PriSonerS61 Posted January 2 Share Posted January 2 In sstp vpn, it writes bridge0 instead of the home segment https://ibb.co/71XMKcn @eralde 2 Quote Link to comment Share on other sites More sharing options...
0 eralde Posted January 2 Share Posted January 2 Thank you for the report. We'll fix it in the next 3.8 build. 2 Quote Link to comment Share on other sites More sharing options...
0 KYTECHNGAMING Posted January 4 Share Posted January 4 is it same? https://prnt.sc/2617auj Quote Link to comment Share on other sites More sharing options...
0 eralde Posted January 5 Share Posted January 5 14 часа назад, yerebakan сказал: is it same? https://prnt.sc/2617auj There are changes in the output of every RCI resource (command) in the 3.8.x firmware. RCI resource output should not contain interface aliases ("Home", "Guest", "ISP", ...). It was requested by developers working on the web UI (especially me), since it simplifies the web UI code. We'll need some time to fix bugs caused by that change. This change however should not affect the telnet/SSH CLI output. Quote Link to comment Share on other sites More sharing options...
0 KYTECHNGAMING Posted January 5 Share Posted January 5 9 hours ago, eralde said: There are changes in the output of every RCI resource (command) in the 3.8.x firmware. RCI resource output should not contain interface aliases ("Home", "Guest", "ISP", ...). It was requested by developers working on the web UI (especially me), since it simplifies the web UI code. We'll need some time to fix bugs caused by that change. This change however should not affect the telnet/SSH CLI output. I got it, I got some information from Keenetic TR R&D about the arrangement of layer names. It was in my support case about deleting that PPPOE description on DSL connections. 🙏💙🤞 Quote Link to comment Share on other sites More sharing options...
PriSonerS61
@eralde
4 answers to this question
