kis-markiz Posted September 17, 2020 Share Posted September 17, 2020 обственно, на ZK Ultra под 2.16.D.6.0-0 Скрытый текст в лог валится вот такое: Скрытый текст 1 Quote Link to comment Share on other sites More sharing options...
Goblin Posted September 17, 2020 Share Posted September 17, 2020 ну не все. swap-раздел у меня примонтировался. Сен 17 22:54:10 ndm FileSystem::Ext: "/dev/sda" has an unknown partition type, ignored. Сен 17 22:54:10 ndm FileSystem::Ext: ntfs "01D5603F5DB55A30:": filesystem initialized. Сен 17 22:54:10 kernel tntfs info (device sda1, pid 4116): ntfs_fill_super(): fail_safe is enabled. Сен 17 22:54:10 kernel tntfs error (device sda1, pid 4116): ntfs_fill_super(): Unable to determine device size. Сен 17 22:54:10 ndm FileSystem::Native: failed to mount "/tmp/mnt/01D5603F5DB55A30": invalid argument. Сен 17 22:54:10 ndm FileSystem::Ext: failed to mount. Сен 17 22:54:10 ndm FileSystem::Ext: ntfs "01D5603F5DB55A30:": unable to mount. Сен 17 22:54:10 ndm FileSystem::Repository: failed to register "01D5603F5DB55A30:" filesystem. Сен 17 22:54:10 ndm FileSystem::Ext: swap "94ef5575-fb89-4ca7-a4d9-e5ecab9aa41e:": filesystem initialized. Сен 17 22:54:10 kernel Adding 511996k swap on /dev/sda2. Priority:-1 extents:1 across:511996k Сен 17 22:54:10 ndm FileSystem::Repository: "94ef5575-fb89-4ca7-a4d9-e5ecab9aa41e:" registered. Quote Link to comment Share on other sites More sharing options...
Goblin Posted September 17, 2020 Share Posted September 17, 2020 @Le ecureuil, чего с дисками то делать? может как-то временно(до выхода фикса прошивки) "руками" можно примонтировать? 1 Quote Link to comment Share on other sites More sharing options...
Rootdiv Posted September 17, 2020 Share Posted September 17, 2020 (edited) @Le ecureuil, аналогичная проблема srlftest и log прикреплю скрытым сообщением. P.S. Я откатился на предыдущую версию. Edited September 17, 2020 by Rootdiv 1 Quote Link to comment Share on other sites More sharing options...
kis-markiz Posted September 17, 2020 Author Share Posted September 17, 2020 12 минуты назад, Rootdiv сказал: P.S. Я откатился на предыдущую версию. Вот и я откатился. После 14 часов работы эникейщиком (8 часов + удаленка) и пары бокалов виски мосх других идей генерировать не в состоянии ) Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted September 17, 2020 Share Posted September 17, 2020 Причина ясна и устранена, пересборка уже в пути. Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted September 17, 2020 Share Posted September 17, 2020 32 минуты назад, Goblin сказал: @Le ecureuil, чего с дисками то делать? может как-то временно(до выхода фикса прошивки) "руками" можно примонтировать? Чуть обождать, через пару часов все будет. Quote Link to comment Share on other sites More sharing options...
keenet07 Posted September 17, 2020 Share Posted September 17, 2020 52 минуты назад, Le ecureuil сказал: Чуть обождать, через пару часов все будет. С тем же номером версии? Версия 2.16.D.6.0-0: NTFS: восстановлено монтирование разделов (сообщили @kis-markiz, @Rootdiv, @Goblin) Quote Link to comment Share on other sites More sharing options...
Goblin Posted September 18, 2020 Share Posted September 18, 2020 5 часов назад, keenet07 сказал: С тем же номером версии? пришла 2.16.D.6.0-1 Quote Link to comment Share on other sites More sharing options...
keenet07 Posted September 18, 2020 Share Posted September 18, 2020 5 часов назад, Goblin сказал: пришла 2.16.D.6.0-1 Так и подумал. Написал, чтоб в истории версий копипасту версии поправили. Quote Link to comment Share on other sites More sharing options...
