modem (1-port) converter detected
[I] Jan  1 03:00:45 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[I] Jan  1 03:00:45 ndm: kernel: scsi1 : usb-storage 1-1:1.3
[I] Jan  1 03:00:45 ndm: kernel: scsi2 : usb-storage 1-1:1.4
[I] Jan  1 03:00:46 ndm: Ntp::Client: unable to communicate with "3.pool.ntp.org".
[I] Jan  1 03:00:46 ndm: Ntp::Client: could not synchronize, waiting...
[I] Jan  1 03:00:46 ndm: kernel: ADDRCONF(NETDEV_CHANGE): lte_br0: link becomes ready
[I] Jan  1 03:00:46 ndm: Network::Interface::Usb: interface "UsbLte0" is plugged (port 1).
[I] Jan  1 03:00:48 ndm: kernel: scsi 1:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[I] Jan  1 03:00:48 ndm: kernel: scsi 2:0:0:0: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Jan  1 03:00:48 ndm: kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
[W] Jan  1 03:00:48 ndm: kernel: sr0: scsi-1 drive
[I] Jan  1 03:00:48 ndm: kernel: sr 1:0:0:0: Attached scsi CD-ROM sr0
[I] Jan  1 03:00:48 ndm: kernel: sr 1:0:0:0: Attached scsi generic sg1 type 5
[I] Jan  1 03:00:48 ndm: kernel: sd 2:0:0:0: [sda] Attached SCSI removable disk
[I] Jan  1 03:00:50 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[E] Jan  1 03:00:55 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Jan  1 03:00:55 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Jan  1 03:00:56 ndm: kernel: lte_br0: no IPv6 routers present
[I] Jan  1 03:00:58 ndm: Ntp::Client: unable to communicate with "0.pool.ntp.org".
[I] Jan  1 03:00:58 ndm: Ntp::Client: could not synchronize, waiting...
[I] Jan  1 03:01:08 ndm: Network::Interface::UsbLte: "UsbLte0": connection timeout.
[I] Jan  1 03:01:16 ndm: kernel: ADDRCONF(NETDEV_CHANGE): wimax0: link becomes ready
[I] Jan  1 03:01:16 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[I] Jan  1 03:01:23 ndm: Network::Interface::UsbLte: "UsbLte0": connection established.
[I] Jan  1 03:01:26 ndhcpc: UsbLte0: NDM DHCP client (version 3.1.15) started.
[I] Jan  1 03:01:27 ndm: Dhcp::Client: configuring interface UsbLte0.
[I] Jan  1 03:01:27 ndm: Network::Interface::IP: "UsbLte0": IP address is 100.88.235.27/29.
[I] Jan  1 03:01:27 ndm: Dhcp::Client: obtained IP address 100.88.235.27/29.
[I] Jan  1 03:01:27 ndm: Dhcp::Client: interface "UsbLte0" is global, priority 400.
[I] Jan  1 03:01:27 ndm: Dhcp::Client: adding a default route via 100.88.235.25.
[I] Jan  1 03:01:27 ndm: Dhcp::Client: adding a host route to name server 10.52.129.36.
[I] Jan  1 03:01:27 ndm: Dhcp::Client: adding name server 10.52.129.36.
[I] Jan  1 03:01:27 ndm: Dns::Manager: name server 10.52.129.36 added, domain (default).
[I] Jan  1 03:01:27 ndm: Dhcp::Client: adding a host route to name server 10.52.129.56.
[I] Jan  1 03:01:27 ndm: Dhcp::Client: adding name server 10.52.129.56.
[I] Jan  1 03:01:27 ndm: Dns::Manager: name server 10.52.129.56 added, domain (default).
[I] Jan  1 03:01:27 ndm: kernel: wimax0: no IPv6 routers present
[I] Jan  1 03:01:27 ndm: Network::InterfaceFlusher: flushed conntrack and route cache.
[I] Jan  1 03:01:29 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Jan  1 03:01:29 upnp: HTTP listening on port 32986
[I] Jan  1 03:01:29 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Apr  2 11:24:45 ndm: Core::System::Clock: system time has been changed.
