avn Posted September 20, 2023 Share Posted September 20, 2023 Выборочный роутинг можно сделать через REDIRECT Скрытый текст /opt/etc/ndm/netfilter.d/10n-ss4.sh #!/bin/sh [ "$type" != "iptables" ] && exit 0 [ "$table" != "nat" ] && exit 0 ip4t() { if ! iptables -C "$@" &>/dev/null; then iptables -A "$@" || exit 0 fi } # V2Ray ip4t PREROUTING -t nat -i br0 -p tcp -m set --match-set unblock4-ssp dst -j REDIRECT --to-port 9171 ip4t PREROUTING -t nat -i br0 -p udp -m set --match-set unblock4-ssp dst -j REDIRECT --to-port 9171 exit 0 /opt/etc/ndm/netfilter.d/10n-ss6.sh #!/bin/sh [ "$type" != "ip6tables" ] && exit 0 [ "$table" != "nat" ] && exit 0 ip6t() { if ! ip6tables -C "$@" &>/dev/null; then ip6tables -A "$@" || exit 0 fi } # V2Ray ip6t PREROUTING -t nat -i br0 -p tcp -m set --match-set unblock6-ssp dst -j REDIRECT --to-port 9171 ip6t PREROUTING -t nat -i br0 -p udp -m set --match-set unblock6-ssp dst -j REDIRECT --to-port 9171 exit 0 Конфиг /opt/etc/v2ray/common.json. Ключевые слова redirect и dokodemo-door { "inbounds": [ { "listen": "::", "port": 1082, "protocol": "socks", "settings": { "network": "tcp", "auth": "noauth" }, "sniffing": { "enabled": true, "destOverride": [ "http", "tls", "quic" ] }, "tag": "socks" }, { "listen": "::", "port": 9171, "protocol": "dokodemo-door", "settings": { "network": "tcp,udp", "followRedirect": true }, "sniffing": { "enabled": true, "destOverride": [ "http", "tls", "quic" ] }, "tag": "redirect" } ], "outbounds": [ { "protocol": "freedom", "settings": {}, "streamSettings": {}, "tag": "direct" }, { "protocol": "blackhole", "settings": {}, "streamSettings": {}, "tag": "blocked" } ], "routing": { "domainStrategy": "IPIfNonMatch", "rules": [ { "type": "field", "inboundTag": [ "socks", "redirect" ], "outboundTag": "proxy-vless-grpc-reality" } ] } } 3 2 Quote Link to comment Share on other sites More sharing options...
artem_annihilator Posted September 20, 2023 Share Posted September 20, 2023 17 часов назад, Skrill0 сказал: Доброго Вам времени суток! Попробуйте обновленную конфигурацию routing. В ней все соединения, что не указаны в direct — будут открываться через VPS. Если необходимо, чтобы через VPS открывались только некоторые сайты, а остальные через direct можно использовать альтернативную конфигурацию Показать содержимое // Настройка маршрутизации { "routing": { "domainStrategy": "IPIfNonMatch", "rules": [ // Настройка черного списка { "inboundTag": ["socks-in"], "domain": [ "ext:geosite_v2fly.dat:category-ads-all", "google-analytics", // Могут быть проблемы с сервисами Google. Нужны тесты "analytics.yandex" // Могут быть проблемы с сервисами Yandex. Нужны тесты ], "outboundTag": "block", "type": "field" }, // Блокируем соединение по уязвимым UDP портам { "inboundTag": ["socks-in"], "network": "udp", "port": "135, 137, 138, 139", "outboundTag": "block", "type": "field" }, // Настройка подключений через VPS с помощью доменных имен { "inboundTag": ["socks-in"], "domain": [ "speedtest.net", "strava.com", "ext:geosite_antifilter.dat:antifilter-community", "ext:geosite_v2fly.dat:openai", "ext:geosite_v2fly.dat:paypal", "ext:geosite_v2fly.dat:ebay", "ext:geosite_v2fly.dat:facebook", "ext:geosite_v2fly.dat:instagram" ], "outboundTag": "proxy", "type": "field" }, // Настройка подключений через VPS с помощью IP { "inboundTag": ["socks-in"], "ip": [ "ext:geoip_antifilter.dat:antifilter-community", "ext:geoip_antifilter.dat:antifilter", "ext:geoip_v2fly.dat:facebook", "ext:geoip_v2fly.dat:twitter" ], "outboundTag": "proxy", "type": "field" }, { "inboundTag": ["socks-in"], "outboundTag": "direct", "type": "field" } ] } } Ещё раз добрый вечер Конфиг роутинга к сожалению не помог, strava.com так же не открывается. Прокси подключение смогу протестить только в выходные Quote Link to comment Share on other sites More sharing options...
