Mesh Device Configuration Issues After 4.3 Alpha 6 Update
Posted
After updating to version 4.3 Alpha 6, I noticed the following issues:
  • The Buddy 6 mesh device does not display the settings for the Home segment.
  • The Hero mesh device shows the Home segment settings as locked, which seems to be a bug.
Additionally, since our mesh device might be operating in wired mode, it should be possible to adjust the 2.4GHz channel independently from the controller.
Greetings from Türkiye, together with @KYTECHNGAMING
  • Thanks 3
9 answers to this question
Posted
Edit: With the A6 update, clients connected to Buddy6 are not receiving IP addresses. We temporarily resolved the issue by downgrading to the A5 version.
  • Thanks 2
Posted
21 час назад, ru.celebi сказал:
Thank you for the report, that is a bug in Alpha 6. It will be fixed in a future version.
That is not a bug. Extender settings that are configured by the controller are locked in the extender web UI.
However, at the moment some Wi-Fi parameters are still configurable only via the extender web UI, you can see them if you click on the “Advanced Settings” link in your screenshot.
Basic Wi-Fi settings on the extender (SSID / Network protection / Password / ...) in both bands are synchronized with the controller. This is part of the Mesh Wi-Fi system design.
  • Thanks 2
Posted
@eralde Is there any progress on this issue? Client devices are unable to obtain an IP address from Buddy6 with A6
Posted
11 минуту назад, ru.celebi сказал:
Please check if 4.3 Alpha 6.1 solves this problem.
Posted (edited)
This morning, I tried 4.3.A6.1, but the issue persists.
Edited by ru.celebi
Posted
3 hours ago, Leshiyart said:
fix in CLI interface mac address factory wan
after updates and apply system save configuration
just enter the command on extender?
interface devicemacaddress factory wan