[I] Apr  2 11:24:45 ndm: Ntp::Client: time synchronized with "1.pool.ntp.org".
[I] Apr  2 11:26:16 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(24:f0:94:63:1f:0a) had associated successfully.
[I] Apr  2 11:26:16 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(24:f0:94:63:1f:0a) set key done in WPA2/WPA2PSK.
[I] Apr  2 11:26:18 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.1.67 from 24:f0:94:63:1f:0a.
[I] Apr  2 11:26:18 ndhcps: _WEBADMIN: sending ACK of 192.168.1.67 to 24:f0:94:63:1f:0a.
[I] Apr  2 11:26:43 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(84:20:96:a9:12:ff) had associated successfully.
[I] Apr  2 11:26:44 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(84:20:96:a9:12:ff) set key done in WPA2/WPA2PSK.
[I] Apr  2 11:26:44 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.1.48 from 84:20:96:a9:12:ff.
[I] Apr  2 11:26:44 ndhcps: _WEBADMIN: sending ACK of 192.168.1.48 to 84:20:96:a9:12:ff.
[I] Apr  2 11:26:46 ndm: kernel: usb 1-1: USB disconnect, device number 3
[I] Apr  2 11:26:46 ndm: kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[I] Apr  2 11:26:46 ndm: kernel: option 1-1:1.0: device disconnected
[I] Apr  2 11:26:46 ndm: kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[I] Apr  2 11:26:46 ndm: kernel: option 1-1:1.1: device disconnected
[I] Apr  2 11:26:46 ndm: kernel: wimax0: unregister 'huawei_ether' usb-ehci-platform-1, Huawei Ethernet Device
[I] Apr  2 11:26:46 ndm: Network::Interface::UsbLte: "UsbLte0": tty disconnected.
[I] Apr  2 11:26:46 ndm: Network::Interface::Usb: interface "UsbLte0" is unplugged.
[I] Apr  2 11:26:46 ndm: Network::Interface::Usb: "UsbLte0": device ID removed.
[W] Apr  2 11:26:46 ndm: Dhcp::Client: DHCP server is not responding.
[I] Apr  2 11:26:46 ndm: Network::Interface::IP: "UsbLte0": IP address cleared.
[I] Apr  2 11:26:46 ndhcpc: UsbLte0: NDM DHCP client stopped (exit status 0).
[I] Apr  2 11:26:46 upnp: shutting down MiniUPnPd
[I] Apr  2 11:26:46 ndm: Core::Server: client disconnected.
[I] Apr  2 11:26:52 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) had associated successfully.
[I] Apr  2 11:26:53 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) set key done in WPA2/WPA2PSK.
[I] Apr  2 11:26:54 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.1.68 from 98:01:a7:b6:a5:cb.
[I] Apr  2 11:26:54 ndhcps: _WEBADMIN: sending ACK of 192.168.1.68 to 98:01:a7:b6:a5:cb.
