vpivci Posted August 19, 2022 Share Posted August 19, 2022 8 часов назад, TheBB сказал: Да, потерялся пакет. Загружен... Установил. Запускаю. Теперь валится в процессе установки фронтенда. Попытка раз: Скрытый текст ~ # hass -c /opt/var/lib/homeassistant -vvv --debug 2022-08-19 11:28:09 INFO (MainThread) [homeassistant.bootstrap] Config directory: /opt/var/lib/homeassistant 2022-08-19 11:28:09 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.238 seconds 2022-08-19 11:28:09 INFO (MainThread) [asyncio] execute program '/opt/bin/python3': <_UnixSubprocessTransport pid=24217 running stdin=<_UnixWritePipeTransport fd=10 idle bufsize=0> stdout=<_UnixReadPipeTransport fd=11 polling>> 2022-08-19 11:28:10 INFO (MainThread) [asyncio] <_UnixWritePipeTransport fd=10 idle bufsize=0> was closed by peer 2022-08-19 11:28:10 INFO (MainThread) [asyncio] <_UnixReadPipeTransport fd=11 polling> was closed by peer 2022-08-19 11:28:10 INFO (MainThread) [asyncio] <_UnixSubprocessTransport pid=24217 running stdin=<_UnixWritePipeTransport closed fd=10 closed> stdout=<_UnixReadPipeTransport closing fd=11 idle>> exited with return code 0 2022-08-19 11:28:10 INFO (SyncWorker_0) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant 2022-08-19 11:28:10 INFO (SyncWorker_1) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification 2022-08-19 11:28:10 INFO (MainThread) [homeassistant.setup] Setting up homeassistant 2022-08-19 11:28:10 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds 2022-08-19 11:28:10 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-9' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.145 seconds 2022-08-19 11:28:10 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification 2022-08-19 11:28:10 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds 2022-08-19 11:28:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config 2022-08-19 11:28:11 INFO (SyncWorker_0) [homeassistant.loader] Loaded script from homeassistant.components.script 2022-08-19 11:28:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded scene from homeassistant.components.scene 2022-08-19 11:28:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded tts from homeassistant.components.tts 2022-08-19 11:28:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded automation from homeassistant.components.automation 2022-08-19 11:28:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded http from homeassistant.components.http 2022-08-19 11:28:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded application_credentials from homeassistant.components.application_credentials 2022-08-19 11:28:11 INFO (SyncWorker_0) [homeassistant.loader] Loaded blueprint from homeassistant.components.blueprint 2022-08-19 11:28:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded auth from homeassistant.components.auth 2022-08-19 11:28:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api 2022-08-19 11:28:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded trace from homeassistant.components.trace 2022-08-19 11:28:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud 2022-08-19 11:28:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook 2022-08-19 11:28:11 INFO (SyncWorker_0) [homeassistant.loader] Loaded counter from homeassistant.components.counter 2022-08-19 11:28:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded dhcp from homeassistant.components.dhcp 2022-08-19 11:28:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded energy from homeassistant.components.energy 2022-08-19 11:28:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded history from homeassistant.components.history 2022-08-19 11:28:11 INFO (SyncWorker_0) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder 2022-08-19 11:28:11 INFO (SyncWorker_3) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend 2022-08-19 11:28:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded api from homeassistant.components.api 2022-08-19 11:28:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config 2022-08-19 11:28:11 INFO (SyncWorker_0) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation 2022-08-19 11:28:12 INFO (SyncWorker_3) [homeassistant.loader] Loaded diagnostics from homeassistant.components.diagnostics 2022-08-19 11:28:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace 2022-08-19 11:28:12 INFO (SyncWorker_1) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding 2022-08-19 11:28:12 INFO (SyncWorker_0) [homeassistant.loader] Loaded analytics from homeassistant.components.analytics 2022-08-19 11:28:12 INFO (SyncWorker_3) [homeassistant.loader] Loaded person from homeassistant.components.person 2022-08-19 11:28:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded image from homeassistant.components.image 2022-08-19 11:28:12 INFO (SyncWorker_1) [homeassistant.loader] Loaded search from homeassistant.components.search 2022-08-19 11:28:12 INFO (SyncWorker_3) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log 2022-08-19 11:28:12 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean 2022-08-19 11:28:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_button from homeassistant.components.input_button 2022-08-19 11:28:12 INFO (SyncWorker_1) [homeassistant.loader] Loaded input_datetime from homeassistant.components.input_datetime 2022-08-19 11:28:12 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number 2022-08-19 11:28:12 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select 2022-08-19 11:28:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text 2022-08-19 11:28:12 INFO (SyncWorker_1) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook 2022-08-19 11:28:12 INFO (SyncWorker_3) [homeassistant.loader] Loaded map from homeassistant.components.map 2022-08-19 11:28:12 INFO (SyncWorker_0) [homeassistant.loader] Loaded media_source from homeassistant.components.media_source 2022-08-19 11:28:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app 2022-08-19 11:28:12 INFO (SyncWorker_1) [homeassistant.loader] Loaded tag from homeassistant.components.tag 2022-08-19 11:28:12 INFO (SyncWorker_1) [homeassistant.loader] Loaded my from homeassistant.components.my 2022-08-19 11:28:13 INFO (SyncWorker_0) [homeassistant.loader] Loaded network from homeassistant.components.network 2022-08-19 11:28:13 INFO (SyncWorker_3) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp 2022-08-19 11:28:13 INFO (SyncWorker_2) [homeassistant.loader] Loaded sun from homeassistant.components.sun 2022-08-19 11:28:13 INFO (SyncWorker_1) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health 2022-08-19 11:28:13 INFO (SyncWorker_0) [homeassistant.loader] Loaded timer from homeassistant.components.timer 2022-08-19 11:28:13 INFO (SyncWorker_3) [homeassistant.loader] Loaded usb from homeassistant.components.usb 2022-08-19 11:28:13 INFO (SyncWorker_2) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf 2022-08-19 11:28:13 INFO (SyncWorker_1) [homeassistant.loader] Loaded zone from homeassistant.components.zone 2022-08-19 11:28:13 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.366 seconds 2022-08-19 11:28:14 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.198 seconds 2022-08-19 11:28:14 INFO (MainThread) [homeassistant.bootstrap] Domains to be set up: {'timer', 'usb', 'default_config', 'webhook', 'trace', 'input_boolean', 'input_number', 'input_button', 'mobile_app', 'history', 'auth', 'script', 'my', 'input_datetime', 'image', 'http', 'diagnostics', 'zeroconf', 'application_credentials', 'dhcp', 'scene', 'config', 'media_source', 'ssdp', 'automation', 'system_health', 'sun', 'system_log', 'logbook', 'blueprint', 'device_automation', 'tts', 'counter', 'websocket_api', 'person', 'frontend', 'cloud', 'energy', 'analytics', 'search', 'input_select', 'tag', 'input_text', 'onboarding', 'zone', 'map', 'recorder', 'network', 'lovelace', 'api'} 2022-08-19 11:28:14 INFO (MainThread) [homeassistant.bootstrap] Setting up logging: {'recorder', 'system_log'} 2022-08-19 11:28:31 INFO (MainThread) [homeassistant.setup] Setting up recorder 2022-08-19 11:28:31 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-97' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 17.294 seconds 2022-08-19 11:28:32 INFO (MainThread) [homeassistant.setup] Setting up system_log 2022-08-19 11:28:32 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds 2022-08-19 11:28:32 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-98' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.893 seconds 2022-08-19 11:28:32 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //opt/var/lib/homeassistant/home-assistant_v2.db was shutdown cleanly 2022-08-19 11:28:32 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=2 from 2022-08-19 07:57:16.810575) 2022-08-19 11:28:33 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.6 seconds 2022-08-19 11:28:33 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'usb', 'webhook', 'auth', 'image', 'http', 'diagnostics', 'zeroconf', 'dhcp', 'ssdp', 'config', 'system_log', 'device_automation', 'websocket_api', 'person', 'frontend', 'cloud', 'analytics', 'search', 'onboarding', 'network', 'lovelace', 'api'} 2022-08-19 11:28:33 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.194 seconds 2022-08-19 11:28:33 INFO (MainThread) [homeassistant.setup] Setting up http 2022-08-19 11:28:34 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-138' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-159' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.237 seconds 2022-08-19 11:28:36 INFO (MainThread) [homeassistant.setup] Setting up dhcp 2022-08-19 11:28:36 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds 2022-08-19 11:28:37 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-141' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.032 seconds 2022-08-19 11:28:37 INFO (MainThread) [homeassistant.setup] Setting up device_automation 2022-08-19 11:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds 2022-08-19 11:28:39 INFO (MainThread) [homeassistant.setup] Setting up lovelace 2022-08-19 11:28:39 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-153' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-187' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.283 seconds 2022-08-19 11:28:39 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.2 