PriSonerS61 Posted January 19, 2022 Posted January 19, 2022 (edited) Segment names are displayed in English in the Keenetic application. (Turkish should appear) https://ibb.co/ChVh8dY I think the reason why there is an error in this way is that the descriptions of the home network and the guest network are written in English. https://ibb.co/VQb3jLM https://ibb.co/mbYF2WB @Alex Sh. @eralde Edited January 19, 2022 by PriSonerS61 1 1 Quote
0 PriSonerS61 Posted March 19, 2022 Author Posted March 19, 2022 (edited) On 3/15/2022 at 10:27 AM, Alex Sh. said: It wasn't me but another Alex I suppose. However I have checked your complain in TG and reopened the task I had created earler. It looks like we still have this issue on two screens: Connected Device List and Connected Device Card. We will fix both. Thank you for letting us, Alexes, know. UPD: Forgot to mention: N/A instead of Offline will be fixed in the next app release. There was a translation mistake. The problem has been fixed in v32(117). Thanks. https://ibb.co/0MmK9W3 Edited March 19, 2022 by PriSonerS61 Quote
0 eralde Posted January 19, 2022 Posted January 19, 2022 12 минуты назад, PriSonerS61 сказал: Segment names are displayed in English in the Keenetic application. (Turkish should appear) https://ibb.co/ChVh8dY I think the reason why there is an error in this way is that the descriptions of the home network and the guest network are written in English. https://ibb.co/VQb3jLM https://ibb.co/mbYF2WB @Alex Sh. @eralde This is not an error. If a predefined segment (Home, Guest) has a default description ("Home network", "Guest network"), its visible name is translated into the current language of the web UI. I hope that someday we will stop doing this and just rename the predefined segments in the Initial Setup Wizard. 2 Quote
0 PriSonerS61 Posted January 19, 2022 Author Posted January 19, 2022 14 minutes ago, eralde said: This is not an error. If a predefined segment (Home, Guest) has a default description ("Home network", "Guest network"), its visible name is translated into the current language of the web UI. I hope that someday we will stop doing this and just rename the predefined segments in the Initial Setup Wizard. Then the source of the problem is not where I think it is. The problem is related to the mobile application. I hope @Alex Sh. will fix it for the next version Quote
0 Alex Sh. Posted January 20, 2022 Posted January 20, 2022 12 часа назад, PriSonerS61 сказал: The problem is related to the mobile application. Correct. In fact, the app does the same name translation too, but only for RU atm. I've created a task to add the rest of the translations including TR. Thank you for letting me know. 2 Quote
0 Alex Sh. Posted February 24, 2022 Posted February 24, 2022 @PriSonerS61 Hi, is the issue still present on dashboard and connected device screen on v30? I can't see you screenshots anymore to double-check that it is fixed. Quote
0 PriSonerS61 Posted March 14, 2022 Author Posted March 14, 2022 On 2/24/2022 at 10:08 AM, Alex Sh. said: @PriSonerS61 Hi, is the issue still present on dashboard and connected device screen on v30? I can't see you screenshots anymore to double-check that it is fixed. Hello, I wanted to update the topic. We were in contact with you via telegram. Currently the mobile app version is v32(116) and the problem persists. Quote
0 Alex Sh. Posted March 15, 2022 Posted March 15, 2022 14 часа назад, PriSonerS61 сказал: We were in contact with you via telegram It wasn't me but another Alex I suppose. However I have checked your complain in TG and reopened the task I had created earler. It looks like we still have this issue on two screens: Connected Device List and Connected Device Card. We will fix both. Thank you for letting us, Alexes, know. UPD: Forgot to mention: N/A instead of Offline will be fixed in the next app release. There was a translation mistake. 2 Quote
0 PriSonerS61 Posted March 15, 2022 Author Posted March 15, 2022 58 minutes ago, Alex Sh. said: It wasn't me but another Alex I suppose. However I have checked your complain in TG and reopened the task I had created earler. It looks like we still have this issue on two screens: Connected Device List and Connected Device Card. We will fix both. Thank you for letting us, Alexes, know. UPD: Forgot to mention: N/A instead of Offline will be fixed in the next app release. There was a translation mistake. Thanks. I thought it was the same person I'm glad you saw my posts there. If I had known that you were not the same person, I would have continued to write here Quote
0 KYTECHNGAMING Posted March 19, 2022 Posted March 19, 2022 On 3/15/2022 at 10:27 AM, Alex Sh. said: It wasn't me but another Alex I suppose. However I have checked your complain in TG and reopened the task I had created earler. It looks like we still have this issue on two screens: Connected Device List and Connected Device Card. We will fix both. Thank you for letting us, Alexes, know. UPD: Forgot to mention: N/A instead of Offline will be fixed in the next app release. There was a translation mistake. N/A to Çevrimdışı ✔️ 1 Quote
PriSonerS61
@Alex Sh. @eralde
Edited by PriSonerS6110 answers to this question