[I] Apr  2 11:26:57 ndm: kernel: usb 1-1: new high-speed USB device number 4 using ehci-platform
[I] Apr  2 11:26:57 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=14fe
[I] Apr  2 11:26:57 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Apr  2 11:26:57 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Apr  2 11:26:57 ndm: kernel: usb 1-1: SerialNumber: 0123456789ABCDEF
[I] Apr  2 11:26:57 ndm: kernel: scsi3 : usb-storage 1-1:1.0
[I] Apr  2 11:27:00 ndm: kernel: scsi 3:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[W] Apr  2 11:27:00 ndm: kernel: sr0: scsi-1 drive
[I] Apr  2 11:27:00 ndm: kernel: sr 3:0:0:0: Attached scsi CD-ROM sr0
[I] Apr  2 11:27:00 ndm: kernel: sr 3:0:0:0: Attached scsi generic sg0 type 5
[I] Apr  2 11:27:00 ndm: kernel: scsi 3:0:0:1: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:27:00 ndm: kernel: sd 3:0:0:1: Attached scsi generic sg1 type 0
[I] Apr  2 11:27:00 ndm: kernel: sd 3:0:0:1: [sda] Attached SCSI removable disk
[E] Apr  2 11:27:07 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Apr  2 11:27:07 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Apr  2 11:27:09 ndm: kernel: usb 1-1: USB disconnect, device number 4
[I] Apr  2 11:27:10 ndm: kernel: usb 1-1: new high-speed USB device number 5 using ehci-platform
[I] Apr  2 11:27:10 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=1506
[I] Apr  2 11:27:10 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Apr  2 11:27:10 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Apr  2 11:27:10 ndm: kernel: option 1-1:1.0: GSM modem (1-port) converter detected
[I] Apr  2 11:27:10 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[I] Apr  2 11:27:10 ndm: kernel: option 1-1:1.1: GSM modem (1-port) converter detected
[I] Apr  2 11:27:10 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[I] Apr  2 11:27:11 ndm: kernel: scsi4 : usb-storage 1-1:1.3
[I] Apr  2 11:27:11 ndm: kernel: scsi5 : usb-storage 1-1:1.4
[I] Apr  2 11:27:11 ndm: Network::Interface::Usb: interface "UsbLte0" is plugged (port 1).
[I] Apr  2 11:27:14 ndm: kernel: scsi 4:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:27:14 ndm: kernel: scsi 5:0:0:0: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:27:14 ndm: kernel: sd 5:0:0:0: Attached scsi generic sg0 type 0
[W] Apr  2 11:27:14 ndm: kernel: sr0: scsi-1 drive
[I] Apr  2 11:27:14 ndm: kernel: sr 4:0:0:0: Attached scsi CD-ROM sr0
[I] Apr  2 11:27:14 ndm: kernel: sr 4:0:0:0: Attached scsi generic sg1 type 5
[I] Apr  2 11:27:14 ndm: kernel: sd 5:0:0:0: [sda] Attached SCSI removable disk
[I] Apr  2 11:27:16 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[E] Apr  2 11:27:21 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Apr  2 11:27:21 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Apr  2 11:27:33 ndm: Network::Interface::UsbLte: "UsbLte0": connection timeout.
[I] Apr  2 11:27:42 ndm: kernel: ADDRCONF(NETDEV_CHANGE): wimax0: link becomes ready
[I] Apr  2 11:27:42 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[I] Apr  2 11:27:49 ndm: Network::Interface::UsbLte: "UsbLte0": connection established.
[I] Apr  2 11:27:52 ndhcpc: UsbLte0: NDM DHCP client (version 3.1.15) started.
[I] Apr  2 11:27:52 ndm: Dhcp::Client: configuring interface UsbLte0.
[I] Apr  2 11:27:52 ndm: Network::Interface::IP: "UsbLte0": IP address is 100.77.196.140/29.
[I] Apr  2 11:27:52 ndm: Dhcp::Client: obtained IP address 100.77.196.140/29.
[I] Apr  2 11:27:52 ndm: Dhcp::Client: interface "UsbLte0" is global, priority 400.
[I] Apr  2 11:27:52 ndm: Dhcp::Client: adding a default route via 100.77.196.137.
[I] Apr  2 11:27:52 ndm: Dhcp::Client: adding a host route to name server 10.52.129.36.
[I] Apr  2 11:27:52 ndm: Dhcp::Client: adding name server 10.52.129.36.
[I] Apr  2 11:27:52 ndm: Dns::Manager: name server 10.52.129.36 added, domain (default).
[I] Apr  2 11:27:52 ndm: Dhcp::Client: adding a host route to name server 10.52.129.56.
[I] Apr  2 11:27:52 ndm: Dhcp::Client: adding name server 10.52.129.56.
[I] Apr  2 11:27:52 ndm: Dns::Manager: name server 10.52.129.56 added, domain (default).
[I] Apr  2 11:27:52 ndm: Network::InterfaceFlusher: flushed UsbLte0 conntrack and route cache.
[I] Apr  2 11:27:53 ndm: kernel: wimax0: no IPv6 routers present
[I] Apr  2 11:27:54 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Apr  2 11:27:54 upnp: HTTP listening on port 52517
[I] Apr  2 11:27:54 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Apr  2 11:28:00 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) had associated successfully.
