dancom Posted June 9, 2021 Share Posted June 9, 2021 On 6/8/2021 at 12:03 PM, al12s said: это хорошо уже не знаю куда копать, помогите советом. Несколько раз все переустановил по инструкциям (с этой ветки форума), но все равно на этапе установки netifaces ... error Мне помогло: opkg update opkg install gcc opkg install python3-dev Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 9, 2021 Share Posted June 9, 2021 "залечил вусмерть", остались пути, типа $(PKG_BUILD_DIR)/* Скрытый текст diff --git a/lang/python/python3/Makefile b/lang/python/python3/Makefile index ec581a0..d10ef68 100644 --- a/lang/python/python3/Makefile +++ b/lang/python/python3/Makefile @@ -4,7 +4,7 @@ # This is free software, licensed under the GNU General Public License v2. # See /LICENSE for more information. # -# Entware specific: CONFIGURE_ARGS+= --with-system-expat="$(STAGING_DIR)/opt" +# Entware specific: CONFIGURE_ARGS+= --with-system-expat="$(STAGING_DIR)/opt" TZPATH include $(TOPDIR)/rules.mk @@ -12,7 +12,7 @@ include $(TOPDIR)/rules.mk include ../python3-version.mk PKG_NAME:=python3 -PKG_RELEASE:=1 +PKG_RELEASE:=1b PKG_VERSION:=$(PYTHON3_VERSION).$(PYTHON3_VERSION_MICRO) PKG_SOURCE:=Python-$(PKG_VERSION).tar.xz @@ -145,6 +145,7 @@ DISABLE_BLUETOOTH:= \ CONFIGURE_ARGS+= \ --sysconfdir=/opt/etc \ --with-system-expat="$(STAGING_DIR)/opt" \ + --with-tzpath="/opt/share/zoneinfo:/usr/share/zoneinfo" \ --enable-optimizations \ --enable-shared \ --with-system-ffi \ @@ -281,6 +282,10 @@ define Py3Package/python3-base/install # This depends on being called before filespec is processed $(SED) 's|$(TARGET_AR)|ar|g;s|$(TARGET_CROSS)readelf|readelf|g;s|$(TARGET_CC)|gcc|g;s|$(TARGET_CXX)|g++|g' \ $(PKG_INSTALL_DIR)/opt/lib/python$(PYTHON3_VERSION)/_sysconfigdata.py + # XXX + $(SED) 's,$(STAGING_DIR),,g;s,$(TOOLCHAIN_DIR),/opt,g;s,$(STAGING_DIR_HOST),/opt,g; \ + s,-fmacro-prefix-map=$(PKG_BUILD_DIR)=Python-$(PKG_VERSION),,g' \ + $(PKG_INSTALL_DIR)/opt/lib/python$(PYTHON3_VERSION)/_sysconfigdata.py endef Py3Package/python3-light/install:=: diff --git a/lang/python/python3/files/python3-package-dev.mk b/lang/python/python3/files/python3-package-dev.mk index 4afe29e..8bf1a88 100644 --- a/lang/python/python3/files/python3-package-dev.mk +++ b/lang/python/python3/files/python3-package-dev.mk @@ -20,6 +20,11 @@ define Py3Package/python3-dev/install # This depends on being called before filespec is processed $(SED) 's|$(TARGET_AR)|ar|g;s|$(TARGET_CROSS)readelf|readelf|g;s|$(TARGET_CC)|gcc|g;s|$(TARGET_CXX)|g++|g' \ $(PKG_INSTALL_DIR)/opt/lib/python$(PYTHON3_VERSION)/config-$(PYTHON3_VERSION)/Makefile + # XXX + $(SED) 's,$(STAGING_DIR),,g;s,$(TOOLCHAIN_DIR),/opt,g;s,$(STAGING_DIR_HOST),/opt,g; \ + s,-fmacro-prefix-map=$(PKG_BUILD_DIR)=Python-$(PKG_VERSION),,g' \ + $(PKG_INSTALL_DIR)/opt/bin/python$(PYTHON3_VERSION)-config \ + $(PKG_INSTALL_DIR)/opt/lib/python$(PYTHON3_VERSION)/config-$(PYTHON3_VERSION)/Makefile endef $(eval $(call Py3BasePackage,python3-dev, \ Quote Link to comment Share on other sites More sharing options...
