Петя Думин Posted October 7, 2016 Share Posted October 7, 2016 [error] 1751#0: *17 open() "/opt/share/www/tm" failed (13: Permission denied), client: 192.168.1.33, server: localhost, request: "GET /tm HTTP/1.1", host: "192.168.1.1:88" Подскажите пожалуйста, почему такое может происходить? chmod и chown не помогает. Quote Link to comment Share on other sites More sharing options...
Le ecureuil Posted October 8, 2016 Share Posted October 8, 2016 15 часов назад, Петя Думин сказал: [error] 1751#0: *17 open() "/opt/share/www/tm" failed (13: Permission denied), client: 192.168.1.33, server: localhost, request: "GET /tm HTTP/1.1", host: "192.168.1.1:88" Подскажите пожалуйста, почему такое может происходить? chmod и chown не помогает. chown nobody.nogroup -R /opt/share/www А вообще Quote Link to comment Share on other sites More sharing options...
zyxmon Posted October 8, 2016 Share Posted October 8, 2016 1 час назад, Le ecureuil сказал: chown nobody.nogroup -R /opt/share/www Группы и юзеры в Entware свои. Там не nogroup при установке, а nobody. Quote Link to comment Share on other sites More sharing options...
PoliceMan Posted October 9, 2016 Share Posted October 9, 2016 В 08.10.2016 в 01:47, Петя Думин сказал: [error] 1751#0: *17 open() "/opt/share/www/tm" failed (13: Permission denied), client: 192.168.1.33, server: localhost, request: "GET /tm HTTP/1.1", host: "192.168.1.1:88" Подскажите пожалуйста, почему такое может происходить? chmod и chown не помогает. NTFS+nginx? Quote Link to comment Share on other sites More sharing options...
WMac Posted October 14, 2016 Share Posted October 14, 2016 При переходе по http://192.168.1.1:88/tm/index.php Получаю ошибку Fatal error: Call to a member function prepare() on null in /opt/share/www/tm/class/Database.class.php on line 67 Подскажите где я ошибся. Делал все по инструкции. Quote Link to comment Share on other sites More sharing options...
Softx Posted February 16, 2017 Share Posted February 16, 2017 (edited) Если стоит Entware-3x, то пакет nginx-zyx отсутствует. Вместо него надо ставить пакет nginx... Соответственно минимальный набор пакетов (чтоб запустить), наверное, выглядит так: (TheBB добавь в шапку) --------------- opkg install nginx php5-fastcgi php5-mod-ctype php5-mod-curl php5-mod-dom \ php5-mod-exif php5-mod-fileinfo php5-mod-gd php5-mod-gettext php5-mod-hash \ php5-mod-iconv php5-mod-json php5-mod-mbstring php5-mod-mcrypt php5-mod-pdo \ php5-mod-pdo-mysql php5-mod-session php5-mod-simplexml php5-mod-sockets \ php5-mod-xml php5-mod-xmlreader php5-mod-xmlwriter php5-mod-zip mysql-server -------------- Но даже если все делать по инструкции то: 1. /opt/etc/php5 вообще отсутствует файл php.ini 2. Даже если подкинем мы его туда, то у всех ini внутри идет "перенаправление", к примеру xml.ini внутри: extension=xml.so 1. php.ini нашел где то, и поправил, как в инструкции кинул в /opt/etc/php5 В конце всех операций в Oper(е) получил: Fatal error: Call to undefined function session_id() in /opt/share/www/tm/class/System.class.php on line 530 Как это побороть. У меня стоит Entware-3x + Debian и есть способ решить с ТМ через Debian. Но не хочется "городушки городить" т.к. Debian стоит "прозапас" если какого нибудь пакета, что нужно я в Entware не найду. Но пакет nginx в Entware присутствует. Мне нужна помощь в настройке данного пакета. А с учетом, что Entware-3x (installer-3x.tar.gz) стоит не только у меня, я думаю эта проблема будет решена для ряда пользователей. Edited February 16, 2017 by Softx Quote Link to comment Share on other sites More sharing options...