[I] Apr  2 11:28:01 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) set key done in WPA2/WPA2PSK.
[I] Apr  2 11:28:02 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.1.68 from 98:01:a7:b6:a5:cb.
[I] Apr  2 11:28:02 ndhcps: _WEBADMIN: sending ACK of 192.168.1.68 to 98:01:a7:b6:a5:cb.
[I] Apr  2 11:28:04 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:28:04 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:28:04 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:28:04 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:28:05 ndm: UPnP::Manager: redirect and forward rules deleted: udp 8909.
[I] Apr  2 11:28:06 ndm: UPnP::Manager: redirect and forward rules deleted: tcp 8909.
[I] Apr  2 11:28:08 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:28:08 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:28:09 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:28:09 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:28:26 ndm: kernel: usb 1-1: USB disconnect, device number 5
[I] Apr  2 11:28:26 ndm: kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[I] Apr  2 11:28:26 ndm: kernel: option 1-1:1.0: device disconnected
[I] Apr  2 11:28:26 ndm: kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[I] Apr  2 11:28:26 ndm: kernel: option 1-1:1.1: device disconnected
[I] Apr  2 11:28:26 ndm: kernel: wimax0: unregister 'huawei_ether' usb-ehci-platform-1, Huawei Ethernet Device
[I] Apr  2 11:28:26 ndm: Network::Interface::Usb: interface "UsbLte0" is unplugged.
[I] Apr  2 11:28:26 ndm: Network::Interface::Usb: "UsbLte0": device ID removed.
[W] Apr  2 11:28:26 ndm: Dhcp::Client: DHCP server is not responding.
[I] Apr  2 11:28:26 ndm: Network::Interface::IP: "UsbLte0": IP address cleared.
[I] Apr  2 11:28:26 ndhcpc: UsbLte0: NDM DHCP client stopped (exit status 0).
[I] Apr  2 11:28:26 upnp: shutting down MiniUPnPd
[I] Apr  2 11:28:26 ndm: Core::Server: client disconnected.
[I] Apr  2 11:28:37 ndm: kernel: usb 1-1: new high-speed USB device number 6 using ehci-platform
[I] Apr  2 11:28:37 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=14fe
[I] Apr  2 11:28:37 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Apr  2 11:28:37 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Apr  2 11:28:37 ndm: kernel: usb 1-1: SerialNumber: 0123456789ABCDEF
[I] Apr  2 11:28:37 ndm: kernel: scsi6 : usb-storage 1-1:1.0
[I] Apr  2 11:28:40 ndm: kernel: scsi 6:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[W] Apr  2 11:28:40 ndm: kernel: sr0: scsi-1 drive
[I] Apr  2 11:28:40 ndm: kernel: sr 6:0:0:0: Attached scsi CD-ROM sr0
[I] Apr  2 11:28:40 ndm: kernel: sr 6:0:0:0: Attached scsi generic sg0 type 5
[I] Apr  2 11:28:40 ndm: kernel: scsi 6:0:0:1: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:28:40 ndm: kernel: sd 6:0:0:1: Attached scsi generic sg1 type 0
[I] Apr  2 11:28:40 ndm: kernel: sd 6:0:0:1: [sda] Attached SCSI removable disk
[E] Apr  2 11:28:47 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Apr  2 11:28:47 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Apr  2 11:28:49 ndm: kernel: usb 1-1: USB disconnect, device number 6
[I] Apr  2 11:28:50 ndm: kernel: usb 1-1: new high-speed USB device number 7 using ehci-platform
[I] Apr  2 11:28:50 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=1506
[I] Apr  2 11:28:50 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Apr  2 11:28:50 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Apr  2 11:28:50 ndm: kernel: option 1-1:1.0: GSM modem (1-port) converter detected
[I] Apr  2 11:28:50 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[I] Apr  2 11:28:50 ndm: kernel: option 1-1:1.1: GSM modem (1-port) converter detected
[I] Apr  2 11:28:50 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[I] Apr  2 11:28:50 ndm: kernel: scsi7 : usb-storage 1-1:1.3
[I] Apr  2 11:28:50 ndm: kernel: scsi8 : usb-storage 1-1:1.4
[I] Apr  2 11:28:51 ndm: Network::Interface::Usb: interface "UsbLte0" is plugged (port 1).