seconds 2022-08-19 11:28:40 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-138' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-196' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), <9 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.109 seconds 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain http took 6.5 seconds 2022-08-19 11:28:40 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-138' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), <9 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.108 seconds 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setting up webhook 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds 2022-08-19 11:28:40 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-135' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.113 seconds 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setting up auth 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setting up diagnostics 2022-08-19 11:28:40 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-139' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.230 seconds 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setting up config 2022-08-19 11:28:40 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-143' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.115 seconds 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setting up websocket_api 2022-08-19 11:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds 2022-08-19 11:28:41 INFO (MainThread) [homeassistant.setup] Setting up api 2022-08-19 11:28:41 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds 2022-08-19 11:28:41 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-154' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), <2 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.199 seconds 2022-08-19 11:28:48 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-212' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 7.033 seconds 2022-08-19 11:28:48 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-213' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.166 seconds 2022-08-19 11:28:48 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-217' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.106 seconds 2022-08-19 11:28:49 INFO (MainThread) [homeassistant.setup] Setting up image 2022-08-19 11:28:49 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-137' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-255' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.648 seconds 2022-08-19 11:28:49 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 9.1 seconds 2022-08-19 11:28:49 INFO (MainThread) [homeassistant.setup] Setup of domain config took 9.0 seconds 2022-08-19 11:28:51 INFO (MainThread) [homeassistant.setup] Setting up search 2022-08-19 11:28:51 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds 2022-08-19 11:28:51 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-150' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.719 seconds 2022-08-19 11:28:57 INFO (MainThread) [homeassistant.setup] Setting up analytics 2022-08-19 11:28:57 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-149' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-266' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 6.062 seconds 2022-08-19 11:28:57 INFO (SyncWorker_0) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant 2022-08-19 11:28:57 INFO (SyncWorker_3) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa 2022-08-19 11:28:58 INFO (MainThread) [homeassistant.setup] Setup of domain image took 8.4 seconds 2022-08-19 11:28:58 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.7 seconds 2022-08-19 11:28:59 INFO (SyncWorker_0) [homeassistant.loader] Loaded camera from homeassistant.components.camera 2022-08-19 11:29:00 INFO (MainThread) [homeassistant.setup] Setting up usb 2022-08-19 11:29:02 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 2.0 seconds 2022-08-19 11:29:02 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-134' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 3.804 seconds 2022-08-19 11:29:02 INFO (MainThread) [homeassistant.setup] Setting up person 2022-08-19 11:29:02 INFO (MainThread) [homeassistant.setup] Setting up network 2022-08-19 11:29:02 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.1 seconds 2022-08-19 11:29:02 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-152' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), <1 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.106 seconds 2022-08-19 11:29:02 INFO (SyncWorker_3) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player 2022-08-19 11:29:02 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.6 seconds 2022-08-19 11:29:02 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-146' coro=<_async_setup_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/setup.py:145> result=True created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.103 seconds 2022-08-19 11:29:08 INFO (MainThread) [homeassistant.setup] Setting up zeroconf 2022-08-19 11:29:08 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-140' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 5.781 seconds 2022-08-19 11:29:08 INFO (MainThread) [homeassistant.setup] Setting up onboarding 2022-08-19 11:29:17 INFO (MainThread) [homeassistant.setup] Setting up cloud 2022-08-19 11:29:17 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-148' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-310' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 8.274 seconds 2022-08-19 11:29:18 INFO (MainThread) [homeassistant.setup] Setting up ssdp 2022-08-19 11:29:18 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.1 seconds 2022-08-19 11:29:18 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-142' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.141 seconds 2022-08-19 11:29:18 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 10.0 seconds 2022-08-19 11:29:18 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-312' coro=<_ServiceBrowserBase._async_start_query_sender() running at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:445> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.147 seconds 2022-08-19 11:29:18 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 10.1 seconds 2022-08-19 11:29:20 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-313' coro=<SsdpListener.async_start() running at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp_listener.py:517> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[gather.<locals>._done_callback() at /opt/lib/python3.10/asyncio/tasks.py:720] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 1.833 seconds 2022-08-19 11:29:23 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-148' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.223 seconds 2022-08-19 11:29:31 INFO (SyncWorker_3) [homeassistant.util.package] Attempting install of home-assistant-frontend==20220601.0 2022-08-19 11:29:31 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-147' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 8.265 seconds 2022-08-19 11:29:32 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 14.9 seconds 2022-08-19 11:29:32 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-148' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.153 seconds 2022-08-19 11:29:32 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-312' coro=<_ServiceBrowserBase._async_start_query_sender() done, defined at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:442> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.445 seconds 2022-08-19 11:29:32 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=327620.636845403 _weakref_handle((<weakref at 0... at 0x3929530>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.232 seconds 2022-08-19 11:29:33 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.219 seconds 2022-08-19 11:29:33 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-334' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.331 seconds 2022-08-19 11:29:34 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-336' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[shield.<locals>._outer_done_callback() at /opt/lib/python3.10/asyncio/tasks.py:857, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.136 seconds 2022-08-19 11:29:34 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327628.639467514 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.325 seconds 2022-08-19 11:29:34 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.313 seconds 2022-08-19 11:29:35 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-336' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.234 seconds 2022-08-19 11:29:35 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-336' coro=<SsdpAdvertisementListener._async_on_data() done, defined at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:44> result=None created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.175 seconds 2022-08-19 11:29:36 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327631.498077849 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.112 seconds 2022-08-19 11:29:40 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327635.614079794 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.192 seconds 2022-08-19 11:29:48 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327643.79742921 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.105 seconds 2022-08-19 11:29:51 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.243 seconds 2022-08-19 11:29:55 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=327650.322289387 _weakref_handle((<weakref at 0... at 0x3929530>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.115 seconds 2022-08-19 11:29:57 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=327650.544664085 _weakref_handle((<weakref at 0... at 0x2c8f9e8>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 2.152 seconds 2022-08-19 11:29:58 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327651.011371982 _set_result_unless_cancelled(<Future finis...events.py:429>, None) at /opt/lib/python3.10/asyncio/futures.py:308 created at /opt/lib/python3.10/asyncio/tasks.py:601> took 0.187 seconds 2022-08-19 11:29:58 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=327652.443450107 _weakref_handle((<weakref at 0... at 0x3929530>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.145 seconds 2022-08-19 11:29:59 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 1.077 seconds 2022-08-19 11:30:00 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=327655.409924265 _weakref_handle((<weakref at 0... at 0x3929530>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.145 seconds 2022-08-19 11:30:02 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327657.001120393 _set_result_unless_cancelled(<Future finis...events.py:429>, None) at /opt/lib/python3.10/asyncio/futures.py:308 created at /opt/lib/python3.10/asyncio/tasks.py:601> took 0.102 seconds 2022-08-19 11:30:05 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.590 seconds 2022-08-19 11:30:08 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 3.024 seconds 2022-08-19 11:30:09 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-356' coro=<SsdpAdvertisementListener._async_on_data() done, defined at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:44> result=None created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.437 seconds 2022-08-19 11:30:09 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327660.00161875 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.583 seconds 2022-08-19 11:30:10 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.280 seconds 2022-08-19 11:30:12 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.165 seconds 2022-08-19 11:30:15 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=327670.081768465 _weakref_handle((<weakref at 0... at 0x2c8f9e8>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.865 seconds 2022-08-19 11:30:33 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.686 seconds 2022-08-19 11:30:33 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-365' coro=<SsdpAdvertisementListener._async_on_data() done, defined at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:44> result=None created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.139 seconds 2022-08-19 11:30:33 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327688.344283886 _GlobalTaskContext._on_timeout() created at /opt/lib/python3.10/site-packages/homeassistant/util/timeout.py:202> took 0.612 seconds 2022-08-19 11:30:34 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.595 seconds 2022-08-19 11:30:35 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.145 seconds 2022-08-19 11:30:42 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327697.009005305 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.606 seconds 2022-08-19 11:30:42 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.148 seconds 2022-08-19 11:30:56 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.341 seconds 2022-08-19 11:31:03 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.823 seconds 2022-08-19 11:31:19 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.123 seconds 2022-08-19 11:31:30 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327744.118794657 AsyncEngine._async_cache_cleanup() created at /opt/lib/python3.10/site-packages/zeroconf/_core.py:174> took 0.380 seconds 2022-08-19 11:31:33 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=327744.786947917 _weakref_handle((<weakref at 0... at 0x2c8f9e8>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.109 seconds 2022-08-19 11:31:37 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 3.179 seconds 2022-08-19 11:31:38 WARNING (MainThread) [asyncio] Executing <TimerHandle when=327748.2417616012 async_track_point_in_utc_time.<locals>.run_action(<Job HassJobT...at 0x3a00180>>) at /opt/lib/python3.10/site-packages/homeassistant/helpers/event.py:1286 created at /opt/lib/python3.10/site-packages/homeassistant/helpers/event.py:1308> took 0.377 seconds 2022-08-19 11:31:39 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-384' coro=<SsdpAdvertisementListener._async_on_data() done, defined at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:44> result=None created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.742 seconds Segmentation fault Попытка два: Скрытый текст ~ # hass -c /opt/var/lib/homeassistant -vvv --debug 2022-08-19 14:35:15 INFO (MainThread) [homeassistant.bootstrap] Config directory: /opt/var/lib/homeassistant 2022-08-19 14:35:15 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.284 seconds 2022-08-19 14:35:15 INFO (MainThread) [asyncio] execute program '/opt/bin/python3': <_UnixSubprocessTransport pid=31761 running stdin=<_UnixWritePipeTransport fd=10 idle bufsize=0> stdout=<_UnixReadPipeTransport fd=11 polling>> 2022-08-19 14:35:16 INFO (MainThread) [asyncio] <_UnixWritePipeTransport fd=10 idle bufsize=0> was closed by peer 2022-08-19 14:35:16 INFO (MainThread) [asyncio] <_UnixReadPipeTransport fd=11 polling> was closed by peer 2022-08-19 14:35:16 INFO (MainThread) [asyncio] <_UnixSubprocessTransport pid=31761 running stdin=<_UnixWritePipeTransport closed fd=10 closed> stdout=<_UnixReadPipeTransport closed fd=11 closed>> exited with return code 0 2022-08-19 14:35:16 INFO (SyncWorker_0) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification 2022-08-19 14:35:16 INFO (SyncWorker_1) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant 2022-08-19 14:35:16 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification 2022-08-19 14:35:16 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds 2022-08-19 14:35:16 INFO (MainThread) [homeassistant.setup] Setting up homeassistant 2022-08-19 14:35:16 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds 2022-08-19 14:35:16 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-10' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.121 seconds 2022-08-19 14:35:17 INFO (SyncWorker_1) [homeassistant.loader] Loaded scene from homeassistant.components.scene 2022-08-19 14:35:17 INFO (SyncWorker_0) [homeassistant.loader] Loaded tts from homeassistant.components.tts 2022-08-19 14:35:17 INFO (SyncWorker_2) [homeassistant.loader] Loaded script from homeassistant.components.script 2022-08-19 14:35:17 INFO (SyncWorker_3) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config 2022-08-19 14:35:17 INFO (SyncWorker_1) [homeassistant.loader] Loaded automation from homeassistant.components.automation 2022-08-19 14:35:17 INFO (SyncWorker_0) [homeassistant.loader] Loaded http from homeassistant.components.http 2022-08-19 14:35:17 INFO (SyncWorker_2) [homeassistant.loader] Loaded blueprint from homeassistant.components.blueprint 2022-08-19 14:35:17 INFO (SyncWorker_3) [homeassistant.loader] Loaded application_credentials from homeassistant.components.application_credentials 2022-08-19 14:35:17 INFO (SyncWorker_1) [homeassistant.loader] Loaded trace from homeassistant.components.trace 2022-08-19 14:35:17 INFO (SyncWorker_2) [homeassistant.loader] Loaded auth from homeassistant.components.auth 2022-08-19 14:35:17 INFO (SyncWorker_3) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api 2022-08-19 14:35:17 INFO (SyncWorker_0) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud 2022-08-19 14:35:17 INFO (SyncWorker_1) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook 2022-08-19 14:35:17 INFO (SyncWorker_2) [homeassistant.loader] Loaded counter from homeassistant.components.counter 2022-08-19 14:35:17 INFO (SyncWorker_3) [homeassistant.loader] Loaded dhcp from homeassistant.components.dhcp 2022-08-19 14:35:17 INFO (SyncWorker_0) [homeassistant.loader] Loaded energy from homeassistant.components.energy 2022-08-19 14:35:17 INFO (SyncWorker_1) [homeassistant.loader] Loaded history from homeassistant.components.history 2022-08-19 14:35:17 INFO (SyncWorker_2) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder 2022-08-19 14:35:17 INFO (SyncWorker_3) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend 2022-08-19 14:35:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded api from homeassistant.components.api 2022-08-19 14:35:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config 2022-08-19 14:35:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation 2022-08-19 14:35:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded diagnostics from homeassistant.components.diagnostics 2022-08-19 14:35:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace 2022-08-19 14:35:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding 2022-08-19 14:35:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded analytics from homeassistant.components.analytics 2022-08-19 14:35:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded person from homeassistant.components.person 2022-08-19 14:35:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded image from homeassistant.components.image 2022-08-19 14:35:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded search from homeassistant.components.search 2022-08-19 14:35:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log 2022-08-19 14:35:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean 2022-08-19 14:35:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_button from homeassistant.components.input_button 2022-08-19 14:35:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded input_datetime from homeassistant.components.input_datetime 2022-08-19 14:35:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number 2022-08-19 14:35:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select 2022-08-19 14:35:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text 2022-08-19 14:35:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook 2022-08-19 14:35:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded map from homeassistant.components.map 2022-08-19 14:35:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded media_source from homeassistant.components.media_source 2022-08-19 14:35:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app 2022-08-19 14:35:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded tag from homeassistant.components.tag 2022-08-19 14:35:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded my from homeassistant.components.my 2022-08-19 14:35:19 INFO (SyncWorker_3) [homeassistant.loader] Loaded network from homeassistant.components.network 2022-08-19 14:35:19 INFO (SyncWorker_0) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp 2022-08-19 