TheBB Posted February 16, 2017 Author Share Posted February 16, 2017 3 часа назад, Softx сказал: Если стоит Entware-3x, то пакет nginx-zyx отсутствует. Вместо него надо ставить пакет nginx... Когда писался пост, Entware-ng-3x ещё не было. nginx-zyx - это отдельный пакет (в Entware-Keenetic), "разбавленный" патчами для Кинетиков. 3 часа назад, Softx сказал: 1. /opt/etc/php5 вообще отсутствует файл php.uni... где то место с ачипяткой - php.uni ? (не нашёл, а исправлять надо...) 3 часа назад, Softx сказал: В конце всех операций в Oper(е) получил: с этим лучше к автору ТМ (к слову, в owrt/LEDE поддержка php5 прекращена (в Entware-* пока оставлена для совместимости), а как обстоит дружба ТМ с php7 - знает автор ТМ) Quote Link to comment Share on other sites More sharing options...
sla_m Posted April 5, 2017 Share Posted April 5, 2017 Сделал по инструкции, все запускается и через WebGUI работает, но я сделал запуск через cron 01 * * * * root /opt/share/www/tm/engine.php >> /opt/var/log/tm/error.log 2>&1 Но в логе я получаю: /opt/bin/sh: /opt/share/www/tm/engine.php: Permission denied Quote Link to comment Share on other sites More sharing options...
zyxmon Posted April 5, 2017 Share Posted April 5, 2017 Нужно поставить phpN-cli (N=5 или 7 - смотря что стоит) и вызывать "php-cli <path_to_php>". Quote Link to comment Share on other sites More sharing options...
sla_m Posted April 5, 2017 Share Posted April 5, 2017 Большое спасибо, помогло. Может добавить в первый пост, краткую инструкцию, как настроить запуск по расписанию? Quote Link to comment Share on other sites More sharing options...
sla_m Posted May 2, 2017 Share Posted May 2, 2017 Через некоторое время работы, заметил такую особенность, что отваливается процесс php-fcgi. Запускаю руками, и torrentmonitor продолжает работать, куда смотреть? На keenetic кроме torrentmonitor больше ничего не ставил. Quote Link to comment Share on other sites More sharing options...
Softx Posted May 19, 2017 Share Posted May 19, 2017 Кто подскажет/поможет? Сначала все работало нормально. Потом поставил кучку необходимых мне пакетов. После чего набираю в браузере ip.add.re.ss:88/tm и в место показа в браузере index.php - Crome пытается сохранить эту страницу, explorer - просто показывает содержимое файла index.php. Ладно. Набираю ip.add.re.ss:88/tm/index.php то же сохраняет index.php Иду через инет... мой.выделенный.ip.адрес:88/tm/config.php и сохраняется config.php!!! Да с паролями и т.д. жуть. Стоит еще owncloud http://192.168.77.1:88/owncloud - Загружается страница owncloud(а) http://192.168.77.1:88/tm - Пытается сохранить/показать файлы. Переустановку TorrentMonitor пробовал. (mysql> DROP DATABASE tm;), удалял каталог tm, скачивал заново, далее create database tm и все по инструкции. Ничего не помогает. Что может быть? Думаю это безобразие из за одного порта (88)? В эту сторону копать? Если да то где его менять? Quote Link to comment Share on other sites More sharing options...
TheBB Posted May 19, 2017 Author Share Posted May 19, 2017 11 минуту назад, Softx сказал: Что может быть? смотреть логи, если включены, (для php) /opt/var/log/php-errors.log (для nginx) /opt/var/log/nginx/error.log (для lighttpd)... 14 минуты назад, Softx сказал: Думаю это безобразие из за одного порта (88)? В эту сторону копать? Если да то где его менять? 1 нет 2 нет 3 /opt/etc/nginx/nginx.conf (/opt/etc/lighttpd/lighttpd.conf) Quote Link to comment Share on other sites More sharing options...
