Установка DokuWiki на Keenetic
Решил запустить на Keenetic Omni II web server c DokuWiki.
Исходные данные:
1. Архив Entware нашел в этой теме
2. Установленные пакеты:
~ # opkg list-installed
busybox - 1.27.2-3c
dropbear - 2017.75-5
entware-release - 1.0-2
findutils - 4.6.0-1
glib2 - 2.55.1-1
grep - 2.26-1
ldconfig - 2.27-8
libattr - 20170915-1
libblkid - 2.30.2-2
libbz2 - 1.0.6-3
libc - 2.27-8
libcurl - 7.58.0-1
libffi - 3.2.1-3
libfreetype - 2.9-1
libgcc - 7.3.0-8
libiconv-full - 1.11.1-3
libintl-full - 0.19.8.1-1
libjpeg - 9a-1
liblua - 5.1.5-1
libmariadb - 5.5.58-1
libmbedtls - 2.6.0-1
libmount - 2.30.2-2
libncurses - 6.1-1
libncursesw - 6.1-1
libndm - 1.8.0-1
libopenssl - 1.0.2n-1b
libpcre - 8.41-2
libpng - 1.6.34-1
libpthread - 2.27-8
libreadline - 7.0-1
librt - 2.27-8
libslang2 - 2.3.1a-1
libssh2 - 1.8.0-1
libssp - 7.3.0-8
libstdcpp - 7.3.0-8
libuuid - 2.30.2-2
libxml2 - 2.9.7-1
locales - 2.27-8
mc - 4.8.20-1
ndmq - 1.0.2-3
nginx - 1.12.2-1
opkg - 2011-04-08-9c97d5ec-17b
opt-ndmsv2 - 1.0-10a
php7 - 7.2.2-1
php7-cgi - 7.2.2-1
php7-fastcgi - 7.2.2-1
php7-fpm - 7.2.2-1
php7-mod-ctype - 7.2.2-1
php7-mod-curl - 7.2.2-1
php7-mod-dom - 7.2.2-1
php7-mod-exif - 7.2.2-1
php7-mod-fileinfo - 7.2.2-1
php7-mod-gd - 7.2.2-1
php7-mod-gettext - 7.2.2-1
php7-mod-hash - 7.2.2-1
php7-mod-iconv - 7.2.2-1
php7-mod-json - 7.2.2-1
php7-mod-mbstring - 7.2.2-1
php7-mod-mysqli - 7.2.2-1
php7-mod-pdo - 7.2.2-1
php7-mod-pdo-mysql - 7.2.2-1
php7-mod-session - 7.2.2-1
php7-mod-simplexml - 7.2.2-1
php7-mod-sockets - 7.2.2-1
php7-mod-xml - 7.2.2-1
php7-mod-xmlreader - 7.2.2-1
php7-mod-xmlwriter - 7.2.2-1
php7-mod-zip - 7.2.2-1
terminfo - 6.1-1
zlib - 1.2.11-2
zoneinfo-asia - 2018c-1
zoneinfo-europe - 2018c-1
Мой nginx.conf
user  nobody;
worker_processes  1;
#error_log  /opt/var/log/nginx/error.log;
#error_log  /opt/var/log/nginx/error.log  notice;
#error_log  /opt/var/log/nginx/error.log  info;
#pid        /opt/var/run/nginx.pid;
events {
    worker_connections  64;
http {
    include       mime.types;
    default_type  application/octet-stream;
    #log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
    #                  '$status $body_bytes_sent "$http_referer" '
    #                  '"$http_user_agent" "$http_x_forwarded_for"';
    #access_log  /opt/var/log/nginx/access.log main;
    sendfile        on;
    #tcp_nopush     on;
    #keepalive_timeout  0;
    keepalive_timeout  65;
    #gzip  on;
    server {
        listen       192.168.1.1:81;
        server_name  doku.5.mykeenetic.kz www.doku.5.mykeenetic.kz;
        #server_name   192.168.1.1;
        autoindex off;
        client_max_body_size 15M;
        client_body_buffer_size 128k;
        index index.html index.htm index.php doku.php;
        root  /opt/share/nginx/html/dokuwiki;
        location / {
         try_files $uri $uri/ @dokuwiki;
        location ~ ^/lib.*\.(gif|png|ico|jpg)$ {
          expires 30d;
        location = /robots.txt  { access_log off; log_not_found off; }
        location = /favicon.ico { access_log off; log_not_found off; }
        location ~ /\.          { access_log off; log_not_found off; deny all; }
