SSTP-сервер и клиент
@Le ecureuil
Сделал клиент сервер, все практически по умолчанию
На клиенте выставляется DNS равный внешнему ip сервера. Странновато...
[I] Feb  1 22:36:04 ndm: Network::Interface::Base: "SSTP0": interface is up.
[I] Feb  1 22:36:04 ndm: Network::Interface::Ppp: "SSTP0": disabled connection.
[I] Feb  1 22:36:04 ndm: Network::Interface::PppTunnel: "SSTP0": remote endpoint is resolved to "178.140.123.132".
[I] Feb  1 22:36:04 ndm: Network::Interface::PppTunnel: "SSTP0": local endpoint is resolved to "192.168.0.168" (via "CdcEthernet0").
[I] Feb  1 22:36:04 ndm: Network::Interface::PppTunnel: "SSTP0": added host route to 178.140.123.132 via 192.168.0.1 (CdcEthernet0).
[I] Feb  1 22:36:04 ndm: Network::Interface::Ppp: "SSTP0": enabled connection via any interface.
[I] Feb  1 22:36:06 pppd[2875]: Plugin sstp-pppd-plugin.so loaded.
[I] Feb  1 22:36:06 pppd[2875]: pppd 2.4.4-4 started by root, uid 0
[I] Feb  1 22:36:06 pppd[2875]: Using interface ppp0
[I] Feb  1 22:36:06 pppd[2875]: Connect: ppp0 <--> /dev/pts/0
[I] Feb  1 22:36:07 pppd[2875]: CHAP authentication succeeded
[I] Feb  1 22:36:07 pppd[2875]: local  IP address 172.16.3.10
[I] Feb  1 22:36:07 pppd[2875]: remote IP address 178.140.123.132
[I] Feb  1 22:36:07 pppd[2875]: primary   DNS address 178.140.123.132
[I] Feb  1 22:36:07 ndm: Network::Interface::Base: "SSTP0": interface is up.
[I] Feb  1 22:36:07 ndm: Network::Interface::Ppp: "SSTP0": adding nameserver 178.140.123.132.
[I] Feb  1 22:36:07 ndm: Dns::Manager: name server 178.140.123.132 added, domain (default).
[I] Feb  1 22:36:07 ndm: Network::Interface::IP: "SSTP0": IP address is 172.16.3.10/32.
@Le ecureuil и еще
Если соединяемся через облако remote endpoint определяется облачный, но затем remote IP address определяется как внешний адрес сервера
это так и задумано? Не понятно.
[I] Feb  1 22:48:27 ndm: Network::Interface::PppTunnel: "SSTP0": remote endpoint is resolved to "91.218.112.172".
[I] Feb  1 22:48:27 ndm: Core::ConfigurationSaver: saving configuration...
[I] Feb  1 22:48:27 ndm: Network::Interface::PppTunnel: "SSTP0": local endpoint is resolved to "192.168.0.168" (via "CdcEthernet0").
[I] Feb  1 22:48:27 ndm: Network::Interface::PppTunnel: "SSTP0": added host route to 91.218.112.172 via 192.168.0.1 (CdcEthernet0).
[I] Feb  1 22:48:28 ndm: Network::Interface::Ppp: "SSTP0": enabled connection via any interface.
[I] Feb  1 22:48:30 pppd[3472]: Plugin sstp-pppd-plugin.so loaded.
[I] Feb  1 22:48:30 pppd[3472]: pppd 2.4.4-4 started by root, uid 0
[I] Feb  1 22:48:30 pppd[3472]: Using interface ppp0
[I] Feb  1 22:48:30 pppd[3472]: Connect: ppp0 <--> /dev/pts/0
[I] Feb  1 22:48:31 pppd[3472]: CHAP authentication succeeded
[I] Feb  1 22:48:31 pppd[3472]: local  IP address 172.16.3.10
[I] Feb  1 22:48:31 pppd[3472]: remote IP address 178.140.123.132
[I] Feb  1 22:48:31 pppd[3472]: primary   DNS address 178.140.123.132
[I] Feb  1 22:48:31 ndm: Core::ConfigurationSaver: configuration saved.
[I] Feb  1 22:48:31 ndm: Network::Interface::Base: "SSTP0": interface is up.
[I] Feb  1 22:48:31 ndm: Network::Interface::Ppp: "SSTP0": adding nameserver 178.140.123.132.
[I] Feb  1 22:48:31 ndm: Dns::Manager: name server 178.140.123.132 added, domain (default).
[I] Feb  1 22:48:31 ndm: Network::Interface::IP: "SSTP0": IP address is 172.16.3.10/32.
Я так понимаю, сервером выступает тоже Keenetic?
Прошу снять self-test с обоих устройств:
- на сервере нужно запустить > system debug
- на клиенте нужно запустить > interface SSTP0 debug
и после этого дождаться подключения.
5 минут назад, r13 сказал:
@Le ecureuil и еще
Да, тут пока так и будет - особенность реализации.
10 минут назад, Le ecureuil сказал:
готово
11 час назад, r13 сказал:
готово
А можно еще попросить вывод
more temp:/run/sstp-server/accel.conf
с сервера, когда приходят такие DNS и удаленный хост (скрытым постом)?
