Keenetic теряет связь в одно и тоже время.
Aiden2303
Здравствуйте, Keenetic Viva разрывает связь с интернетом каждый день в 12:33.
Хозяин в это время подключен к удалённому рабочего столу через VPN l2tp, и по тому что отключается удалённый рабочий стол. зафиксировал время разрыва.
В журнале роутера в это время каждый день проходят такие строки.
[quote]
[I] Dec 5 10:28:16 ndm: Network::Interface::Rtx::WifiMonitor: "WifiMaster1/AccessPoint0": STA(c4:85:08:8d:0f:95) had deauthenticated by STA (reason: unspecified).
[I] Dec 5 11:03:33 ndhcpc: GigabitEthernet1: received ACK for 10.109.233.78 from 10.255.0.100 lease 7200 sec.
[I] Dec 5 11:51:33 ndm: Network::Interface::Switch: "GigabitEthernet0/2": switch link down at port 3.
[I] Dec 5 11:51:36 ndm: Network::Interface::Switch: "GigabitEthernet0/2": switch link up at port 3 (1000FD/AN).
[I] Dec 5 11:51:43 ndhcps: DHCPINFORM received for 192.168.1.40 from 00:23:54:14:36:c7.
[I] Dec 5 11:51:43 ndhcps: sending INFORM to 00:23:54:14:36:c7.
[I] Dec 5 11:51:48 ndhcps: DHCPREQUEST received (STATE_INIT) for 192.168.1.40 from 00:23:54:14:36:c7.
[I] Dec 5 11:51:49 ndhcps: sending ACK of 192.168.1.40 to 00:23:54:14:36:c7.
[I] Dec 5 12:03:33 ndhcpc: GigabitEthernet1: received ACK for 10.109.233.78 from 10.255.0.100 lease 7200 sec.
[I] Dec 5 12:33:38 pppd[11948]: LCP terminated by peer
[I] Dec 5 12:33:38 pppd[11948]: Connect time 1440.0 minutes.
[I] Dec 5 12:33:38 pppd[11948]: Sent 304902490 bytes, received 1130442655 bytes.
[I] Dec 5 12:33:38 pppd[11948]: Modem hangup
[I] Dec 5 12:33:38 pppd[11948]: Connection terminated.
[I] Dec 5 12:33:38 pppd[11948]: Sent PADT
[I] Dec 5 12:33:38 ndm: Network::Interface::Ip: "PPPoE0": IP address cleared.
[I] Dec 5 12:33:38 ndm: Network::InterfaceFlusher: flushed PPPoE0 conntrack and route cache.
[I] Dec 5 12:33:38 ndm: Network::InternetChecker: Internet access lost (status: 0x0000).
[I] Dec 5 12:33:38 ndm: Core::Schedule::Manager: raised action "start" by "schedule0".
[I] Dec 5 12:33:39 ndm: Http::Nginx: loaded SSL certificate for "52009dfe03ea076936d94d07.keenetic.io".
[I] Dec 5 12:33:39 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Dec 5 12:33:39 ndm: Core::Session: client disconnected.
[I] Dec 5 12:33:39 ndm: Http::Manager: updated configuration.
[I] Dec 5 12:33:39 pppd[11948]: Exit.
[E] Dec 5 12:33:39 ndm: Service: "PPPoE0": unexpectedly stopped.
[E] Dec 5 12:33:39 ndm: Cloud::Agent: can not connect to the cloud server.
[I] Dec 5 12:33:40 upnp: shutting down MiniUPnPd
[I] Dec 5 12:33:40 ndm: Core::Session: client disconnected.
[I] Dec 5 12:33:40 ndm: Network::Interface::Base: "PPPoE0": interface is up.
[I] Dec 5 12:33:42 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Dec 5 12:33:42 upnp: HTTP listening on port 1900
[I] Dec 5 12:33:42 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Dec 5 12:33:43 pppd[12327]: Plugin rp-pppoe.so loaded.
[I] Dec 5 12:33:43 pppd[12327]: pppd 2.4.4-4 started by root, uid 0
[I] Dec 5 12:33:43 pppd[12327]: Found unterminated session: 2728:84:34:97:11:1f:f4
[I] Dec 5 12:33:43 pppd[12327]: Sent PADT
[I] Dec 5 12:33:43 pppd[12327]: PPP session is 32937
[I] Dec 5 12:33:43 pppd[12327]: Using interface ppp0
[I] Dec 5 12:33:43 pppd[12327]: Connect: ppp0 <--> eth3
[I] Dec 5 12:33:43 pppd[12327]: CHAP authentication succeeded
[I] Dec 5 12:33:43 pppd[12327]: peer from calling number 2C:C8:1B:BC:0C:DA authorized
[I] Dec 5 12:33:43 pppd[12327]: local  IP address 172.16.6.20
[I] Dec 5 12:33:43 pppd[12327]: remote IP address 192.168.123.6
[I] Dec 5 12:33:43 pppd[12327]: primary   DNS address 109.238.80.244
[I] Dec 5 12:33:43 pppd[12327]: secondary DNS address 109.238.80.132
[I] Dec 5 12:33:43 ndm: Network::Interface::Base: "PPPoE0": interface is up.