        location ~ ~$           { access_log off; log_not_found off; deny all; }
        location @dokuwiki {
          rewrite ^/_media/(.*) /lib/exe/fetch.php?media=$1 last;
          rewrite ^/_detail/(.*) /lib/exe/detail.php?media=$1 last;
          rewrite ^/_export/([^/]+)/(.*) /doku.php?do=export_$1&id=$2 last;
          rewrite ^/(.*) /doku.php?id=$1 last;
        location ~ \.php$ {
            fastcgi_pass   192.168.1.1:9200;
            fastcgi_index  index.php;
            fastcgi_param  SCRIPT_FILENAME  /scripts$fastcgi_script_name;
            #fastcgi_param  PATH_INFO        /scripts$fastcgi_script_name;  #necessary for URL rewrite
            include        fastcgi_params;
            fastcgi_intercept_errors        on;
            fastcgi_ignore_client_abort     off;
            fastcgi_connect_timeout 60;
            fastcgi_send_timeout 180;
            fastcgi_read_timeout 180;
            fastcgi_buffer_size 128k;
            fastcgi_buffers 4 256k;
            fastcgi_busy_buffers_size 256k;
            fastcgi_temp_file_write_size 256k;
        location ~ /(data|conf|bin|inc)/ {
          deny all;
        location ~ /\.ht {
          deny  all;
В результате веб сервер  и dokuwiki запускаются, но страницы грузятся без стилей, голые. Очень неудобно пользоваться. Вопрос в следующем, что я сделал не так или вообще не сделал? Подскажите где найти информацию. Предполагаю, что некорректно настроены права доступа к папкам dokuwiki, потому-что смог запустить сайт только после экспериментов с правами доступа к папке dokuwiki.
В 03.04.2018 в 19:14, boez сказал:
В результате веб сервер  и dokuwiki запускаются, но страницы грузятся без стилей, голые...
стиль у неё "спартанский".
...Подскажите где найти информацию...
на сайте проектов dokuwiki, nginx, php
... некорректно настроены права доступа...
совсем не настраивал (т.е., абсолютно, просто распаковал архив)
перестарались с конфигом. зачем надо было так усложнять? для домашнего пользования хватило б неск. правок дефолтного конфига nginx (хотя и с Вашим запустилось, ну-у, почти... сменил для php с порта прослушки на сокет, поменял порт сервера, поменял путь для root... ).
user  nobody;
worker_processes  1;
events {
http {
    include       mime.types;
    sendfile        on;
    #tcp_nopush     on;
    #gzip  on;
    server {
        listen       88;
#        server_name  doku.5.mykeenetic.kz www.doku.5.mykeenetic.kz;
        autoindex off;
        root  /opt/share/www;
        location / {
          expires 30d;
        location ~ \.php$ {
            fastcgi_pass   unix:/var/run/php-fcgi.sock;
          deny all;
        location ~ /\.ht {
          deny  all;
8 часов назад, TheBB сказал:
Да, я не программист ни в коем разе. Просто есть роутер и желание запустить свой сайт. )))  С правками дефолтного конфига у меня не получалось запустить приложение,  Nginx запускался.
Вот и нашел инструкцию https://www.nginx.com/resources/wiki/start/topics/recipes/dokuwiki/.
Проблемы с отображением стилей бывают видимо при несовместимости версий nginx+php+dokuwiki. Обсуждалось здесь
Снесу php7 и попробую на php5 запустить.