[I] Apr  2 11:28:53 ndm: kernel: scsi 7:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:28:53 ndm: kernel: scsi 8:0:0:0: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:28:53 ndm: kernel: sd 8:0:0:0: Attached scsi generic sg0 type 0
[I] Apr  2 11:28:53 ndm: kernel: sd 8:0:0:0: [sda] Attached SCSI removable disk
[W] Apr  2 11:28:53 ndm: kernel: sr0: scsi-1 drive
[I] Apr  2 11:28:53 ndm: kernel: sr 7:0:0:0: Attached scsi CD-ROM sr0
[I] Apr  2 11:28:53 ndm: kernel: sr 7:0:0:0: Attached scsi generic sg1 type 5
[I] Apr  2 11:28:56 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[E] Apr  2 11:29:00 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Apr  2 11:29:00 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Apr  2 11:29:13 ndm: Network::Interface::UsbLte: "UsbLte0": connection timeout.
[I] Apr  2 11:29:22 ndm: kernel: ADDRCONF(NETDEV_CHANGE): wimax0: link becomes ready
[I] Apr  2 11:29:22 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[I] Apr  2 11:29:29 ndm: Network::Interface::UsbLte: "UsbLte0": connection established.
[I] Apr  2 11:29:32 ndhcpc: UsbLte0: NDM DHCP client (version 3.1.15) started.
[I] Apr  2 11:29:32 ndm: Dhcp::Client: configuring interface UsbLte0.
[I] Apr  2 11:29:32 ndm: Network::Interface::IP: "UsbLte0": IP address is 100.77.204.204/29.
[I] Apr  2 11:29:32 ndm: Dhcp::Client: obtained IP address 100.77.204.204/29.
[I] Apr  2 11:29:32 ndm: Dhcp::Client: interface "UsbLte0" is global, priority 400.
[I] Apr  2 11:29:32 ndm: Dhcp::Client: adding a default route via 100.77.204.201.
[I] Apr  2 11:29:32 ndm: Dhcp::Client: adding a host route to name server 10.52.129.36.
[I] Apr  2 11:29:32 ndm: Dhcp::Client: adding name server 10.52.129.36.
[I] Apr  2 11:29:32 ndm: Dns::Manager: name server 10.52.129.36 added, domain (default).
[I] Apr  2 11:29:32 ndm: Dhcp::Client: adding a host route to name server 10.52.129.56.
[I] Apr  2 11:29:32 ndm: Dhcp::Client: adding name server 10.52.129.56.
[I] Apr  2 11:29:32 ndm: Dns::Manager: name server 10.52.129.56 added, domain (default).
[I] Apr  2 11:29:32 ndm: Network::InterfaceFlusher: flushed UsbLte0 conntrack and route cache.
[I] Apr  2 11:29:33 ndm: kernel: wimax0: no IPv6 routers present
[I] Apr  2 11:29:35 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Apr  2 11:29:35 upnp: HTTP listening on port 54017
[I] Apr  2 11:29:35 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Apr  2 11:29:35 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:29:35 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:29:35 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:29:35 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:30:05 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(24:f0:94:63:1f:0a) had disassociated.
[I] Apr  2 11:30:13 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) had disassociated.
[I] Apr  2 11:31:15 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) had associated successfully.
[I] Apr  2 11:31:15 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) set key done in WPA2/WPA2PSK.
[I] Apr  2 11:31:17 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.1.68 from 98:01:a7:b6:a5:cb.
[I] Apr  2 11:31:17 ndhcps: _WEBADMIN: sending ACK of 192.168.1.68 to 98:01:a7:b6:a5:cb.
[I] Apr  2 11:31:18 ndm: UPnP::Manager: redirect and forward rules deleted: udp 8909.