[I] Dec 5 12:33:43 ndm: Network::Interface::Ppp: "PPPoE0": interface "PPPoE0" is global, priority 32942.
[I] Dec 5 12:33:43 ndm: Network::Interface::Ppp: "PPPoE0": adding default route via PPPoE0.
[I] Dec 5 12:33:43 ndm: Network::Interface::Ppp: "PPPoE0": adding nameserver 109.238.80.244.
[I] Dec 5 12:33:43 ndm: Dns::Manager: name server 109.238.80.244 added, domain (default).
[I] Dec 5 12:33:43 ndm: Network::Interface::Ppp: "PPPoE0": adding nameserver 109.238.80.132.
[I] Dec 5 12:33:43 ndm: Dns::Manager: name server 109.238.80.132 added, domain (default).
[I] Dec 5 12:33:43 ndm: Network::Interface::Ip: "PPPoE0": IP address is 172.16.6.20/32.
[I] Dec 5 12:33:43 ndm: Network::InterfaceFlusher: flushed GigabitEthernet1 conntrack and route cache.
[I] Dec 5 12:33:43 ndm: Core::Schedule::Manager: raised action "start" by "schedule0".
[I] Dec 5 12:33:44 upnp: shutting down MiniUPnPd
[I] Dec 5 12:33:44 ndm: Core::Session: client disconnected.
[I] Dec 5 12:33:44 ndm: Http::Nginx: loaded SSL certificate for "52009777ea076936d94d07.keenetic.io".
[I] Dec 5 12:33:44 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Dec 5 12:33:44 ndm: Http::Manager: updated configuration.
[I] Dec 5 12:33:44 ndm: Network::InternetChecker: Internet access detected.
[I] Dec 5 12:33:46 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Dec 5 12:33:46 upnp: HTTP listening on port 1900
[I] Dec 5 12:33:46 upnp: Listening for NAT-PMP/PCP traffic on port 5351
[I] Dec 5 13:03:33 ndhcpc: GigabitEthernet1: received ACK for 10.109.233.78 from 10.255.0.100 lease 7200 sec.
[I] Dec 5 13:18:41 ndhcps: DHCPREQUEST received (STATE_RENEWING) for 192.168.1.38 from 8c:45:00:83:31:ed.
[I] Dec 5 13:18:41 ndhcps: sending ACK of 192.168.1.38 to 8c:45:00:83:31:ed.
[I] Dec 5 14:03:33 ndhcpc: GigabitEthernet1: received ACK for 10.109.233.78 from 10.255.0.100 lease 7200 sec.
[I] Dec 5 15:03:33 ndhcpc: GigabitEthernet1: received ACK for 10.109.233.78 from 10.255.0.100 lease 7200 sec.
[/quote]
Подскажите пожалуйста, в чём может быть причина?
6 answers to this question
18 минут назад, Aiden2303 сказал:
1440 минуты это ровно 24 часа. Сутки. Что-то рвёт соединение раз в сутки.
27 минут назад, Aiden2303 сказал:
[quote]
[/quote]
В это время происходит разрыв pppoe сессии по таймауту для смены ip адреса. Можно попробовать сделать так, что бы сессия заканчивалась и начиналась новая в другое время. Нужно просто просто перезагрузить роутер, например где-нибудь ночью.
4 минуты назад, Илья Картавенко сказал:
Хорошая мысль. Сместить этот разрыв на время когда никто не работает в интернете.
  • Upvote 2
1 час назад, keenet07 сказал:
некоторые провы рвут пппое раз в сутки....
  • Upvote 2
25 минут назад, krass сказал:
Большое всем спасибо!
А если рвёт провайдер (позвоню уточню) сообщений в журнале не должно ведь быть?
Есть несколько кинетиков, на разных провайдерах. Другие стабильно работают без разрывов раз в сутки.
В кинетике изнутри можно отключить обновление IP?
2 минуты назад, Aiden2303 сказал:
У разных провайдеров разный тип подключения. В данном случае PPPOE. В данном случае такое поведение нормально. Соответственно в журнале будет информация о сбытии.