Подскажите какой комплект пакетов нужно установить? Может быть я здесь накосячил...
opkg install php7-fpm php7-mod-ctype php7-mod-curl php7-mod-dom \
php7-mod-exif php7-mod-fileinfo php7-mod-gd php7-mod-gettext php7-mod-hash \
php7-mod-iconv php7-mod-json php7-mod-mbstring php7-mod-mcrypt php7-mod-mysqli \
php7-mod-pdo-mysql php7-mod-session php7-mod-simplexml php7-mod-sockets \
php7-mod-xml php7-mod-xmlreader php7-mod-xmlwriter php7-mod-zip php7-fastcgi
Edited by boez
5 часов назад, boez сказал:
... Просто есть роутер и желание запустить свой сайт...
если "для дома, для семьи", то мне хватило нижеследующего конфига nginx (только ради тестирования). если для "выхода в свет", надо схему усложнять (постепенно, шаг за шагом).
user  nobody;
worker_processes  1;
events {
http {
    include       mime.types;
    sendfile        on;
    server {
        listen       81;
        location / {
            index  index.php index.html index.htm;
        #error_page  404              /404.html;
        # redirect server error pages to the static page /50x.html
        error_page   500 502 503 504  /50x.html;
        location = /50x.html {
            root   /opt/share/nginx/html;
        location ~ \.php$ {
... Снесу php7 и попробую на php5 запустить...
плохая идея, т.к. в Entware, php5 "выведен из строя". тогда стоит смотреть в сторону Debian.
... Подскажите какой комплект пакетов нужно установить? Может быть я здесь накосячил...
сойдёт. а, т.к. у меня уже стояла "доп. морда" (пакет "ext-ui-nginx-7"), ею и воспользовался, заменив конфиг на дефолтный и подправив его.
Установил пакет "ext-ui-nginx-7", конфиг взял ваш (последний) и вот, что выдает при запуске и нажатии на ту или иную кнопку кроме терминала, NDMS и справки:
5ac66c50b1670__doku_1.thumb.PNG.97102cc6c8bd7f8f99f72e02102c152f.PNG 5ac66c51eb1a3__doku_2.thumb.PNG.5faa51b065581b736fc7782cec4078cb.PNG
Папку с программой закинул сюда: /opt/share/www
На запрос http://192.168.1.1:81/doku.php получаю ответ как на втором скрине.
упс...  :) в файле `/opt/etc/init.d/S79php-fcgi` надо путь к сокету сменить, как в конфиге сервера nginx
ARGS="-b /var/run/php-fcgi.sock &"
или в конфиге сервера прописать правильный путь, как в файле `S79php-fcgi`, т.е.
fastcgi_pass   unix:/opt/var/run/php-fcgi.sock;
11 час назад, TheBB сказал:
Прописал. Не помогло.
Указал в конфиге конкретно путь до папки dokuwiki
location / {
            root   /opt/share/www/dokuwiki;
и здесь
 location ~ \.php$ {
После этого на запрос http://192.168.1.1:81/doku.php, открывается страничка, но без стилей.
Такое ощущение, что php не видит файловую структуру папок и файлов...
значит надо включать в php.ini логирование ошибок, если не включено, и смотреть вывод.
log_errors = On
error_log = /opt/var/log/php_errors.log
да и вывод ошибок сервера не помешает глянуть
3 часа назад, TheBB сказал:
Включил логирование ошибок и поменял обратно в конфиге адрес на:
. Лог по адресу /opt/var/log/php_errors.log не появился. Но теперь загружается Extended User Interface и работает.