OlegOs Posted June 24, 2021 Share Posted June 24, 2021 Здравствуйте, пытаюсь из ha по ssh уводить в сон windows компы с OpenSSH подобно тому, как здесь предлагают - https://community.home-assistant.io/t/hibernate-and-wake-up-your-windows-pc/713/8 но не могу добиться работы из консоли entware команды типа ssh user@comp rundll32 powrprof.dll,SetSuspendState 0,1,0 по ключу без пароля (по паролю работает) OpenSSH сервер на винде настроил, открытый ключ в authorized_keys прописал, всё сделал согласно - https://winitpro.ru/index.php/2019/10/17/windows-openssh-server/ и https://winitpro.ru/index.php/2019/11/13/autentifikaciya-po-ssh-klyucham-v-windows/ с мобильного клиента захожу по ключу нормально и команда отрабатывает, комп засыпает, а с entware не даёт подключиться. пытался явно указывать в команде файл с закрытым ключом, тоже не прокатывает. Подскажите пожалуйста как настроить подключение по ssh по ключу без пароля из entware. Задача обратная обсуждаемой здесь - Скрытый текст ~ # opkg install openssh-keygen Installing openssh-keygen (8.5p1-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/openssh-keygen_8.5p1-1_mipsel-3.4.ipk Configuring openssh-keygen. ~ # ssh-keygen -t rsa Generating public/private rsa key pair. Enter file in which to save the key (/opt/root/.ssh/id_rsa): Created directory '/opt/root/.ssh'. Enter passphrase (empty for no passphrase): Enter same passphrase again: Your identification has been saved in /opt/root/.ssh/id_rsa Your public key has been saved in /opt/root/.ssh/id_rsa.pub The key fingerprint is: ...... ~ # ssh user@comp ssh: Connection to user@comp exited: No auth methods could be used. Quote Link to comment Share on other sites More sharing options...
sergeyk Posted June 24, 2021 Share Posted June 24, 2021 4 минуты назад, Олег Осипов сказал: но не могу добиться работы из консоли entware команды типа ssh user@comp rundll32 powrprof.dll,SetSuspendState 0,1,0 по ключу без пароля (по паролю работает) Попробуйте команду "rundll32 powrprof.dll,SetSuspendState 0,1,0" взять в кавычки. Quote Link to comment Share on other sites More sharing options...
OlegOs Posted June 24, 2021 Share Posted June 24, 2021 Из Enyware не подключается даже вообще без команды когда на сервере убираешь подключение по паролю ~ # ssh user@comp ssh: Connection to user@comp exited: No auth methods could be used. Quote Link to comment Share on other sites More sharing options...
sergeyk Posted June 24, 2021 Share Posted June 24, 2021 2 минуты назад, Олег Осипов сказал: Из Enyware не подключается даже вообще без команды когда на сервере убираешь подключение по паролю Запускайте тогда ssh -vvv ... для отладки. Quote Link to comment Share on other sites More sharing options...
OlegOs Posted June 24, 2021 Share Posted June 24, 2021 Не понимает такой ключик 🙂 ~ # ssh -vvv user@comp WARNING: Ignoring unknown option -v WARNING: Ignoring unknown option -v WARNING: Ignoring unknown option -v Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 24, 2021 Share Posted June 24, 2021 29 минут назад, Олег Осипов сказал: Не понимает такой ключик 🙂 dropbear? А если попробовать openssh? Quote Link to comment Share on other sites More sharing options...
alex1 Posted June 24, 2021 Share Posted June 24, 2021 добрый день, пытаюсь сделать уведомление на ios с фотографией с камеры, часть отвечающую за snapshot реализовал, фото сохраняться, но не могу понять, куда именно сохранять фото для последующего вывода в уведомлении на iphone/ Может кто-то это уже реализовал, подскажите пожалуйста. Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 24, 2021 Share Posted June 24, 2021 bump to 2021.6.6 Quote Link to comment Share on other sites More sharing options...
OlegOs Posted June 24, 2021 Share Posted June 24, 2021 53 минуты назад, TheBB сказал: dropbear? А если попробовать openssh? Да а как попробовать openssh? Клиент не ставится Скрытый текст ~ # opkg install openssh-client Installing openssh-client (8.5p1-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/openssh-client_8.5p1-1_mipsel-3.4.ipk Collected errors: * check_data_file_clashes: Package openssh-client wants to install file /opt/bin/scp But that file is already provided by package * dropbear * check_data_file_clashes: Package openssh-client wants to install file /opt/bin/ssh But that file is already provided by package * dropbear * opkg_install_cmd: Cannot install package openssh-client. Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 24, 2021 Share Posted June 24, 2021 1 час назад, Олег Осипов сказал: Клиент не ставится opkg install --force-overwrite ... Quote Link to comment Share on other sites More sharing options...
OlegOs Posted June 24, 2021 Share Posted June 24, 2021 53 минуты назад, TheBB сказал: opkg install --force-overwrite ... Спасибо огромное, всё заработало с OpenSSH !!! Спасибо за обновление, удачно обновилось всё !!! Quote Link to comment Share on other sites More sharing options...
al12s Posted June 29, 2021 Share Posted June 29, 2021 В 24.06.2021 в 14:40, alex1 сказал: добрый день, пытаюсь сделать уведомление на ios с фотографией с камеры, часть отвечающую за snapshot реализовал, фото сохраняться, но не могу понять, куда именно сохранять фото для последующего вывода в уведомлении на iphone/ Может кто-то это уже реализовал, подскажите пожалуйста. Добрый день, присоединяюсь к вопросу. Но не совсем по этой теме, интересует в какую папку можно положить изображение и потом его открыть через http://192.168.1.xxx:8123/, в интернете много информации по пути /config/www, но в реализации keenetic такого пути нет, перепробовал множество папок и урлов, ничего не выходит. Прошу помощи. Заранее спасибо. Quote Link to comment Share on other sites More sharing options...