Softx Posted June 4, 2017 Share Posted June 4, 2017 Новая тестовая прошивка 2.09.B.0.0-0... ----------------------------- TheBB - Прошу добавить в шапку про каталог... Сначала создаем каталог /opt/share/www Далее создаем файл с выводом информации о РНР echo "<?php phpinfo(); ?>" >> /opt/share/www/phpinfo.php ---------------------------- (мучится ведь бедолаги будут ))) -----------------skip------------- Создаём базу данных (БД) mysql_install_db --datadir=/opt/var --basedir=/opt --force И видим, что у нас вместо mysqld пошла - MariaDB: ~ # mysql_install_db --datadir=/opt/var --basedir=/opt --force Installing MariaDB/MySQL system tables in '/opt/var' ... 170605 0:29:45 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release. 170605 0:29:45 [Note] /opt/bin/mysqld (mysqld 5.5.56-MariaDB) starting as process 1908 ... OK Filling help tables... 170605 0:29:45 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release. 170605 0:29:45 [Note] /opt/bin/mysqld (mysqld 5.5.56-MariaDB) starting as process 1915 ... OK To start mysqld at boot time you have to copy support-files/mysql.server to the right place for your system PLEASE REMEMBER TO SET A PASSWORD FOR THE MariaDB root USER ! To do so, start the server, then issue the following commands: '/opt/bin/mysqladmin' -u root password 'new-password' '/opt/bin/mysqladmin' -u root -h Server password 'new-password' Alternatively you can run: '/opt/bin/mysql_secure_installation' which will also give you the option of removing the test databases and anonymous user created by default. This is strongly recommended for production servers. See the MariaDB Knowledgebase at http://mariadb.com/kb or the MySQL manual for more instructions. You can start the MariaDB daemon with: cd '/opt' ; /opt/bin/mysqld_safe --datadir='/opt/var' You can test the MariaDB daemon with mysql-test-run.pl cd '/opt/mysql-test' ; perl mysql-test-run.pl Please report any problems at http://mariadb.org/jira The latest information about MariaDB is available at http://mariadb.org/. You can find additional information about the MySQL part at: http://dev.mysql.com Consider joining MariaDB's strong and vibrant community: https://mariadb.org/get-involved/ Материмся и запускаем сервис /opt/etc/init.d/S70mysqld S70mariadbd Задаем пароль для доступа к БД, удаляем anonymous(ов) и т.д. ~ # mysql_secure_installation А что дальше делать пока не въехал. По ходу Debian на Zyxel накидывать. Но не хочется. Кто уйдет далее до полного старта ТМ на MariaDB отпишитесь. Может выложат инструкцию те, кто то на Lite смог ТМ запустить или на Debian в chroot-среде ... Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 4, 2017 Author Share Posted June 4, 2017 35 минут назад, Softx сказал: ... И видим, что у нас вместо mysqld пошла - MariaDB... А в анонсе предупредили ведь... 37 минут назад, Softx сказал: ... Материмся и запускаем сервис... Была та же беда, когда предложили потестить, всех сдуло с горизонта 40 минут назад, Softx сказал: ... А что дальше делать пока не въехал... То же самое, что и в случае использования mysql 42 минуты назад, Softx сказал: ... Кто уйдет далее до полного старта ТМ на MariaDB отпишитесь... Отписываюсь: трудится(?) с тестового запуска до сих пор... 45 минут назад, Softx сказал: ... Может выложат инструкцию... Обновление реп завершено(?), приступаю к переписыванию... PS swap включать - крайне рекомендовано, особливо для устройств с < 256 MB (прожорлива, зараза) Quote Link to comment Share on other sites More sharing options...