bigpu Posted September 20, 2023 Share Posted September 20, 2023 8 минут назад, artem_annihilator сказал: strava.com так же не открывается. добавил к себе в конфиг вручную - открывается без проблем, так же как и через GeoSite: Скрытый текст 1 Quote Link to comment Share on other sites More sharing options...
artem_annihilator Posted September 21, 2023 Share Posted September 21, 2023 9 часов назад, bigpu сказал: добавил к себе в конфиг вручную - открывается без проблем, так же как и через GeoSite: Показать содержимое Хм, видимо я что-то неправильно делаю. Можете пожалуйста отправить ваши конфиги роутинга, можно тут или в личку Quote Link to comment Share on other sites More sharing options...
Marassa Posted September 21, 2023 Share Posted September 21, 2023 Задам ещё один тупой теоретический вопрос, чтоб пазл в голове окончательно сложился. Понятно, что Xray умеет гибко маршрутизировать трафик внутри себя. А как и почему этот трафик изначально попадает в Xray? Нужно в явном виде в настройках роутера назначить некий приоритет подключению Xray? Почему-то не вижу в документации явного указания на это. 1 Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 21, 2023 Author Share Posted September 21, 2023 1 час назад, Marassa сказал: Задам ещё один тупой теоретический вопрос, чтоб пазл в голове окончательно сложился. Понятно, что Xray умеет гибко маршрутизировать трафик внутри себя. А как и почему этот трафик изначально попадает в Xray? Нужно в явном виде в настройках роутера назначить некий приоритет подключению Xray? Почему-то не вижу в документации явного указания на это. Доброго Вам утра! Есть несколько способов направить трафик на Xray. Самый простой — прокси-клиент от Keenetic. Тогда схема подключения выглядит таким образом Скрытый текст Можно также направить соединение с помощью iptables, как в этом посте описывал @avn Или использовать tproxy. 2 Quote Link to comment Share on other sites More sharing options...
Marassa Posted September 21, 2023 Share Posted September 21, 2023 9 минут назад, Skrill0 сказал: Есть несколько способов направить трафик на Xray. Самый простой — прокси-клиент от Keenetic То есть для работы Xray по самому простому способу необходимо поставить/включить компонент прошивки "Прокси-клиент", который по умолчанию выключен и который позволит создать новое подключение/интерфейс через Xray, и потом в явном виде в настройках кинетика направить трафик на это новое подключение? И тогда я могу использовать, например Static routes, чтобы какой-то трафик направлять в Xray, а какой-то пускать вообще мимо Xray сразу к провайдеру? 14 минуты назад, Skrill0 сказал: Можно также направить соединение с помощью iptables, как в этом посте описывал @avn Или использовать tproxy. Тогда необходимо дополнительно ставить пакет iptables через entware? А сам по себе Xray, получается, не использует iptables, а использует для маршрутизации какой-то свой встроенный проприетарный механизм? 1 Quote Link to comment Share on other sites More sharing options...