[I] Apr  2 11:31:18 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:31:18 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:31:18 ndm: UPnP::Manager: redirect and forward rules deleted: tcp 8909.
[I] Apr  2 11:31:18 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:31:18 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:31:21 ndm: UPnP::Manager: redirect and forward rules deleted: udp 8909.
[I] Apr  2 11:31:22 ndm: UPnP::Manager: redirect and forward rules deleted: tcp 8909.
[I] Apr  2 11:31:23 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:31:23 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:31:24 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:31:24 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[E] Apr  2 11:32:20 ndm: Core::Ndss: HTTP error: 404 (Not found).
[E] Apr  2 11:32:41 ndm: Core::Ndss: HTTP error: 404 (Not found).
[I] Apr  2 11:32:43 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(e4:e0:a6:8d:0d:d3) had associated successfully.
[I] Apr  2 11:32:43 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(e4:e0:a6:8d:0d:d3) set key done in WPA2/WPA2PSK.
[I] Apr  2 11:32:43 ndhcps: _WEBADMIN: DHCPDISCOVER received  from e4:e0:a6:8d:0d:d3.
[I] Apr  2 11:32:44 ndhcps: _WEBADMIN: making OFFER of 192.168.1.52 to e4:e0:a6:8d:0d:d3.
[I] Apr  2 11:32:45 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_SELECTING) for 192.168.1.52 from e4:e0:a6:8d:0d:d3.
[I] Apr  2 11:32:45 ndhcps: _WEBADMIN: sending ACK of 192.168.1.52 to e4:e0:a6:8d:0d:d3.
[I] Apr  2 11:32:59 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(e4:e0:a6:8d:0d:d3) had deauthenticated.
[I] Apr  2 11:33:21 ndm: UPnP::Manager: redirect and forward rules deleted: udp 8909.
[I] Apr  2 11:33:21 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:33:21 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:33:21 ndm: UPnP::Manager: redirect and forward rules deleted: tcp 8909.
[I] Apr  2 11:33:22 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:33:22 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:33:23 ndm: UPnP::Manager: redirect and forward rules deleted: udp 8909.
[I] Apr  2 11:33:24 ndm: UPnP::Manager: redirect and forward rules deleted: tcp 8909.
[I] Apr  2 11:33:25 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:33:25 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:33:26 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:33:26 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:33:38 ndm: kernel: usb 1-1: USB disconnect, device number 7
[I] Apr  2 11:33:38 ndm: kernel: option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[I] Apr  2 11:33:38 ndm: kernel: option 1-1:1.0: device disconnected
[I] Apr  2 11:33:38 ndm: kernel: option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[I] Apr  2 11:33:38 ndm: kernel: option 1-1:1.1: device disconnected
[I] Apr  2 11:33:38 ndm: kernel: wimax0: unregister 'huawei_ether' usb-ehci-platform-1, Huawei Ethernet Device
[I] Apr  2 11:33:38 ndm: Network::Interface::Usb: interface "UsbLte0" is unplugged.
[I] Apr  2 11:33:38 ndm: Network::Interface::Usb: "UsbLte0": device ID removed.
[W] Apr  2 11:33:38 ndm: Dhcp::Client: DHCP server is not responding.
[I] Apr  2 11:33:38 ndm: Network::Interface::IP: "UsbLte0": IP address cleared.
[I] Apr  2 11:33:38 ndhcpc: UsbLte0: NDM DHCP client stopped (exit status 0).
[I] Apr  2 11:33:39 upnp: shutting down MiniUPnPd
[I] Apr  2 11:33:39 ndm: Core::Server: client disconnected.
