  • 1
4.0.14 постоянное сообщение changed "link" layer state "pending" to "running" и ошибка в таблице марщрутизации профиля
vasek00
4.0.14 настроенный wireguard клиент для выхода в интернет (в нем один cloudflare warp). В настройках прописан DNS 192.168.130.101 сам роутер AdGuardHome, весь лог забит сообщениями, "Проверка активности" стоит 240 стояло 120/30 в данном подключение думаю оно по барабану какое, "ip global 65434".  Есть созданный профиль с одним только данным подключением.
[I] Mar 25 10:57:15 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Mar 25 10:57:15 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 10:57:15 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 10:57:15 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 10:57:15 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 10:57:15 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Mar 25 10:57:15 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
[I] Mar 25 10:57:15 ndm: Core::Syslog: last message repeated 3 times.
[I] Mar 25 11:00:18 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Mar 25 11:00:18 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Mar 25 11:00:18 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Mar 25 11:00:18 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted.
[I] Mar 25 11:01:21 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Mar 25 11:01:21 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 11:01:21 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 11:01:21 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 11:01:21 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 11:01:21 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Mar 25 11:01:21 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
[I] Mar 25 11:01:21 ndm: Core::Syslog: last message repeated 3 times.
[I] Mar 25 11:04:25 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Mar 25 11:04:25 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Mar 25 11:04:25 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Mar 25 11:04:25 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted.
[I] Mar 25 11:05:28 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Mar 25 11:05:28 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 11:05:28 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 11:05:28 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 11:05:28 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 08:17:45 ndm: Core::Syslog: last message repeated 3 times.
[I] Mar 25 08:20:55 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Mar 25 08:20:55 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Mar 25 08:20:55 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Mar 25 08:20:55 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted.
[I] Mar 25 08:21:52 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Mar 25 08:21:52 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 08:21:52 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 08:21:52 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 25 08:21:52 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Mar 25 08:21:52 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Mar 25 08:21:52 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
[I] Mar 25 08:21:52 ndm: Core::Syslog: last message repeated 3 times.
[I] Mar 25 08:24:21 ndm: Netfilter::Util::Conntrack: flushed 99 IPv4 connections.
Вопрос это просто лишняя информация в логе или что-то с созданным профилем происходит, так как в нем только один активный интерфейс Wireguard0 и для него может быть "adding default route via Wireguard0/removing default route via Wireguard0"
И для справки IP6, хотя не где не чего для него не настраивал.
Edited by vasek00
7 answers to this question
@vasek00 могу предположить, что эти сообщения связаны с новым механизмом определения состояния интерфейсов:
У меня стоит 4.0 Alpha 14. Замечал их в логе, но не обращал внимание. Они появляются даже при изменении состояния Ethernet портов. Например, если отключить и заново вставить в порт Ethernet-кабель от компьютера:
[I] Mar 25 18:09:11 ndm: Network::Interface::Switch: "GigabitEthernet0/0": switch link down at port 1.
[I] Mar 25 18:09:11 ndm: Network::Interface::Base: "GigabitEthernet0/0": "ethernet" changed "link" layer state "running" to "pending".
[I] Mar 25 18:09:14 ndm: Network::Interface::Switch: "GigabitEthernet0/0": switch link up at port 1 (1000FD/AN).
[I] Mar 25 18:09:14 ndm: Network::Interface::Base: "GigabitEthernet0/0": "ethernet" changed "link" layer state "pending" to "running".
Posted (edited)
Да но тут еще
добавить и удалить default -> как сказал выше данный интерфейс у меня в созданном профиле.
и тут не 3ceк
Edited by vasek00
Posted (edited)
Что интересно - создал еще один профиль, так же создал в нем еще один wireguard (Proton) он один канал, клиента не помещал в него. В итоге никаких лишних записей по нему нет
лог чистый по данному интерфейсу, в отличие от
[I] Mar 26 05:37:33 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Mar 26 05:37:33 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 05:37:33 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 05:37:33 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted.
[I] Mar 26 05:38:37 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Mar 26 05:38:37 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 26 05:38:37 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Mar 26 05:38:37 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 26 05:38:37 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Mar 26 05:38:37 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Mar 26 05:38:37 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
[I] Mar 26 05:38:37 ndm: Core::Syslog: last message repeated 3 times.
[I] Mar 26 06:06:18 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Mar 26 06:06:18 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 06:06:18 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 06:06:18 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted.
[I] Mar 26 06:07:16 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Mar 26 06:07:16 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 26 06:07:16 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Mar 26 06:07:16 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 26 06:07:16 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Mar 26 06:07:16 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Mar 26 06:07:16 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
[I] Mar 26 06:07:16 ndm: Core::Syslog: last message repeated 3 times.
[I] Mar 26 06:10:25 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Mar 26 06:10:25 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 06:10:25 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 06:10:25 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted.
[I] Mar 26 07:29:12 ndm: Core::Syslog: last message repeated 3 times.
[I] Mar 26 07:32:15 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
[I] Mar 26 07:32:15 ndm: Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 07:32:15 ndm: Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
[I] Mar 26 07:32:15 ndm: Dns::Manager: name server 192.168.130.101, domain (default) deleted.