bigpu Posted September 21, 2023 Share Posted September 21, 2023 30 минут назад, Marassa сказал: То есть для работы Xray по самому простому способу необходимо поставить/включить компонент прошивки "Прокси-клиент", который по умолчанию выключен и который позволит создать новое подключение/интерфейс через Xray, и потом в явном виде в настройках кинетика направить трафик на это новое подключение? 1 Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 21, 2023 Author Share Posted September 21, 2023 21 минуту назад, Marassa сказал: То есть для работы Xray по самому простому способу необходимо поставить/включить компонент прошивки "Прокси-клиент", который по умолчанию выключен и который позволит создать новое подключение/интерфейс через Xray Да, все правильно. Если использовать метод с направлением через прокси-клиент — компонент должен быть установлен. С его помощью можно создать новое прокси-подключение, которое будет направлять соединение на нужный адрес и порт. В нашем случае на те, по которым слушает Xray в конфигурации inbounds. 23 минуты назад, Marassa сказал: И тогда я могу использовать, например Static routes, чтобы какой-то трафик направлять в Xray, а какой-то пускать вообще мимо Xray сразу к провайдеру? Да, можно сделать методом статической маршрутизации. Но намного проще добавить клиента в созданную политику и проксировать все соединение этого клиента в Xray. А в routing Xray гибко настроить соединение, в том числе обозначив, какой трафик пускать к провайдеру. 26 минут назад, Marassa сказал: Тогда необходимо дополнительно ставить пакет iptables через entware? Да, верно. В случае использования метода прямого перенаправления — нужно будет установить iptables. Если хотите использовать метод с tproxy — нужно будет дополнительно поднять и его. 28 минут назад, Marassa сказал: А сам по себе Xray, получается, не использует iptables, а использует для маршрутизации какой-то свой встроенный проприетарный механизм? Да, Xray не использует iptables. У него свой механизм. 3 Quote Link to comment Share on other sites More sharing options...
bigpu Posted September 21, 2023 Share Posted September 21, 2023 32 минуты назад, Marassa сказал: И тогда я могу использовать, например Static routes, чтобы какой-то трафик направлять в Xray, а какой-то пускать вообще мимо Xray сразу к провайдеру? так тоже можно, но менее удобно уже 1 Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 21, 2023 Author Share Posted September 21, 2023 2 часа назад, artem_annihilator сказал: Хм, видимо я что-то неправильно делаю. Можете пожалуйста отправить ваши конфиги роутинга, можно тут или в личку Здравствуйте! Отписала Вам в личные сообщения. Разберемся с Вашей проблемой) 1 Quote Link to comment Share on other sites More sharing options...
Marassa Posted September 21, 2023 Share Posted September 21, 2023 10 минут назад, Skrill0 сказал: Да, все правильно. Спасибо огромное, теперь архитектурный пазл в голове сложился окончательно 11 минуту назад, bigpu сказал: Спасибо, я это видел, но почему-то прочел как частный ответ на частный вопрос о каком-то специфическом случае, а не общее руководство по встройке Xray в кинетик. Возможно стоило бы вставить в документацию буквально пару строк в духе "для того, чтобы трафик маршрутизатора попал в Xray, нужно сделать одно из трёх:..." 1 Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 21, 2023 Author Share Posted September 21, 2023 1 минуту назад, Marassa сказал: Спасибо огромное, теперь архитектурный пазл в голове сложился окончательно Спасибо, я это видел, но почему-то прочел как частный ответ на частный вопрос о каком-то специфическом случае, а не общее руководство по встройке Xray в кинетик. Возможно стоило бы вставить в документацию буквально пару строк в духе "для того, чтобы трафик маршрутизатора попал в Xray, нужно сделать одно из трёх:..." Спасибо за рекомендацию. Обязательно добавлю) Quote Link to comment Share on other sites More sharing options...
bigpu Posted September 21, 2023 Share Posted September 21, 2023 5 минут назад, Skrill0 сказал: Спасибо за рекомендацию. Обязательно добавлю) Доброго утра, раз дело зашло за рекомендации...можно было бы вставить еще одну в руководстве в пункт "Сохраняем комфорт даже при мобильной сети": Для IKE подключения нужен белый IP-адрес, а с серым IP и SSTP скорость будет не ахти какая. Потому разумнее поставить на мобильное уст-во клиент v2rayNG для Android, или аналогичный для iOS, и внести туда настройки сервера с Xray, настроив и само приложение. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Le ecureuil Posted September 21, 2023 Popular Post Share Posted September 21, 2023 Добавлена команда interface proxy socks5-udp которая включает режим SOCKS5-UDP. Будет в draft. 13 1 Quote Link to comment Share on other sites More sharing options...