[I] Apr  2 11:33:49 ndm: kernel: usb 1-1: new high-speed USB device number 8 using ehci-platform
[I] Apr  2 11:33:49 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=14fe
[I] Apr  2 11:33:49 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Apr  2 11:33:49 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Apr  2 11:33:49 ndm: kernel: usb 1-1: SerialNumber: 0123456789ABCDEF
[I] Apr  2 11:33:49 ndm: kernel: scsi9 : usb-storage 1-1:1.0
[I] Apr  2 11:33:52 ndm: kernel: scsi 9:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[W] Apr  2 11:33:52 ndm: kernel: sr0: scsi-1 drive
[I] Apr  2 11:33:52 ndm: kernel: sr 9:0:0:0: Attached scsi CD-ROM sr0
[I] Apr  2 11:33:52 ndm: kernel: sr 9:0:0:0: Attached scsi generic sg0 type 5
[I] Apr  2 11:33:52 ndm: kernel: scsi 9:0:0:1: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:33:52 ndm: kernel: sd 9:0:0:1: Attached scsi generic sg1 type 0
[I] Apr  2 11:33:52 ndm: kernel: sd 9:0:0:1: [sda] Attached SCSI removable disk
[E] Apr  2 11:33:59 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Apr  2 11:33:59 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Apr  2 11:34:02 ndm: kernel: usb 1-1: USB disconnect, device number 8
[I] Apr  2 11:34:02 ndm: kernel: usb 1-1: new high-speed USB device number 9 using ehci-platform
[I] Apr  2 11:34:03 ndm: kernel: usb 1-1: New USB device found, idVendor=12d1, idProduct=1506
[I] Apr  2 11:34:03 ndm: kernel: usb 1-1: Product: HUAWEI_MOBILE
[I] Apr  2 11:34:03 ndm: kernel: usb 1-1: Manufacturer: HUAWEI_MOBILE
[I] Apr  2 11:34:03 ndm: kernel: option 1-1:1.0: GSM modem (1-port) converter detected
[I] Apr  2 11:34:03 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[I] Apr  2 11:34:03 ndm: kernel: option 1-1:1.1: GSM modem (1-port) converter detected
[I] Apr  2 11:34:03 ndm: kernel: usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[I] Apr  2 11:34:03 ndm: kernel: scsi10 : usb-storage 1-1:1.3
[I] Apr  2 11:34:03 ndm: kernel: scsi11 : usb-storage 1-1:1.4
[I] Apr  2 11:34:04 ndm: Network::Interface::Usb: interface "UsbLte0" is plugged (port 1).
[I] Apr  2 11:34:06 ndm: kernel: scsi 10:0:0:0: CD-ROM            HUAWEI   Mass Storage     2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:34:06 ndm: kernel: scsi 11:0:0:0: Direct-Access     HUAWEI   TF CARD Storage  2.31 PQ: 0 ANSI: 2
[I] Apr  2 11:34:06 ndm: kernel: sd 11:0:0:0: Attached scsi generic sg0 type 0
[I] Apr  2 11:34:06 ndm: kernel: sd 11:0:0:0: [sda] Attached SCSI removable disk
[W] Apr  2 11:34:06 ndm: kernel: sr0: scsi-1 drive
[I] Apr  2 11:34:06 ndm: kernel: sr 10:0:0:0: Attached scsi CD-ROM sr0
[I] Apr  2 11:34:06 ndm: kernel: sr 10:0:0:0: Attached scsi generic sg1 type 5
[I] Apr  2 11:34:08 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[I] Apr  2 11:34:11 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) had disassociated.
[E] Apr  2 11:34:13 ndm: FileSystem::Ext: failed to open "/dev/sda" device to mount.
[E] Apr  2 11:34:13 ndm: FileSystem::Repository: failed to create a new filesystem.
[I] Apr  2 11:34:26 ndm: Network::Interface::UsbLte: "UsbLte0": connection timeout.
[I] Apr  2 11:34:34 ndm: kernel: ADDRCONF(NETDEV_CHANGE): wimax0: link becomes ready
[I] Apr  2 11:34:34 ndm: Network::Interface::UsbLte: "UsbLte0": connection initialized.
[I] Apr  2 11:34:41 ndm: Network::Interface::UsbLte: "UsbLte0": connection established.
[I] Apr  2 11:34:45 ndhcpc: UsbLte0: NDM DHCP client (version 3.1.15) started.
[I] Apr  2 11:34:45 ndm: Dhcp::Client: configuring interface UsbLte0.