Lordmaster Posted June 5, 2017 Share Posted June 5, 2017 Поразмыслив несколько часов поискал ошибку. Если не запускается, проверьте строчку: pdo_mysql.default_socket=/opt/var/run/mysqld.sock в php.ini Maridb хранит сокет в /opt/tmp/mysql.sock Изменив эту строку (и если мне не изменяет память то еще где то такой же вывод был) все включилось и заработало. Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 5, 2017 Author Share Posted June 5, 2017 добавлено в "шапку" об установке Torrentmonitor на сервер Nginx with PHP7 & SQLite Машка (MariaDB) интересует? Quote Link to comment Share on other sites More sharing options...
Softx Posted June 5, 2017 Share Posted June 5, 2017 (edited) 1. Конечно интересует. Пишите. Будет выбор на чем строить. (Для общего развития посмотрел, сравнил, сделал выводы как, чего и для чего делается и почему работает. У начинающих типо меня (не работает. Всмысле работает пока не начинаю жестко эксперементировать) А то как то все работает.. Скучно... Надо зайти в репу и что нибудь не совместимое поставить. Потом уже "совмещать". 2. Как думаете на чем оптимальнее? Машка вроде прожорлевее SQLite. 3. Прошлый косяк с сохранением в броузере вместо входа на страницу ТМ не нашел. Ну прошивку поменял. Не помогло. Все удалил - бесполезно. Очистил кеш (ВЕЗДЕ) и только тогда смог увидеть ТМ на новой чистой прошивке. До этого кеш чистил - бесполезно. Т.е. после полного обнуления entware и очистки только. У кого такое кроме меня случится, чтоб найти баг: исправляем конфиги, чистим кеш, пробуем... И так по переменке до полного удвл. Я просто кардинально решил подойти к этому т.к. намучился и уже не знал в какую сторону рыть да версия новая вышла)). В сторону апача капать начал... надоело. Заново entware накатить пришлось. Докопался до отказа SSH. (Случайно как то вышло). Edited June 5, 2017 by Softx Quote Link to comment Share on other sites More sharing options...
Softx Posted June 5, 2017 Share Posted June 5, 2017 Keenetic Ultra II + 2.09.B.0.0-0 + MySQL(MariaDB) PHP7 Fatal error: Uncaught Error: Undefined class constant 'MYSQL_ATTR_INIT_COMMAND' in /opt/share/www/tm/class/Database.class.php:20 Stack trace: #0 /opt/share/www/tm/class/Database.class.php(53): Database->__construct() #1 /opt/share/www/tm/class/Database.class.php(60): Database::getInstance() #2 /opt/share/www/tm/class/Database.class.php(65): Database::getDbType() #3 /opt/share/www/tm/class/Database.class.php(90): Database::newStatement('SELECT `val` FR...') #4 /opt/share/www/tm/class/System.class.php(542): Database::getSetting('auth') #5 /opt/share/www/tm/index.php(7): Sys::checkAuth() #6 {main} thrown in /opt/share/www/tm/class/Database.class.php on line 20 Чего может быть? Quote Link to comment Share on other sites More sharing options...
TheBB Posted June 5, 2017 Author Share Posted June 5, 2017 пол дня "мучил" гигу2 (2.06) с Entware-Keenetic, вывалил полные конфиги и... нате-здрасьте. 27 минут назад, Softx сказал: Чего может быть? 2 часа назад, Softx сказал: ... работает пока не начинаю жестко эксперементировать) А то как то все работает.. Скучно... Quote Link to comment Share on other sites More sharing options...
eEye Posted June 25, 2017 Share Posted June 25, 2017 Доброй ночи! Задумался установкой автоматизированного скачивания торрент наткнулся на данную статью (внешняя ссылка habrahabr). Для чего вопрос, можно ли не TorrentMonitor на php, а Monitorrent на python прикрутить к Ultra II, Giga III ? Quote Link to comment Share on other sites More sharing options...
