  • 5
IntelliQoS Page (Smart Queue Management) - A few feature requests
Posted
Hello. I think IntelliQoS is missing a few controls. @eralde
These are :
1) Enable / disable
2) MBPS / KBPS selection
Feature 1 is needed because : SQM cannot be disabled, there is no control for this in the new interface. When you want to disable it, you cannot enter the value 0 or leave it empty.
The 2nd feature is needed for the following reason: Sometimes users may want to fine tune the speed in KBPS. I think it would be good to give this choice to the user.
https://ibb.co/mBtd1xD
  • Upvote 6
6 answers to this question
Posted
3 часа назад, PriSonerS61 сказал:
These are :
1) Enable / disable
To disable traffic prioritization you should uncheck the second checkbox on the picture below
(it does the same thing as the toggle in the current UI)
Personally, I don't think specifying a kbps limit is a very popular feature, but if it gets a lot of votes, we'll probably implement it.
Perhaps an easier way to achieve the same result would be to modify the inputs to allow you to enter a non-integer value (in Mbps) there.
  • Thanks 2
Posted
I don't quite understand your first message. Aren't the "Smart Queue Management" and "Application classification and prioritization" features independent of each other?
I just wanted an on/off feature for the Smart Queue Management feature because it limits the speed according to the value entered. Maybe the user may want to remove or disable it later.
Yes I agree with that, if we are not forced to enter integers in mbps, it will indirectly work the same as kbps.
Posted
6 часов назад, PriSonerS61 сказал:
The "IntelliQoS" page layout may be a bit confusing, but the "Application prioritization" checkbox actually turns SQM on or off.
In order to properly prioritize traffic, we need to:
  • know the actual bandwidth (how many packets you can send per second over a given connection)
  • classify traffic (put packets of a given type into appropriate queues)
  • send a certain number of packets from each queue according to its priority
So that's what we show in the new UI: a table to specify the bandwidth limit for each connection, a checkbox to enable classification and another checkbox to enable prioritization (with a list of traffic types that can be ordered according to your wishes below).
  • Thanks 3
Posted (edited)
12 часа назад, eralde сказал:
Hi, i have a questions.
1. If i use app prioritazation data i have jitters and ping spikes in my tests, also games like (apex,cs,dota) do not have category ( they have 6 because because not determited.)
2.And strange thing, if i use bandwith limit in intelliqos like 250/250 works fine, but if use upstream I(interface ISP) rate-limit - upload and download 250/250. Upload works fine, download no (make speed more then limit).
3.How to setup SQM correctly? Should i use app prioritize to enable SQM (fq_codel/cake algorithms) also priority 6 (default) in device list? OR can use intelliqos rate limit and setup priority in device list in my pc (not default 6)
Thanks!
Keenetic Viva 1912 and 4.1 beta 4
Edited by pashachoo
Posted
2 часа назад, pashachoo сказал:
Thanks!
This is certainly out of scope of this thread (your questions aren't about the Web UI, if I understand them correctly).
Please, start a new thread here: https://forum.keenetic.com/forum/52-dev-channel-issues-test-reports/ and describe your issues as detailed as possible or create a new request to the tech support (https://help.keenetic.com/hc/en-us)