14:35:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded sun from homeassistant.components.sun 2022-08-19 14:35:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health 2022-08-19 14:35:19 INFO (SyncWorker_3) [homeassistant.loader] Loaded timer from homeassistant.components.timer 2022-08-19 14:35:19 INFO (SyncWorker_0) [homeassistant.loader] Loaded usb from homeassistant.components.usb 2022-08-19 14:35:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf 2022-08-19 14:35:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded zone from homeassistant.components.zone 2022-08-19 14:35:19 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.360 seconds 2022-08-19 14:35:20 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.200 seconds 2022-08-19 14:35:20 INFO (MainThread) [homeassistant.bootstrap] Domains to be set up: {'my', 'device_automation', 'image', 'usb', 'search', 'websocket_api', 'application_credentials', 'input_text', 'logbook', 'trace', 'media_source', 'timer', 'scene', 'config', 'input_datetime', 'network', 'sun', 'lovelace', 'system_health', 'history', 'frontend', 'script', 'ssdp', 'dhcp', 'http', 'api', 'diagnostics', 'tts', 'person', 'auth', 'default_config', 'recorder', 'blueprint', 'automation', 'counter', 'system_log', 'input_button', 'input_number', 'mobile_app', 'webhook', 'zone', 'onboarding', 'cloud', 'analytics', 'tag', 'input_boolean', 'map', 'energy', 'zeroconf', 'input_select'} 2022-08-19 14:35:20 INFO (MainThread) [homeassistant.bootstrap] Setting up logging: {'system_log', 'recorder'} 2022-08-19 14:35:21 INFO (MainThread) [homeassistant.setup] Setting up system_log 2022-08-19 14:35:21 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds 2022-08-19 14:35:21 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-97' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.024 seconds 2022-08-19 14:35:37 INFO (MainThread) [homeassistant.setup] Setting up recorder 2022-08-19 14:35:37 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-98' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 16.498 seconds 2022-08-19 14:35:38 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //opt/var/lib/homeassistant/home-assistant_v2.db was shutdown cleanly 2022-08-19 14:35:39 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=3 from 2022-08-19 08:28:31.487622) 2022-08-19 14:35:39 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.6 seconds 2022-08-19 14:35:39 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'device_automation', 'image', 'usb', 'search', 'websocket_api', 'config', 'network', 'lovelace', 'frontend', 'ssdp', 'dhcp', 'http', 'api', 'diagnostics', 'person', 'auth', 'system_log', 'webhook', 'onboarding', 'cloud', 'analytics', 'zeroconf'} 2022-08-19 14:35:39 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.197 seconds 2022-08-19 14:35:41 INFO (MainThread) [homeassistant.setup] Setting up device_automation 2022-08-19 14:35:41 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds 2022-08-19 14:35:41 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-134' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.403 seconds 2022-08-19 14:35:42 INFO (MainThread) [homeassistant.setup] Setting up lovelace 2022-08-19 14:35:42 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-141' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-161' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.035 seconds 2022-08-19 14:35:44 INFO (MainThread) [homeassistant.setup] Setting up dhcp 2022-08-19 14:35:44 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds 2022-08-19 14:35:44 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-144' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.020 seconds 2022-08-19 14:35:44 INFO (MainThread) [homeassistant.setup] Setting up http 2022-08-19 14:35:44 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-145' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-173' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.101 seconds 2022-08-19 14:35:45 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 2.7 seconds 2022-08-19 14:35:46 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-145' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-196' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), <9 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.107 seconds 2022-08-19 14:35:46 INFO (MainThread) [homeassistant.setup] Setup of domain http took 2.2 seconds 2022-08-19 14:35:46 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-145' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), <9 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.127 seconds 2022-08-19 14:35:47 INFO (MainThread) [homeassistant.setup] Setting up websocket_api 2022-08-19 14:35:47 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds 2022-08-19 14:35:48 INFO (MainThread) [homeassistant.setup] Setting up config 2022-08-19 14:35:48 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-139' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.667 seconds 2022-08-19 14:35:48 INFO (MainThread) [homeassistant.setup] Setting up api 2022-08-19 14:35:48 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds 2022-08-19 14:35:48 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-146' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), <2 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.128 seconds 2022-08-19 14:35:48 INFO (MainThread) [homeassistant.setup] Setting up diagnostics 2022-08-19 14:35:49 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-147' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.162 seconds 2022-08-19 14:35:49 INFO (MainThread) [homeassistant.setup] Setting up auth 2022-08-19 14:35:49 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds 2022-08-19 14:35:49 INFO (MainThread) [homeassistant.setup] Setting up webhook 2022-08-19 14:35:49 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds 2022-08-19 14:35:49 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-150' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.169 seconds 2022-08-19 14:35:53 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-204' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 4.570 seconds 2022-08-19 14:35:54 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-205' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.153 seconds 2022-08-19 14:35:54 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-209' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.127 seconds 2022-08-19 14:35:56 INFO (MainThread) [homeassistant.setup] Setting up image 2022-08-19 14:35:56 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-135' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-255' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.140 seconds 2022-08-19 14:35:56 INFO (MainThread) [homeassistant.setup] Setup of domain config took 8.4 seconds 2022-08-19 14:35:57 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 8.1 seconds 2022-08-19 14:35:57 INFO (MainThread) [homeassistant.setup] Setting up search 2022-08-19 14:35:57 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds 2022-08-19 14:35:57 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-137' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.248 seconds 2022-08-19 14:36:04 INFO (MainThread) [homeassistant.setup] Setting up analytics 2022-08-19 14:36:05 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-153' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-260' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 8.021 seconds 2022-08-19 14:36:07 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-270' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 1.521 seconds 2022-08-19 14:36:07 INFO (SyncWorker_2) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant 2022-08-19 14:36:07 INFO (SyncWorker_1) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa 2022-08-19 14:36:07 INFO (MainThread) [homeassistant.setup] Setup of domain image took 10.7 seconds 2022-08-19 14:36:07 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 3.1 seconds 2022-08-19 14:36:07 INFO (SyncWorker_3) [homeassistant.loader] Loaded camera from homeassistant.components.camera 2022-08-19 14:36:08 INFO (MainThread) [homeassistant.setup] Setting up usb 2022-08-19 14:36:09 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 1.5 seconds 2022-08-19 14:36:09 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-136' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.819 seconds 2022-08-19 14:36:09 INFO (MainThread) [homeassistant.setup] Setting up person 2022-08-19 14:36:09 INFO (MainThread) [homeassistant.setup] Setting up network 2022-08-19 14:36:09 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds 2022-08-19 14:36:10 INFO (SyncWorker_0) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player 2022-08-19 14:36:10 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.6 seconds 2022-08-19 14:36:22 INFO (MainThread) [homeassistant.setup] Setting up zeroconf 2022-08-19 14:36:22 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-154' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 12.093 seconds 2022-08-19 14:36:22 INFO (MainThread) [homeassistant.setup] Setting up onboarding 2022-08-19 14:36:29 INFO (MainThread) [homeassistant.setup] Setting up cloud 2022-08-19 14:36:29 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-152' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-310' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 7.056 seconds 2022-08-19 14:36:30 INFO (MainThread) [homeassistant.setup] Setting up ssdp 2022-08-19 14:36:30 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds 2022-08-19 14:36:30 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-143' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.578 seconds 2022-08-19 14:36:30 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-306' coro=<AsyncEngine._async_setup() running at /opt/lib/python3.10/site-packages/zeroconf/_core.py:139> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/zeroconf/_core.py:131> took 0.116 seconds 2022-08-19 14:36:30 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 8.2 seconds 2022-08-19 14:36:30 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 8.2 seconds 2022-08-19 14:36:33 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-152' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.367 seconds 2022-08-19 14:36:33 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-328' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.205 seconds 2022-08-19 14:36:33 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.301 seconds 2022-08-19 14:36:34 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 4.5 seconds 2022-08-19 14:36:45 INFO (SyncWorker_0) [homeassistant.util.package] Attempting install of home-assistant-frontend==20220601.0 2022-08-19 14:36:49 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-142' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 15.379 seconds 2022-08-19 14:36:49 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-312' coro=<_ServiceBrowserBase._async_start_query_sender() done, defined at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:442> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.232 seconds 2022-08-19 14:36:50 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-342' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[shield.