Softx Posted July 3, 2017 Share Posted July 3, 2017 Все по инструкции. Пытаюсь 2 вариант с SQLite PHP7 В конце: http://192.168.77.1:88/tm/ Error!: could not find driver (т.е. у меня SQLite PHP7, как и на машке не пашет ( Quote Link to comment Share on other sites More sharing options...
TheBB Posted July 3, 2017 Author Share Posted July 3, 2017 пропущен(?) `opkg install php7-mod-sqlite3`+*/init.d/*php* restart Quote Link to comment Share on other sites More sharing options...
Softx Posted July 3, 2017 Share Posted July 3, 2017 (edited) 41 минуту назад, TheBB сказал: пропущен(?) `opkg install php7-mod-sqlite3`+*/init.d/*php* restart Доброй ночи. Да, пропустил по ходу и уже исправил "пропуск" ~ # opkg install php7-mod-sqlite3 Installing php7-mod-sqlite3 (7.1.5-1) to root... Downloading http://entware-3x.zyxmon.org/binaries/mipsel/php7-mod-sqlite3_7.1.5-1_mipsel-3x.ipk Configuring php7-mod-sqlite3. ~ # /opt/etc/init.d/S80nginx restart Nginx restarted. ~ # /opt/etc/init.d/S79php-fcgi restart Shutting down php-fcgi... done. Starting php-fcgi... done. Вот только Error!: could not find driver - на том же месте Поудалял, все и установил заново поставил. Получил: 403 Forbidden nginx/1.10.3 Edited July 4, 2017 by Softx Quote Link to comment Share on other sites More sharing options...
sla_m Posted November 23, 2017 Share Posted November 23, 2017 Сегодня переустанавливал TorrentMonitor на Entware-3x, столкнулся с тем, что необходим модуль php7-mod-ctype, добавьте в инструкцию, и еще в инструкции очепятка, надо php7-mod-pdo-mysql 1 Quote Link to comment Share on other sites More sharing options...
stakp Posted November 26, 2017 Share Posted November 26, 2017 Поставил в связке nginx+mariadb, при заходе www.ip/tm - получаю 403 ошибку. В общем, путём просмотра логов, выяснилось, что надо править права всем файлам и каталогам внутри tm. Команда chown nobody.nobody -R /opt/share/www не помогает, делал через mc. После правки всё запустилось, работу ещё не проверял. Quote Link to comment Share on other sites More sharing options...
Screamer89 Posted February 8, 2018 Share Posted February 8, 2018 Помогите пожалуйста настроить rc.unslung и profile Читал вики в гитхабе но не понял куда именно вставлять TZ=:/opt/share/zoneinfo/Asia/Yakutsk и export TZ=:/opt/share/zoneinfo/Asia/Yakutsk После перезагрузки Entware часовой пояс сбрасывается до UTC а не до заданного Asia/Yakutsk.TorrentMonitor ругается на неправильный timezone, было бы легко поправить будь доступ на /etc/localtime Quote Link to comment Share on other sites More sharing options...
TheBB Posted February 8, 2018 Author Share Posted February 8, 2018 ну, с устройством мы определились, осталось выяснить версию прошивки и используемую систему пакетов. Quote Link to comment Share on other sites More sharing options...
Screamer89 Posted February 8, 2018 Share Posted February 8, 2018 Keenetic DSL v2.05(AAGK.0)C7, Entware ставил с этой темы https://forum.keenetic.net/topic/221-репозиторий-entware-keenetic/ Quote Link to comment Share on other sites More sharing options...
TheBB Posted February 8, 2018 Author Share Posted February 8, 2018 opkg update opkg upgrade проверяйте ~ # ~ # date Thu Feb 8 19:56:27 +09 2018 ~ # ~ # php-cli ../share/www/addons/phpinfo.php | grep timezone Default timezone => Asia/Yakutsk date.timezone => Asia/Yakutsk => Asia/Yakutsk ~ # Quote Link to comment Share on other sites More sharing options...
