[Giga KN-1011] After firmware upgrading to 3.7.3 Samsung Galaxy S8 Plus doesn't connect to 5 GHz wifi
Posted (edited)
If I add Samsung S8+ to Registered devices and limit its connection to 5GHz only, it can't connect.
At the previous version (3.7.2) all worked fine.
Other my devices work fine now (Samsung S21, Samsung TV). I have problem with Samsung S8+ only. Rebooting didn't help.
Edited by happy_developer
  • Need more info 2
11 answers to this question
Posted
5 hours ago, KYTECHNGAMING said:
Which 5ghz channel are you having this problem on?
Does it automatically connect at 2.4ghz?
Yes.  It automatically connect at 2.4ghz.
If I forcibly change it to 5ghz in "Registered devices" section. smartphone can't connect.
At the previous versions (3.7.2, 3.7.1) all worked fine.
Posted
5 hours ago, admin said:
Please try 3.8 (Dev) branch, and attach self-test if still have a problem.
I've tried and now I can't connect to 5GHz with my Samsung Galaxy S21 also (
I've rolled back to 3.7.3 and it did't help. Now I can't connect to 5GHz wifi. Only my Samsung TV is connected via 5Gh now.
Self-test of 3.8 attached.
self-test_KN-1011_draft_3.08.A.6.0-0_router_2022-02-28T17-55-19.856Z.txt
Posted
After several attempts, I decided to turn off the router, wait a few seconds and turn it back on. It helped with Samsung S21.
I will check Samsung S8+ in 3 hours. I don't have it right now.
Posted
I am experiencing a similar situation. my device is peak dsl and i am using 160mhz active.
I don't have manual 5ghz connection settings for devices.
DFS 104 108 112 are the channels that I have observed problems in general.
I don't have much problem with DFS 100 or 52 channel.
We follow up with Keenetic TR via ticket. #575074
Posted
I've just checked my self-test files. As I can see, during the troubles my 5GHz wifi channel was 149. It looks like that was the reason for the problem. Thanks a lot!