<locals>._outer_done_callback() at /opt/lib/python3.10/asyncio/tasks.py:857, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.237 seconds 2022-08-19 14:36:50 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-342' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.130 seconds 2022-08-19 14:36:51 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-342' coro=<SsdpAdvertisementListener._async_on_data() done, defined at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:44> result=None created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.104 seconds 2022-08-19 14:36:53 WARNING (MainThread) [asyncio] Executing <TimerHandle when=338868.181603367 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.107 seconds 2022-08-19 14:36:58 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.320 seconds 2022-08-19 14:37:05 WARNING (MainThread) [asyncio] Executing <TimerHandle when=338880.361289256 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.121 seconds 2022-08-19 14:37:05 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.116 seconds 2022-08-19 14:37:08 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=338883.329787136 _weakref_handle((<weakref at 0... at 0x34f6ae0>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.135 seconds 2022-08-19 14:37:13 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=338887.468753551 _weakref_handle((<weakref at 0... at 0x34f6ae0>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.571 seconds 2022-08-19 14:37:17 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.680 seconds 2022-08-19 14:37:17 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=338890.247755405 _weakref_handle((<weakref at 0... at 0x34f6ae0>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.110 seconds 2022-08-19 14:37:23 WARNING (MainThread) [asyncio] Executing <TimerHandle when=338896.482576556 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 1.981 seconds 2022-08-19 14:37:23 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.151 seconds 2022-08-19 14:37:28 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.135 seconds 2022-08-19 14:37:41 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 3.150 seconds 2022-08-19 14:37:41 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.378 seconds 2022-08-19 14:37:41 WARNING (MainThread) [asyncio] Executing <TimerHandle when=338914.671114552 _GlobalTaskContext._on_timeout() created at /opt/lib/python3.10/site-packages/homeassistant/util/timeout.py:202> took 0.122 seconds 2022-08-19 14:37:46 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=338920.980409707 _weakref_handle((<weakref at 0... at 0x2da00b0>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.440 seconds 2022-08-19 14:37:52 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=338927.447050718 _weakref_handle((<weakref at 0... at 0x2da00b0>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.194 seconds 2022-08-19 14:38:06 WARNING (MainThread) [asyncio] Executing <TimerHandle when=338930.454727214 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 10.689 seconds 2022-08-19 14:38:10 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 2.905 seconds 2022-08-19 14:38:10 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.232 seconds 2022-08-19 14:38:19 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.125 seconds 2022-08-19 14:38:29 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.226 seconds 2022-08-19 14:38:37 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=338972.33633964 _weakref_handle((<weakref at 0... at 0x2da00b0>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.132 seconds 2022-08-19 14:38:42 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 1 - moving forward 2022-08-19 14:38:42 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'my', 'input_text', 'application_credentials', 'logbook', 'trace', 'media_source', 'timer', 'scene', 'input_datetime', 'sun', 'system_health', 'history', 'script', 'tts', 'default_config', 'blueprint', 'automation', 'counter', 'input_button', 'input_number', 'mobile_app', 'zone', 'tag', 'input_boolean', 'map', 'energy', 'input_select'} 2022-08-19 14:38:44 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 2.547 seconds 2022-08-19 14:38:45 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-441' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.199 seconds 2022-08-19 14:38:50 INFO (MainThread) [homeassistant.setup] Setting up input_text 2022-08-19 14:38:50 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-442' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 5.186 seconds 2022-08-19 14:38:51 INFO (MainThread) [homeassistant.setup] Setting up application_credentials 2022-08-19 14:38:52 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-443' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-471' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.152 seconds 2022-08-19 14:38:53 INFO (MainThread) [homeassistant.setup] Setting up trace 2022-08-19 14:38:53 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.2 seconds 2022-08-19 14:38:53 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-445' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.376 seconds 2022-08-19 14:38:54 INFO (MainThread) [homeassistant.setup] Setting up media_source 2022-08-19 14:38:56 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-446' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.981 seconds 2022-08-19 14:38:56 INFO (MainThread) [homeassistant.setup] Setting up timer 2022-08-19 14:38:56 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-447' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-497' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.344 seconds 2022-08-19 14:38:56 INFO (MainThread) [homeassistant.setup] Setting up scene 2022-08-19 14:38:57 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant 2022-08-19 14:38:57 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-448' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[shield.<locals>._outer_done_callback() at /opt/lib/python3.10/asyncio/tasks.py:857, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.470 seconds 2022-08-19 14:38:57 INFO (MainThread) [homeassistant.setup] Setting up input_datetime 2022-08-19 14:38:58 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-449' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.764 seconds 2022-08-19 14:38:58 INFO (MainThread) [homeassistant.setup] Setting up sun 2022-08-19 14:38:58 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds 2022-08-19 14:38:58 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-450' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.216 seconds 2022-08-19 14:38:58 INFO (MainThread) [homeassistant.setup] Setting up system_health 2022-08-19 14:38:59 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-451' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.767 seconds 2022-08-19 14:39:00 INFO (MainThread) [homeassistant.setup] Setting up history 2022-08-19 14:39:00 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.1 seconds 2022-08-19 14:39:00 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-452' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.368 seconds 2022-08-19 14:39:00 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-453' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.107 seconds 2022-08-19 14:39:00 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-454' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.138 seconds 2022-08-19 14:39:01 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-455' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.633 seconds 2022-08-19 14:39:02 INFO (MainThread) [homeassistant.setup] Setting up blueprint 2022-08-19 14:39:02 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds 2022-08-19 14:39:02 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-456' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.094 seconds 2022-08-19 14:39:03 INFO (MainThread) [homeassistant.setup] Setting up counter 2022-08-19 14:39:03 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-458' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-555' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.501 seconds 2022-08-19 14:39:03 INFO (MainThread) [homeassistant.setup] Setting up input_button 2022-08-19 14:39:03 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-459' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.223 seconds 2022-08-19 14:39:03 INFO (MainThread) [homeassistant.setup] Setting up input_number 2022-08-19 14:39:04 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-460' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.098 seconds 2022-08-19 14:39:04 INFO (MainThread) [homeassistant.setup] Setting up zone 2022-08-19 14:39:04 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-462' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-565' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.195 seconds 2022-08-19 14:39:04 INFO (MainThread) [homeassistant.setup] Setting up tag 2022-08-19 14:39:05 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-463' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-566' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.443 seconds 2022-08-19 14:39:05 INFO (MainThread) [homeassistant.setup] Setting