[I] Mar 26 07:33:19 ndm: Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
[I] Mar 26 07:33:19 ndm: Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 26 07:33:19 ndm: Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
[I] Mar 26 07:33:19 ndm: Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
[I] Mar 26 07:33:19 ndm: Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
[I] Mar 26 07:33:19 ndm: Dns::Manager: name server 192.168.130.101 added, domain (default).
[I] Mar 26 07:33:19 ndm: Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
[I] Mar 26 07:33:19 ndm: Core::Syslog: last message repeated 3 times.
ip policy Policy0
    description Cloud
    permit global Wireguard0
    no permit global Wireguard4
    no permit global PPPoE0
    no permit global GigabitEthernet0/Vlan2
ip policy Policy2
    description A
    no permit global GigabitEthernet0/Vlan9
    no permit global Wireguard0
ip hotspot
    host КЛИЕНТ1:e2 permit
    host КЛИЕНТ1:e2 policy Policy0
    host КЛИЕНТ1:e2 priority 6
Похоже, после появления/включения клиента в данном профиле где Wireguard0 один и он default данные записи пропадают.
В итоге получаю = отличие двух профилей в которых Wirwguard0 - активен и есть клиент (тут важно включен он или нет) и Wireguard4 - активен но нет клиентов.
Edited by vasek00
Posted (edited)
Ну вот и отловил данный - баг или не баг.
1. Убираю клиента из профиля Policy0 (Wireguard0) и помещаю его в профиль Policy2 (Wireguard3), т.е. КЛИЕНТА В ПРОФИЛЕ Policy0 нет.
2. Дожидаюсь данной описанной выше ошибки и в итоге имею такое поведение в таблице маршрутизация для данного Policy0
Мар 26 10:02:37 ndm Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
Мар 26 10:02:37 ndm Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 65434.
Мар 26 10:02:37 ndm Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
Мар 26 10:02:37 ndm Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 65434.
Мар 26 10:02:37 ndm Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
Мар 26 10:02:37 ndm Dns::Manager: name server 192.168.130.101 added, domain (default).
Мар 26 10:02:37 ndm Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
Мар 26 10:02:37 ndm Core::Syslog: last message repeated 3 times.
смотрим что в реале
(Профиль Policy0)
~ # ip ro show table 42
default dev nwg0  scope link
192.168.130.101 dev nwg0  scope link
10.10.10.0/24 dev eth2.9  scope link
**** 192.168.130.101 dev nwg0  scope link *** ее тут нет
~ # date
Sun Mar 26 07:02:15 UTC 2023 *** тут нужно +3 часа
~ # date
Sun Mar 26 07:02:25 UTC 2023
~ # date
Sun Mar 26 07:02:33 UTC 2023
192.168.130.101 dev nwg0  scope link *** появился
Edited by vasek00
Есть связка профиля (таблица маршрутов) и маркировки пакетов. Маркировка пакетов привязана к активности клиента, т.е. его нет то нет и правил маркировки, он клиент появился и как итог появилась и маркировка для него.
Возможно что-то забыли убрать так как ранее 4.0.13 по моему этого не видел в логах.
4.0.18 не чего не исправлено.
Апр 17 08:42:47 ndm Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
Апр 17 08:42:47 ndm Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
Апр 17 08:42:47 ndm Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
Апр 17 08:43:50 ndm Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "pending" to "running".
Апр 17 08:43:50 ndm Network::Interface::Ip: "Wireguard0": interface "Wireguard0" is global, priority 62346.
Апр 17 08:43:50 ndm Network::Interface::Ip: "Wireguard0": adding default route via Wireguard0.
Апр 17 08:43:50 ndm Network::Interface::Ip6: "Wireguard0": interface "Wireguard0" is global, priority 62346.
Апр 17 08:43:50 ndm Network::Interface::Ip6: "Wireguard0": adding default route via Wireguard0.
Апр 17 08:43:50 ndm Dns::Manager: name server 192.168.130.101 added, domain (default).
Апр 17 08:43:50 ndm Dns::InterfaceSpecific: "Wireguard0": adding a host route to name server 192.168.130.101.
Апр 17 08:43:50 ndm Dns::InterfaceSpecific: "Wireguard0": host route for name server 192.168.130.101 added.
Апр 17 08:46:54 ndm Network::Interface::Base: "Wireguard0": "wireguard" changed "link" layer state "running" to "pending".
Апр 17 08:46:54 ndm Network::Interface::Ip: "Wireguard0": removing default route via Wireguard0.
Апр 17 08:46:54 ndm Network::Interface::Ip6: "Wireguard0": removing default route via Wireguard0.
ip dhcp host хх:хх:хх:хх:хх:e2 192.168.130.2
host хх:хх:хх:хх:хх:e2 policy Policy0
ip policy Policy0
    description Cloud
Повторюсь если клиент не в сети, то логи заполнены тем что выше, при подключении клиента лог.чистый. Ранее такого не было до 4.0.14 при тех же настройках.
Posted (edited)
4.0.19 все по старому. После включения клиента и если долго не работает он (страницы не просматривает) то лог так же забит сообщениями.
Есть дискомфорт при включение клиента и после его долгого тайм аута.
Edited by vasek00