VladimirM Posted September 22, 2023 Share Posted September 22, 2023 Настроил по "ленивой конфигурации", с использованием встроенного прокси-клиента. Всё работает, но qbittorrent с десктопа качает теперь сильно медленнее (скажем, без xray скорость 60мб/с, с ним 7мб/с, проверено на одном и том же торренте). Подозреваю, что трафик через vps идет. Можно ли как-то побороть это ? 1 Quote Link to comment Share on other sites More sharing options...
fijj Posted September 22, 2023 Share Posted September 22, 2023 45 минут назад, VladimirM сказал: Настроил по "ленивой конфигурации", с использованием встроенного прокси-клиента. Всё работает, но qbittorrent с десктопа качает теперь сильно медленнее (скажем, без xray скорость 60мб/с, с ним 7мб/с, проверено на одном и том же торренте). Подозреваю, что трафик через vps идет. Можно ли как-то побороть это ? Встроенный proxy достаточно медленный. Я решил вообще от него отказаться и использую прокси браузера firefox, достаточно удобно. (Скорость получается 200 мегабит, с proxy на роутере только 60) Достаточно просто указать 192.168.1.1:54836, если настраивали по ленивому конфигу. В итоге через vpn идёт только трафик браузера, торренты напрямую. Для каких то других устройств и сценариев можно я думаю поднять другие inbounds со своими конфигами роутинга. Можно проксировать весь трафик и через прокси самой os. Quote Link to comment Share on other sites More sharing options...
t0w80at Posted September 23, 2023 Share Posted September 23, 2023 Здравствуйте, Skrill0. Благодарю за вашу разработку. Очень нужная в наше время штука 😎. Сделал все по инструкции, вроде все верно. Но есть проблема, не могу разобраться в чем дело, не достаточно скила. Суть: не идет никакой трафик вообще у меня в созданном профиле политики Xray на роутере. То есть я создал прокси, затем создал под него политику, включил там только этот прокси. При закидывании туда устройств, трафик на них полностью прекращается. В чем может быть причина, где копать? Скриншоты прилагаю. access.log 1 Quote Link to comment Share on other sites More sharing options...
VladimirM Posted September 23, 2023 Share Posted September 23, 2023 (edited) 8 часов назад, Филиппов Александр сказал: Встроенный proxy достаточно медленный. Я решил вообще от него отказаться и использую прокси браузера firefox, достаточно удобно. (Скорость получается 200 мегабит, с proxy на роутере только 60) Достаточно просто указать 192.168.1.1:54836, если настраивали по ленивому конфигу. В итоге через vpn идёт только трафик браузера, торренты напрямую. Для каких то других устройств и сценариев можно я думаю поднять другие inbounds со своими конфигами роутинга. Можно проксировать весь трафик и через прокси самой os. Спасибо, хороший вариант. Кто на chrome - можно использовать расширение типа foxyproxy. Насчет установки прокси на уровне windows не проверял влияние на скорость, но тоже как вариант (работать-то точно будет). И еще один вариант - остаться на более простых решениях, пока блокировки WireGuard, OpenVPN были какие-то очень точечные или тестовые. Для работы по этим протоколам есть отличный скрипт Bird4static, настройки минимальные и работает без потери скорости. Edited September 23, 2023 by VladimirM 1 Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 23, 2023 Author Share Posted September 23, 2023 6 часов назад, t0w80at сказал: То есть я создал прокси, затем