up input_boolean 2022-08-19 14:39:05 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-464' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.256 seconds 2022-08-19 14:39:05 INFO (MainThread) [homeassistant.setup] Setting up input_select 2022-08-19 14:39:05 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-467' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.300 seconds 2022-08-19 14:39:05 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: input_text, application_credentials, trace, media_source, timer, scene, scene.homeassistant, input_datetime, sun, system_health, history, blueprint, counter, input_button, input_number, zone, tag, input_boolean, input_select 2022-08-19 14:39:05 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.112 seconds 2022-08-19 14:39:06 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.142 seconds 2022-08-19 14:39:06 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-471' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:123> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.126 seconds 2022-08-19 14:39:06 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-445' coro=<_async_setup_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/setup.py:145> result=True created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.169 seconds 2022-08-19 14:39:07 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-479' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.270 seconds 2022-08-19 14:39:07 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-482' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.204 seconds 2022-08-19 14:39:07 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-483' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.164 seconds 2022-08-19 14:39:08 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-488' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.406 seconds 2022-08-19 14:39:08 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-492' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.306 seconds 2022-08-19 14:39:09 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-495' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.438 seconds 2022-08-19 14:39:10 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-498' coro=<async_setup_platform() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/homeassistant/scene.py:169> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 1.494 seconds 2022-08-19 14:39:11 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-450' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:266> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.376 seconds 2022-08-19 14:39:11 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-504' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.455 seconds 2022-08-19 14:39:11 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-507' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.144 seconds 2022-08-19 14:39:14 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-508' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 2.284 seconds 2022-08-19 14:39:15 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-519' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 1.688 seconds 2022-08-19 14:39:17 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-523' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 1.100 seconds 2022-08-19 14:39:17 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-452' coro=<_async_setup_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/setup.py:145> result=True created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.491 seconds 2022-08-19 14:39:18 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-555' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:123> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.180 seconds 2022-08-19 14:39:18 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-556' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.114 seconds 2022-08-19 14:39:22 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-560' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 4.547 seconds 2022-08-19 14:39:25 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-565' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:123> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.016 seconds 2022-08-19 14:39:25 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-566' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:122> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.496 seconds 2022-08-19 14:39:30 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-567' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 4.134 seconds 2022-08-19 14:39:32 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-568' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 2.144 seconds 2022-08-19 14:39:33 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-569' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.376 seconds 2022-08-19 14:39:34 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-573' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.832 seconds 2022-08-19 14:39:34 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-574' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.263 seconds Segmentation fault Попытка три: Скрытый текст ~ # hass -c /opt/var/lib/homeassistant -vvv --debug 2022-08-19 15:00:33 INFO (MainThread) [homeassistant.bootstrap] Config directory: /opt/var/lib/homeassistant 2022-08-19 15:00:33 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.263 seconds 2022-08-19 15:00:34 INFO (MainThread) [asyncio] execute program '/opt/bin/python3': <_UnixSubprocessTransport pid=332 running stdin=<_UnixWritePipeTransport fd=10 idle bufsize=0> stdout=<_UnixReadPipeTransport fd=11 polling>> 2022-08-19 15:00:34 INFO (MainThread) [asyncio] <_UnixWritePipeTransport fd=10 idle bufsize=0> was closed by peer 2022-08-19 15:00:35 INFO (MainThread) [asyncio] <_UnixReadPipeTransport fd=11 polling> was closed by peer 2022-08-19 15:00:35 INFO (MainThread) [asyncio] <_UnixSubprocessTransport pid=332 running stdin=<_UnixWritePipeTransport closed fd=10 closed> stdout=<_UnixReadPipeTransport closed fd=11 closed>> exited with return code 0 2022-08-19 15:00:35 INFO (SyncWorker_0) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification 2022-08-19 15:00:35 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification 2022-08-19 15:00:35 INFO (SyncWorker_1) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant 2022-08-19 15:00:35 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds 2022-08-19 15:00:35 INFO (MainThread) [homeassistant.setup] Setting up homeassistant 2022-08-19 15:00:35 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds 2022-08-19 15:00:35 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-10' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.122 seconds 2022-08-19 15:00:35 INFO (SyncWorker_0) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config 2022-08-19 15:00:35 INFO (SyncWorker_1) [homeassistant.loader] Loaded automation from homeassistant.components.automation 2022-08-19 15:00:35 INFO (SyncWorker_2) [homeassistant.loader] Loaded tts from homeassistant.components.tts 2022-08-19 15:00:35 INFO (SyncWorker_0) [homeassistant.loader] Loaded scene from homeassistant.components.scene 2022-08-19 15:00:35 INFO (SyncWorker_3) [homeassistant.loader] Loaded script from homeassistant.components.script 2022-08-19 15:00:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded http from homeassistant.components.http 2022-08-19 15:00:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded blueprint from homeassistant.components.blueprint 2022-08-19 15:00:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded application_credentials from homeassistant.components.application_credentials 2022-08-19 15:00:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded trace from homeassistant.components.trace 2022-08-19 15:00:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded auth from homeassistant.components.auth 2022-08-19 15:00:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api 2022-08-19 15:00:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud 2022-08-19 15:00:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook 2022-08-19 15:00:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded counter from homeassistant.components.counter 2022-08-19 15:00:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded dhcp from homeassistant.components.dhcp 2022-08-19 15:00:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded energy from homeassistant.components.energy 2022-08-19 15:00:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded history from homeassistant.components.history 2022-08-19 15:00:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder 2022-08-19 15:00:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend 2022-08-19 15:00:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded api from homeassistant.components.api 2022-08-19 15:00:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded config from homeassistant.components.config 2022-08-19 15:00:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation 2022-08-19 15:00:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded diagnostics from homeassistant.components.diagnostics 2022-08-19 15:00:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace 2022-08-19 15:00:36 INFO (SyncWorker_1) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding 2022-08-19 15:00:36 INFO (SyncWorker_0) [homeassistant.loader] Loaded analytics from homeassistant.components.analytics 2022-08-19 15:00:36 INFO (SyncWorker_3) [homeassistant.loader] Loaded person from homeassistant.components.person 2022-08-19 15:00:36 INFO (SyncWorker_2) [homeassistant.loader] Loaded image from homeassistant.components.image 2022-08-19 15:00:37 INFO (SyncWorker_1) [homeassistant.loader] Loaded search from homeassistant.components.search 2022-08-19 15:00:37 INFO (SyncWorker_0) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log 2022-08-19 15:00:37 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean 2022-08-19 15:00:37 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_button from homeassistant.components.input_button 2022-08-19 15:00:37 INFO (SyncWorker_1) [homeassistant.loader] Loaded