У меня почему-то sstp просит зарегестрировать имя keendns, хотя имя у меня зарегестрированно. В логе написанно что нет имени keendns. Хотя имя есть. Что не так?
10 минут назад, pachalia сказал:
А сертификат на это имя получен?
32 минуты назад, pachalia сказал:
self-test приложите.
И вывод команды show sstp-server.
1 час назад, pachalia сказал:
Да.
Старые домены (которые mykeenetic) не подходят.
Работает только на новых доменах, на которых есть автоматическое получение сертификата.
10 часов назад, Le ecureuil сказал:
выложил
кстати, трафик у меня по этому туннелю пока не ходит...только эхо ходит судя по логу
Edited by r13
@Le ecureuil и еще, не смотря на настройку на сервере
sstp-server dhcp route 192.168.1.0 255.255.255.0
маршрут на клиенте не подхватился. не работает пока?
upd прописал маршрут на клиенте, заработал трафик с сервера, с клинта пока нет, видимо на сервере тоже с firewall ом тоже надо шаманить
и еще, кажись правила iptables замножаются
upd2
Да, судя по вот этой цепочке пакеты только на внешний адрес принимаютя?! если идти с клиента на внешний адрес сервера то пакеты проходят.
Edited by r13
upd2
Все понятно с вами.
Цитата из конфига:
sstp-server
    interface ISP
interface здесь - это один из интерейсов в домашней сети, обычно это Bridge0 / Home, а не интерфейс на котором надо слушать подключения. Все абсолютно также, как в PPTP и как в L2TP/IPsec сервере.
У вас так настроилось через Web? Или руками вбили? Потому что это явный баг, если через Web.
Насчет маршрута - а клиент что? Он его запросил? Добавил к себе в таблицу маршрутизации?
Хотя, пока не исправите interface ISP на interface Home у вас так и будет мусорный роутинг и DNS.
7 минут назад, Le ecureuil сказал:
Все понятно с вами.
Цитата из конфига:
sstp-server
    interface ISP
а блин, вот где собака порылась, я балбес его к isp привязал
ps вбивал руками, веб я только потом обнаружил :?
Edited by r13
8 минут назад, Le ecureuil сказал:
так интерфейс поправил, теперь ок,
что нужно чтобы клиент запросил маршруты?
зы клиента в вебе настраивал
12 минуты назад, r13 сказал:
Там по идее должно прийти событие c DHCP INFORM, и отразиться в логе.
Только что, Le ecureuil сказал:
нет, в логе его нет ни с какой стороны
11 минуту назад, Le ecureuil сказал:
а если подключиться виндовым клиентом то есть dhcpinform на сервере. значит ndm клиент не запрашивает
принудительный ввод
ip dhcp client routes
не помог, но судя по документации и не должен помочь, так как по умолчанию включено.
Edited by r13
15 минут назад, r13 сказал:
а если подключиться виндовым клиентом то есть dhcpinform на сервере. ndm значит клиент не запрашивает
Угу, отловил этот баг тоже. Поправлено.
Чойта мне кажется @ndm поторопился, на 2.12.A.3.0-1 нету dhcpinform с встроенным SSTP клиентом.
Кстати это фикс клиента или сервера(На старых версиях клиенты PPTP, L2TP/IPSec запрашивают маршруты?)
Edited by r13
24 минуты назад, r13 сказал:
Там рассылка исправлена, а не прием.
Прием пока еще в стадии отладки. Когда сломался - неизвестно, но факт, что сейчас не работает.
13 часа назад, r13 сказал:
Все поправлено, причем было сломано получение на всех интерфейсах, в том числе и на L2TP и PPTP.
Главное - удаленный адрес в VPN должен отличаться от локального, иначе из-за Reverse Path Filtering вы ничего не получите.
То есть если на сервере VPN привязан к интерфейсу с адресом 192.168.1.1, то на клиенте не должно быть интерфейса с таким адресом (а желательно чтобы и с подсетью, иначе будет конфликт роутинга, который будет маскироваться из-за метрики).
Я не понял как мне при помощи sstp подключиться к диску на роутере.  Клиент пишет что подключение установленно. Роутер подтверждает что подключение есть.  А дальше что? Ведь цель была не установить подключение и потом смотреть на значок vpn, а получить доступ к диску,  который подключён к роутеру.
3 минуты назад, pachalia сказал:
А дальше как с любым другим vpn, заходите на него по ip. Важно чтобы маршруты были настроены на клиенте, и на сервере если нужно  (текущий клиент маршруты не запрашивает, появится в следующей сборке)
5 минут назад, pachalia сказал:
Клиент получает адрес 172.168.3.33. Роутер имеет адрес 192.168.1.1. Попытался с роутера пропинговать адрес 172.168.3.33. Пинг не прошёл.
На клиенте firewall открыт для этого соединения?!
Клиентом выступает vpn client pro. Это клиент для андроида. Клиент показывает что обмен идёт. Так же на роутере появляется запись в активных соединениях .  Но когда с роутера пытаешься пинговать клиент, то пинг не проходит.
 Share