создал под него политику, включил там только этот прокси. При закидывании туда устройств, трафик на них полностью прекращается. В чем может быть причина, где копать? Доброго Вам утра! Скажите, пожалуйста, а зачем Вам отдельная настройка Policy в Xray? Под политикой доступа в инструкции подразумевалось именно политика в Web роутера. То есть, мы создаем отдельную политику, в которой включаем Xray proxy, а затем перемещаем в нее нужных нам клиентов. Вот пример созданной политики Скрытый текст А это пример помещенного в нее клиента Скрытый текст Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 23, 2023 Author Share Posted September 23, 2023 10 часов назад, VladimirM сказал: Настроил по "ленивой конфигурации", с использованием встроенного прокси-клиента. Всё работает, но qbittorrent с десктопа качает теперь сильно медленнее (скажем, без xray скорость 60мб/с, с ним 7мб/с, проверено на одном и том же торренте). Подозреваю, что трафик через vps идет. Можно ли как-то побороть это ? Здравствуйте! Можно направить соединение по протоколу bittorrent на direct. Для этого Вам нужно добавить следующую часть в routing. Скрытый текст { "inboundTag": ["socks-in"], "protocol": ["bittorrent"], "outboundTag": "direct", "type": "field" } Таким образом загрузка торрентов будет идти напрямую 2 Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 23, 2023 Author Share Posted September 23, 2023 (edited) В 23.09.2023 в 10:22, VladimirM сказал: Спасибо, хороший вариант. Кто на chrome - можно использовать расширение типа foxyproxy. Насчет установки прокси на уровне windows не проверял влияние на скорость, но тоже как вариант (работать-то точно будет). И еще один вариант - остаться на более простых решениях, пока блокировки WireGuard, OpenVPN были какие-то очень точечные или тестовые. Для работы по этим протоколам есть отличный скрипт Bird4static, настройки минимальные и работает без потери скорости. Доброго Вам утра! Экспериментальным путем было выяснено, что Xray/v2ray используют ssh. | Отдельна благодарность @vasek00 Что для процессоров MT7621, к примеру, в Giga KN-1011, тяжело. Пока решение не готово. Приблизительная максимальная скорость доступа через Xray: MT7621 — Download 40-60мб/сек. MT7622B — Download 350-400мб/сек. * Под приблизительной подразумевается разница условий. Благодаря технологии XTLS — шифруется только еще не зашифрованный трафик, то есть нет избыточного шифрования. В тестах использовался метод с еще не шифрованным соединением. То есть, обозначена максимальная скорость в условиях постоянного требования к шифрованию. В реальных условиях такого не будет и скорость будет выше. Тест MT7621 Скрытый текст Вот требуемая скорость под разные задачи Скрытый текст 10-25 Мбит/с: Базовый серфинг. Чтение новостей, проверка почты и использования социальных сетей на одном устройстве. 25-50 Мбит/с: Базовый серфинг с нескольких устройств + видео. Для нескольких устройств в сети или интенсивного просмотра потокового видео в разрешении SD. 50-100 Мбит/с Для просмотра видео в разрешении HD, онлайн-игр и подключения множества устройств к сети. 100+ Мбит/с Потоковая передача видео в 4K, большие загрузки файлов. Иными словами, если не использовать проксирование через Xray для загрузок торрентов или стримов в 4k, то разница ощутимой не будет. Edited September 25, 2023 by Skrill0 2 Quote Link to comment Share on other sites More sharing options...