input_datetime from homeassistant.components.input_datetime 2022-08-19 15:00:37 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number 2022-08-19 15:00:37 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select 2022-08-19 15:00:37 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text 2022-08-19 15:00:37 INFO (SyncWorker_1) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook 2022-08-19 15:00:37 INFO (SyncWorker_0) [homeassistant.loader] Loaded map from homeassistant.components.map 2022-08-19 15:00:37 INFO (SyncWorker_3) [homeassistant.loader] Loaded media_source from homeassistant.components.media_source 2022-08-19 15:00:37 INFO (SyncWorker_2) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app 2022-08-19 15:00:37 INFO (SyncWorker_1) [homeassistant.loader] Loaded tag from homeassistant.components.tag 2022-08-19 15:00:37 INFO (SyncWorker_0) [homeassistant.loader] Loaded my from homeassistant.components.my 2022-08-19 15:00:37 INFO (SyncWorker_3) [homeassistant.loader] Loaded network from homeassistant.components.network 2022-08-19 15:00:37 INFO (SyncWorker_2) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp 2022-08-19 15:00:37 INFO (SyncWorker_1) [homeassistant.loader] Loaded sun from homeassistant.components.sun 2022-08-19 15:00:37 INFO (SyncWorker_0) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health 2022-08-19 15:00:37 INFO (SyncWorker_3) [homeassistant.loader] Loaded timer from homeassistant.components.timer 2022-08-19 15:00:37 INFO (SyncWorker_2) [homeassistant.loader] Loaded usb from homeassistant.components.usb 2022-08-19 15:00:37 INFO (SyncWorker_1) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf 2022-08-19 15:00:37 INFO (SyncWorker_0) [homeassistant.loader] Loaded zone from homeassistant.components.zone 2022-08-19 15:00:38 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.359 seconds 2022-08-19 15:00:38 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.204 seconds 2022-08-19 15:00:38 INFO (MainThread) [homeassistant.bootstrap] Domains to be set up: {'default_config', 'cloud', 'lovelace', 'person', 'input_button', 'system_log', 'onboarding', 'blueprint', 'map', 'diagnostics', 'api', 'mobile_app', 'http', 'sun', 'zone', 'timer', 'input_select', 'input_text', 'script', 'analytics', 'recorder', 'my', 'image', 'ssdp', 'history', 'usb', 'trace', 'tts', 'webhook', 'websocket_api', 'input_number', 'automation', 'config', 'device_automation', 'input_boolean', 'input_datetime', 'logbook', 'counter', 'media_source', 'energy', 'application_credentials', 'dhcp', 'zeroconf', 'system_health', 'scene', 'search', 'network', 'auth', 'frontend', 'tag'} 2022-08-19 15:00:38 INFO (MainThread) [homeassistant.bootstrap] Setting up logging: {'system_log', 'recorder'} 2022-08-19 15:00:38 INFO (MainThread) [homeassistant.setup] Setting up system_log 2022-08-19 15:00:38 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds 2022-08-19 15:00:48 INFO (MainThread) [homeassistant.setup] Setting up recorder 2022-08-19 15:00:48 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-98' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 9.926 seconds 2022-08-19 15:00:48 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //opt/var/lib/homeassistant/home-assistant_v2.db was shutdown cleanly 2022-08-19 15:00:49 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=5 from 2022-08-19 11:46:46.494946) 2022-08-19 15:00:49 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.7 seconds 2022-08-19 15:00:49 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'cloud', 'lovelace', 'person', 'system_log', 'onboarding', 'diagnostics', 'api', 'http', 'analytics', 'image', 'ssdp', 'usb', 'webhook', 'websocket_api', 'config', 'device_automation', 'dhcp', 'zeroconf', 'search', 'network', 'auth', 'frontend'} 2022-08-19 15:00:49 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.195 seconds 2022-08-19 15:00:51 INFO (MainThread) [homeassistant.setup] Setting up lovelace 2022-08-19 15:00:51 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-135' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-157' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.040 seconds 2022-08-19 15:00:51 INFO (MainThread) [homeassistant.setup] Setting up http 2022-08-19 15:00:51 INFO (MainThread) [homeassistant.setup] Setting up device_automation 2022-08-19 15:00:51 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds 2022-08-19 15:00:51 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-148' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.124 seconds 2022-08-19 15:00:53 INFO (MainThread) [homeassistant.setup] Setting up dhcp 2022-08-19 15:00:53 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds 2022-08-19 15:00:53 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-149' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.841 seconds 2022-08-19 15:00:53 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 2.6 seconds 2022-08-19 15:00:53 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-140' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-196' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), <9 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.106 seconds 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setup of domain http took 2.8 seconds 2022-08-19 15:00:54 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-140' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), <9 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.124 seconds 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setting up diagnostics 2022-08-19 15:00:54 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-138' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.160 seconds 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setting up api 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds 2022-08-19 15:00:54 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-139' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), <2 more>, Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.163 seconds 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setting up webhook 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setting up websocket_api 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setting up config 2022-08-19 15:00:54 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-147' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.121 seconds 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setting up auth 2022-08-19 15:00:54 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds 2022-08-19 15:00:57 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-212' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 2.300 seconds 2022-08-19 15:00:57 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-213' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.168 seconds 2022-08-19 15:00:57 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-217' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.130 seconds 2022-08-19 15:00:58 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 3.8 seconds 2022-08-19 15:00:58 INFO (MainThread) [homeassistant.setup] Setting up image 2022-08-19 15:00:58 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-142' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-255' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.577 seconds 2022-08-19 15:00:58 INFO (MainThread) [homeassistant.setup] Setup of domain config took 4.0 seconds 2022-08-19 15:01:02 INFO (MainThread) [homeassistant.setup] Setting up analytics 2022-08-19 15:01:02 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-141' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-262' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 3.682 seconds 2022-08-19 15:01:02 INFO (MainThread) [homeassistant.setup] Setting up search 2022-08-19 15:01:02 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.1 seconds 2022-08-19 15:01:02 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-151' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.350 seconds 2022-08-19 15:01:03 INFO (SyncWorker_3) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant 2022-08-19 15:01:03 INFO (SyncWorker_2) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa 2022-08-19 15:01:03 INFO (MainThread) [homeassistant.setup] Setup of domain image took 4.7 seconds 2022-08-19 15:01:03 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 1.4 seconds 2022-08-19 15:01:03 INFO (SyncWorker_0) [homeassistant.loader] Loaded camera from homeassistant.components.camera 2022-08-19 15:01:03 INFO (MainThread) [homeassistant.setup] Setting up usb 2022-08-19 15:01:06 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 2.2 seconds 2022-08-19 15:01:06 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-144' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.592 seconds 2022-08-19 15:01:06 INFO (MainThread) [homeassistant.setup] Setting up person 2022-08-19 15:01:06 INFO (MainThread) [homeassistant.setup] Setting up network 2022-08-19 15:01:06 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds 2022-08-19 15:01:06 INFO (SyncWorker_3) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player 2022-08-19 15:01:06 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.7 seconds 2022-08-19 15:01:10 INFO (MainThread) [homeassistant.setup] Setting up zeroconf 2022-08-19 15:01:10 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-150' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 3.353 seconds 2022-08-19 15:01:18 INFO (MainThread) [homeassistant.setup] Setting up cloud 2022-08-19 15:01:18 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-134' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-309' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 7.718 seconds 2022-08-19 15:01:18 INFO (MainThread) [homeassistant.setup] Setting up onboarding 2022-08-19 15:01:19 INFO (MainThread) [homeassistant.setup] Setting up ssdp 2022-08-19 15:01:19 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds 2022-08-19 15:01:19 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-143' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.854 seconds 2022-08-19 15:01:19 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 9.2 seconds 2022-08-19 15:01:19 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-150' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.147 seconds 2022-08-19 15:01:20 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-134' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.088 seconds 2022-08-19 15:01:20 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 2.5 seconds 2022-08-19 15:01:21 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 3.0 seconds 2022-08-19 15:01:21 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-134' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.118 seconds 2022-08-19 15:01:29 INFO (SyncWorker_2) [homeassistant.util.package] Attempting install of home-assistant-frontend==20220601.0 2022-08-19 15:01:29 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-154' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 8.408 seconds 2022-08-19 15:01:30 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-313' coro=<SsdpListener.async_start() done, defined at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp_listener.py:507> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.137 seconds 2022-08-19 15:01:30 WARNING (MainThread) [asyncio] Executing <Handle wait_event_or_timeout.