[I] Apr  2 11:34:45 ndm: Network::Interface::IP: "UsbLte0": IP address is 100.90.170.191/25.
[I] Apr  2 11:34:45 ndm: Dhcp::Client: obtained IP address 100.90.170.191/25.
[I] Apr  2 11:34:45 ndm: Dhcp::Client: interface "UsbLte0" is global, priority 400.
[I] Apr  2 11:34:45 ndm: Dhcp::Client: adding a default route via 100.90.170.129.
[I] Apr  2 11:34:45 ndm: Dhcp::Client: adding a host route to name server 10.52.129.36.
[I] Apr  2 11:34:45 ndm: Dhcp::Client: adding name server 10.52.129.36.
[I] Apr  2 11:34:45 ndm: Dns::Manager: name server 10.52.129.36 added, domain (default).
[I] Apr  2 11:34:45 ndm: Dhcp::Client: adding a host route to name server 10.52.129.56.
[I] Apr  2 11:34:45 ndm: Dhcp::Client: adding name server 10.52.129.56.
[I] Apr  2 11:34:45 ndm: Dns::Manager: name server 10.52.129.56 added, domain (default).
[I] Apr  2 11:34:45 ndm: Network::InterfaceFlusher: flushed UsbLte0 conntrack and route cache.
[I] Apr  2 11:34:45 ndm: kernel: wimax0: no IPv6 routers present
[I] Apr  2 11:34:47 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Apr  2 11:34:47 upnp: HTTP listening on port 43833
[I] Apr  2 11:34:47 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Apr  2 11:35:31 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(84:20:96:a9:12:ff) had been aged-out and disassociated.
[I] Apr  2 11:41:48 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) had associated successfully.
[I] Apr  2 11:41:48 wmond: WifiMaster0/AccessPoint0: (MT76x2) STA(98:01:a7:b6:a5:cb) set key done in WPA2/WPA2PSK.
[I] Apr  2 11:41:49 ndhcps: _WEBADMIN: DHCPREQUEST received (STATE_INIT) for 192.168.1.68 from 98:01:a7:b6:a5:cb.
[I] Apr  2 11:41:49 ndhcps: _WEBADMIN: sending ACK of 192.168.1.68 to 98:01:a7:b6:a5:cb.
[I] Apr  2 11:41:51 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:41:51 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:41:51 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:41:51 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:41:52 ndm: UPnP::Manager: redirect and forward rules deleted: udp 8909.
[I] Apr  2 11:41:53 ndm: UPnP::Manager: redirect and forward rules deleted: tcp 8909.
[I] Apr  2 11:41:54 ndm: UPnP::Manager: redirect rule added: udp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:41:54 ndm: UPnP::Manager: forward rule added: udp UsbLte0 -> 192.168.1.68:8909.
[I] Apr  2 11:41:55 ndm: UPnP::Manager: redirect rule added: tcp UsbLte0:8909 -> 192.168.1.68:8909.
[I] Apr  2 11:41:55 ndm: UPnP::Manager: forward rule added: tcp UsbLte0 -> 192.168.1.68:8909.
6 answers to this question
  • 1
У вас приоритет на мопеде 400, а у ISP 700. Для начала определитесь какое подключение вам важней...
26 минут назад, Mamay сказал:
Я ничего там не трогал и не менял, вставил модем и сделал быструю настройку. Что мне сделать нужно?
Edited by Кирилл куз
20 минут назад, Кирилл куз сказал:
Опишите вашу схему. Вы используете одновременно два подключения, читай провод и эфир? Отваливается интернет - слишком широкое понятие. Как, когда, при каких обстоятельствах...
1 час назад, Mamay сказал:
К роутеру подключен модем мегафона(напрямую без удлинителей), провод от роутера идет к SIP-телефону(подключен он правильно в желтое гнездо). Каждые 2-3 минуты отваливается полностью модем(как будто перезагружается). На данный момент 55 минут он работает нормально.
В 4/2/2018 в 14:45, Кирилл куз сказал:
Модем и правда отваливается и перезагружается.
Как у вас с качеством приема сигнала? Может питания не хватает модему?