t0w80at Posted September 23, 2023 Share Posted September 23, 2023 5 часов назад, Skrill0 сказал: Доброго Вам утра! Скажите, пожалуйста, а зачем Вам отдельная настройка Policy в Xray? Под политикой доступа в инструкции подразумевалось именно политика в Web роутера. То есть, мы создаем отдельную политику, в которой включаем Xray proxy, а затем перемещаем в нее нужных нам клиентов. Вот пример созданной политики Скрыть содержимое А это пример помещенного в нее клиента Скрыть содержимое Да, я именно так и понял и так и сделал. Прилагаю скриншоты. А политика в самом Xkeen я ничего не настраивал и не менял там ничего, просто файл по умолчанию который был. 1 Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 23, 2023 Author Share Posted September 23, 2023 44 минуты назад, t0w80at сказал: Попробуйте запустить без 09_policy.json. С Xkeen он поставляется пустым. Также можете попробовать не добавлять отдельных DNS. В статье этого также не указывается. Для полноценного запуска нужны только inbounds, outbounds, routing. Если запустится, то нужно искать ошибки в других конфигурациях, которые настроили отдельно. 1 Quote Link to comment Share on other sites More sharing options...
The_Same Posted September 23, 2023 Share Posted September 23, 2023 49 минут назад, t0w80at сказал: Да, я именно так и понял и так и сделал. Прилагаю скриншоты. А политика в самом Xkeen я ничего не настраивал и не менял там ничего, просто файл по умолчанию который был. Я для прокси добавил DNS сервера, потому что без них проксируемые сайты открывались долго и не с первого раза. Например, intel.com с этими DNS открывается стабильно и быстро. 2 Quote Link to comment Share on other sites More sharing options...
The_Same Posted September 23, 2023 Share Posted September 23, 2023 Снова добрый вечер, на устройствах, добавленных в политику прокси скорость доступа в интернет падает раза в два😔 Проверил на своем компьютере, если пускать через прокси, то скорость порядка 180-190 Мб/с, если напрямую - 350-400 Мб/с. Тариф 350 Мб/с. Может кто-то поподробнее расписать конфиги маршрутизации, которые писал @avn выше в теме? Чтобы не использовать встроенный медленный прокси Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 23, 2023 Author Share Posted September 23, 2023 7 минут назад, The_Same сказал: Снова добрый вечер, на устройствах, добавленных в политику прокси скорость доступа в интернет падает раза в два😔 Проверил на своем компьютере, если пускать через прокси, то скорость порядка 180-190 Мб/с, если напрямую - 350-400 Мб/с. Тариф 350 Мб/с. Может кто-то поподробнее расписать конфиги маршрутизации, которые писал @avn выше в теме? Чтобы не использовать встроенный медленный прокси Добрый вечер! Завтра будет обновление xkeen, которое позволит использовать redirect автоматически. 3 2 Quote Link to comment Share on other sites More sharing options...
The_Same Posted September 23, 2023 Share Posted September 23, 2023 (edited) 3 минуты назад, Skrill0 сказал: Добрый вечер! Завтра будет обновление xkeen, которое позволит использовать redirect автоматически. Все конфиги, которые я сегодня делал, надо будет править? Edited September 23, 2023 by The_Same Quote Link to comment Share on other sites More sharing options...
Skrill0 Posted September 23, 2023 Author Share Posted September 23, 2023 Только что, The_Same сказал: Все конфиги, которые я сегодня делал надо будет править? Нет, только 1 правило в inbounds 1 Quote Link to comment Share on other sites More sharing options...
t0w80at Posted September 23, 2023 Share Posted September 23, 2023 7 часов назад, Skrill0 сказал: Попробуйте запустить без 09_policy.json. С Xkeen он поставляется пустым. Также можете попробовать не добавлять отдельных DNS. В статье этого также не указывается. Для полноценного запуска нужны только inbounds, outbounds, routing. Если запустится, то нужно искать ошибки в других конфигурациях, которые настроили отдельно. Итак, попробовал все переустановить и с чистого листа, начать. У меня получилось пропустить трафик но только на не запрещенные ресурсы использовал конфиг 10_routing_p.json так как мне больше подходит история где все идет через VPN и лишь некоторые напрямую. Что-то по видимому у меня не так... файл конфига не правил, поэтому его не прикладываю. Так же попробовал конфиг 10_routing_d.json но в этой конфигурации не конектятся Telegram и Discord и там тоже запрещенные не конектятся. Quote Link to comment Share on other sites More sharing options...