al12s Posted June 29, 2021 Share Posted June 29, 2021 В 09.06.2021 в 13:14, dancom сказал: Мне помогло:opkg update opkg install gccopkg install python3-dev Спасибо, помогло, с первого раза только по вашим командам не вышло, добаивил еще команду source /opt/bin/gcc_env.sh и все завелось! Quote Link to comment Share on other sites More sharing options...
ajs Posted June 29, 2021 Share Posted June 29, 2021 34 минуты назад, al12s сказал: информации по пути /config/www /config - папка в которой лежат все ваши yaml файлы конфигурации, без нее НА не работает, там же лежит база и лог /www - так же штатная папка в ней лежат все расширения, фотки пользователей и тп Quote Link to comment Share on other sites More sharing options...
al12s Posted July 1, 2021 Share Posted July 1, 2021 (edited) В 29.06.2021 в 10:04, ajs сказал: /config - папка в которой лежат все ваши yaml файлы конфигурации, без нее НА не работает, там же лежит база и лог /www - так же штатная папка в ней лежат все расширения, фотки пользователей и тп У меня Keenetic Ultra. У меня этих папок нет Edited July 1, 2021 by al12s Quote Link to comment Share on other sites More sharing options...
ajs Posted July 1, 2021 Share Posted July 1, 2021 14 минуты назад, al12s сказал: У меня этих папок нет Как нет? Скриншот с папки /config , то что нет в ней www то ее можно и создать... 1 Quote Link to comment Share on other sites More sharing options...
al12s Posted July 1, 2021 Share Posted July 1, 2021 1 час назад, ajs сказал: Как нет? Скриншот с папки /config , то что нет в ней www то ее можно и создать... Скриншот с папки /opt/var/lib/homeassistant, видимо она и есть config? именно дословно название папки "config" у меня нет. Создал в этой папке /opt/var/lib/homeassistant папку www, скопировал в нее изображение. Пробую открыть http://192.168.1.ххх:8123/config/www/test.jpg, открывается левое меню и все Quote Link to comment Share on other sites More sharing options...
immya Posted July 1, 2021 Share Posted July 1, 2021 (edited) 42 минуты назад, al12s сказал: Скриншот с папки /opt/var/lib/homeassistant, видимо она и есть config? именно дословно название папки "config" у меня нет. Создал в этой папке /opt/var/lib/homeassistant папку www, скопировал в нее изображение. Пробую открыть http://192.168.1.ххх:8123/config/www/test.jpg, открывается левое меню и все http://192.168.1.ххх:8123/local/test.jpg Edited July 1, 2021 by immya 2 Quote Link to comment Share on other sites More sharing options...
al12s Posted July 1, 2021 Share Posted July 1, 2021 12 минуты назад, immya сказал: http://192.168.1.ххх:8123/local/test.jpg ОГРОМНОЕ СПАСИБО!!! Заработало Quote Link to comment Share on other sites More sharing options...
ajs Posted July 1, 2021 Share Posted July 1, 2021 2 часа назад, al12s сказал: Заработало Надо просто прочесть немного документации, там это описано ... Quote Link to comment Share on other sites More sharing options...
TheBB Posted July 11, 2021 Share Posted July 11, 2021 (edited) !!! ВНИМАНИЕ !!! Рекомендую воздержаться от обновления пакетов "python" (фиксики уже в пути...) --- bump to 2021.7.1 Edited July 11, 2021 by TheBB upd Quote Link to comment Share on other sites More sharing options...
OlegOs Posted July 12, 2021 Share Posted July 12, 2021 TheBB, спасибо за обновление, обновился удачно, полёт нормальный ! Quote Link to comment Share on other sites More sharing options...
TheBB Posted July 15, 2021 Share Posted July 15, 2021 bump to 2021.7.2 Quote Link to comment Share on other sites More sharing options...
OlegOs Posted July 16, 2021 Share Posted July 16, 2021 TheBB, спасибо за обновление, обновился удачно, всё работает ! Quote Link to comment Share on other sites More sharing options...
TheBB Posted July 19, 2021 Share Posted July 19, 2021 bump to 2021.7.3 Quote Link to comment Share on other sites More sharing options...
OlegOs Posted July 20, 2021 Share Posted July 20, 2021 TheBB, спасибо, обновился удачно ! Интересно, кто-нибудь ставил в HA на нашем устройстве MariaDB вместо дефолтного SQLite? Имеет ли смысл? Хватит ли ресурсов? И будет ли быстрее? 1 Quote Link to comment Share on other sites More sharing options...
TheBB Posted July 20, 2021 Share Posted July 20, 2021 Быстрее вряд ли будет, т.к. "машка" нагружает сильнее, но ресурсов должно хватить. 1 Quote Link to comment Share on other sites More sharing options...
al12s Posted July 20, 2021 Share Posted July 20, 2021 (edited) обновился без ошибок, полет нормальный. Спасибо. Edited July 20, 2021 by al12s 1 Quote Link to comment Share on other sites More sharing options...
