Владимир Большаков Posted April 10, 2020 Share Posted April 10, 2020 Подскажите возможно ли запустить скрипт на Python через OPKG? Если это можно чтобы было на автозапуске или cron. В этом деле новичок Quote Link to comment Share on other sites More sharing options...
Albram Posted April 11, 2020 Share Posted April 11, 2020 (edited) Да. Если Python установить, то можно. Скрытый текст BusyBox v1.31.1 () built-in shell (ash) ~ # opkg install python .... skipped .... ~ # opkg info python Package: python Version: 2.7.17-1 Depends: libc, libssp, librt, libpthread, python-light, python-ctypes, python-pydoc, python-multiprocessing, python-logging, python-codecs, python-sqlite3, python-gdbm, python-email, python-distutils, python-xml, python-compiler, python-db, python-openssl, python-decimal, python-unittest, python-ncurses Status: install user installed Section: lang Architecture: mipsel-3.4 Size: 914 Filename: python_2.7.17-1_mipsel-3.4.ipk Description: This package contains the (almost) full Python install. It's python-light + all other packages. Installed-Time: 1580893358 ~ # Edited April 11, 2020 by Albram Quote Link to comment Share on other sites More sharing options...
TheBB Posted April 12, 2020 Share Posted April 12, 2020 см., как пример, запуск deluge (python3) Quote Link to comment Share on other sites More sharing options...