страница DokuWiki загружается только если зайти по адресу http://192.168.1.1:81/dokuwiki/doku.php. Загружается также без стилей
Лог сервера
2018/04/06 07:29:31 [crit] 29173#0: *1 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /doku.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81"
2018/04/06 07:29:48 [crit] 29173#0: *1 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /addons/phpinfo.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81", referrer: "http://192.168.1.1:81/menu.html"
2018/04/06 07:38:45 [crit] 29173#0: *9 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /addons/phpinfo.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81", referrer: "http://192.168.1.1:81/menu.html"
2018/04/06 07:38:59 [crit] 29173#0: *9 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /doku.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81"
2018/04/06 07:44:53 [crit] 29173#0: *12 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /addons/phpinfo.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81", referrer: "http://192.168.1.1:81/menu.html"
2018/04/06 07:44:55 [crit] 29173#0: *12 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /addons/php.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81", referrer: "http://192.168.1.1:81/menu.html"
2018/04/06 07:45:16 [crit] 29173#0: *12 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /doku.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81"
2018/04/06 07:45:41 [crit] 29173#0: *12 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /doku.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81"
2018/04/06 07:45:43 [crit] 29173#0: *12 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /doku.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81"
2018/04/06 07:46:07 [notice] 562#0: signal process started
2018/04/06 07:46:15 [crit] 565#0: *1 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /addons/phpinfo.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81", referrer: "http://192.168.1.1:81/menu.html"
2018/04/06 07:46:26 [crit] 565#0: *1 connect() to unix:/opt/var/run/php-fcgi.sock failed (2: No such file or directory) while connecting to upstream, client: 192.168.1.19, server: , request: "GET /info.php HTTP/1.1", upstream: "fastcgi://unix:/opt/var/run/php-fcgi.sock:", host: "192.168.1.1:81"
2018/04/06 07:48:25 [notice] 1091#0: signal process started
2018/04/06 09:23:27 [emerg] 22126#0: invalid number of arguments in "fastcgi_pass" directive in /opt/etc/nginx/nginx.conf:35
2018/04/06 10:42:24 [notice] 7143#0: signal process started
2018/04/06 10:49:09 [notice] 8728#0: signal process started
2018/04/06 12:07:53 [notice] 26199#0: signal process started
2018/04/06 12:29:29 [notice] 31008#0: signal process started
2018/04/06 12:32:38 [notice] 31713#0: signal process started
2018/04/06 13:13:58 [notice] 8445#0: signal process started
Запущенные сервисы
Edited by boez
Как не старался, повторить не удалось (и стили, и картинки, и... всё на месте). Даже с php-fpm запустилось и работает. Какая ФС на флешке/диске?
тогда совсем "печально"... остаётся проверить в разных браузерах (с "обвесом" из расширений и дополнений и без оных) или "раскатать" систему заново, установить и настроить, и "запечатать" в архив для установки.
Удалось запустить программу, после того как снес все и выполнил только установку сервера и пакетов php7
php7-mod-xml php7-mod-xmlreader php7-mod-xmlwriter php7-mod-zip php7-fastcgi ext-ui-nginx-7
php7-mod-mcrypt не установился. Видимо его в комплекте нет.
Конфиг
user  nobody;
worker_processes  1;
events {
http {
    include       mime.types;
    sendfile        on;
    server {
        listen       81;
        location / {
            index  doku.php index.php index.html index.htm;
        location ~ \.php$ {
дополнительные настройки которые рекомендовались в соседних темах, не делал.
Правда работает dokuwiki на самых облегченных плагинах. С родным плагином все так же не загружаются стили. Думаю или "железо" не тянет или я чего то не допоставил из php
5ac8917eca6bf__doku_3.thumb.PNG.09f32e75878a3e91495e388a5f8900eb.PNG 5ac891800efe4__doku_4.thumb.PNG.e9d445ab99c65590cd35cc8819affe92.PNG
Edited by boez
в OpenWRT:
Цитата
php7: update to 7.2.0
Also drop mcrypt module as it's deprecated.
соотв., в Entware также.
Вот теперь, когда запустилось, можно и усложнять схему (постепенно).
33 минуты назад, TheBB сказал:
в OpenWRT:
Киньте пж-та ссылку на инструкцию как это сделать.
И еще вопрос, как ограничить доступ к Extended User Interface при подключении с "улицы" ? А то на одном порту сидят с doku и все на распашку.
вопрос совместного использования доп. "морды" с разл. движками не рассматривался. у ext-ui есть вкладка для включения защиты, но при таких настройках может не работать, т.к. конфиг состоит из 2-х частей (осн. лежит в /opt/etc/nginx/ доп. лежат в /opt/share/www/addons/passwd/)
 Share