<locals>._handle_timeout_or_wait_complete(<Task finishe...asyncio.py:49>) at /opt/lib/python3.10/site-packages/zeroconf/_utils/asyncio.py:44 created at /opt/lib/python3.10/asyncio/events.py:80> took 0.113 seconds 2022-08-19 15:01:30 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-334' coro=<_async_process_single_integration_platform_component() done, defined at /opt/lib/python3.10/site-packages/homeassistant/helpers/integration_platform.py:28> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.178 seconds 2022-08-19 15:01:30 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-312' coro=<_ServiceBrowserBase._async_start_query_sender() done, defined at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:442> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.210 seconds 2022-08-19 15:01:30 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-311' coro=<Scanner.async_start() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/ssdp/__init__.py:352> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.245 seconds 2022-08-19 15:01:31 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.274 seconds 2022-08-19 15:01:31 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.124 seconds 2022-08-19 15:01:31 WARNING (MainThread) [asyncio] Executing <TimerHandle when=340346.717239253 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.143 seconds 2022-08-19 15:01:32 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.375 seconds 2022-08-19 15:01:34 WARNING (MainThread) [asyncio] Executing <TimerHandle when=340348.85309155 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.265 seconds 2022-08-19 15:01:34 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.170 seconds 2022-08-19 15:01:37 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.121 seconds 2022-08-19 15:01:38 WARNING (MainThread) [asyncio] Executing <TimerHandle when=340353.122494256 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.608 seconds 2022-08-19 15:01:39 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.440 seconds 2022-08-19 15:01:39 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.116 seconds 2022-08-19 15:01:42 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=340356.391963553 _weakref_handle((<weakref at 0... at 0x3649200>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 1.354 seconds 2022-08-19 15:01:43 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.158 seconds 2022-08-19 15:01:46 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.293 seconds 2022-08-19 15:01:47 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-341' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.141 seconds 2022-08-19 15:01:48 WARNING (MainThread) [asyncio] Executing <TimerHandle when=340361.73040837 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.712 seconds 2022-08-19 15:01:50 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-341' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[shield.<locals>._outer_done_callback() at /opt/lib/python3.10/asyncio/tasks.py:857, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 1.227 seconds 2022-08-19 15:01:50 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.160 seconds 2022-08-19 15:01:50 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.482 seconds 2022-08-19 15:01:51 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.156 seconds 2022-08-19 15:01:51 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-341' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[BaseSelectorEventLoop._sock_write_done(28, handle=<Handle BaseS...events.py:291>)(), Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.349 seconds 2022-08-19 15:01:52 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-341' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.216 seconds 2022-08-19 15:01:53 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-341' coro=<SsdpAdvertisementListener._async_on_data() done, defined at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:44> result=None created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.902 seconds 2022-08-19 15:02:03 WARNING (MainThread) [asyncio] Executing <TimerHandle when=340378.84605171 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.146 seconds 2022-08-19 15:02:13 WARNING (MainThread) [asyncio] Executing <TimerHandle cancelled when=340388.792533426 _weakref_handle((<weakref at 0... at 0x34fd458>, '_cleanup_closed')) at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:595 created at /opt/lib/python3.10/site-packages/aiohttp/helpers.py:611> took 0.143 seconds 2022-08-19 15:02:16 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.126 seconds 2022-08-19 15:02:21 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.371 seconds 2022-08-19 15:02:21 WARNING (MainThread) [asyncio] Executing <TimerHandle when=340396.207762012 AsyncEngine._async_cache_cleanup() created at /opt/lib/python3.10/site-packages/zeroconf/_core.py:174> took 0.120 seconds 2022-08-19 15:02:25 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-14' coro=<_async_watch_pending_setups() running at /opt/lib/python3.10/site-packages/homeassistant/bootstrap.py:424> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.243 seconds 2022-08-19 15:02:36 WARNING (MainThread) [asyncio] Executing <TimerHandle when=340410.986062586 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.161 seconds 2022-08-19 15:02:46 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.180 seconds The futex facility returned an unexpected error code.Aborted Quote Link to comment Share on other sites More sharing options...
TheBB Posted August 19, 2022 Share Posted August 19, 2022 попытка нумер 0 Скрытый текст ~ # opkg remove homeassistant homekit scapy yt-dlp Removing package homeassistant from root... Removing package homekit from root... Removing package scapy from root... Removing package yt-dlp from root... ~ # ~ # opkg list-installed | grep pyth | cut -f1 -d' ' | xargs opkg remove --force-depends Removing package libpython3 from root... ... Removing package python3-zeroconf from root... ~ # ~ # opkg list-installed | grep pyt ~ # ~ # rm -rf /opt/lib/python3.10 ~ # ~ # rm -rf /opt/var/lib/homeassistant/* ~ # ~ # opkg install homeassistant Installing homeassistant (2022.6.7-1) to root... Downloading http://bin.entware.net/mipssf-k3.4/test/HA/homeassistant_2022.6.7-1_mips-3.4.ipk ... Configuring homeassistant. *** Prepare your device to use the Home Assistant *** Please read the wiki: https://github.com/Entware/Entware/wiki/Self-installation-of-python-modules ~ # ~ # python -m pip install home-assistant-frontend==20220601.0 Collecting home-assistant-frontend==20220601.0 Using cached home_assistant_frontend-20220601.0-py3-none-any.whl (34.8 MB) Installing collected packages: home-assistant-frontend Successfully installed home-assistant-frontend-20220601.0 WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv WARNING: You are using pip version 22.0.4; however, version 22.2.2 is available. You should consider upgrading via the '/opt/bin/python -m pip install --upgrade pip' command. ~ # ~ # hass -c /opt/var/lib/homeassistant --debug --verbose 2022-08-19 18:04:18 INFO (MainThread) [homeassistant.bootstrap] Config directory: /opt/var/lib/homeassistant 2022-08-19 18:04:18 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.152 seconds 2022-08-19 18:04:18 INFO (MainThread) [asyncio] execute program '/opt/bin/python3': <_UnixSubprocessTransport pid=16718 running stdin=<_UnixWritePipeTransport fd=10 idle bufsize=0> stdout=<_UnixReadPipeTransport fd=11 polling>> 2022-08-19 18:04:19 INFO (MainThread) [asyncio] <_UnixWritePipeTransport fd=10 idle bufsize=0> was closed by peer 2022-08-19 18:04:19 INFO (MainThread) [asyncio] <_UnixReadPipeTransport fd=11 polling> was closed by peer 2022-08-19 18:04:19 INFO (MainThread) [asyncio] <_UnixSubprocessTransport pid=16718 running stdin=<_UnixWritePipeTransport closed fd=10 closed> stdout=<_UnixReadPipeTransport closing fd=11 idle>> exited with return code 0 2022-08-19 18:04:19 INFO (SyncWorker_0) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant 2022-08-19 18:04:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification 2022-08-19 18:04:19 INFO (MainThread) [homeassistant.setup] Setting up homeassistant 2022-08-19 18:04:19 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds 2022-08-19 18:04:19 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-9' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.105 seconds 2022-08-19 18:04:19 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification 2022-08-19 18:04:19 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds 2022-08-19 18:04:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded sun from homeassistant.components.sun 2022-08-19 18:04:19 INFO (SyncWorker_0) [homeassistant.loader] Loaded radio_browser from homeassistant.components.radio_browser 2022-08-19 18:04:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded tts from homeassistant.components.tts 2022-08-19 18:04:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded scene from homeassistant.components.scene 2022-08-19 18:04:19 INFO (SyncWorker_0) [homeassistant.loader] Loaded met from homeassistant.components.met 2022-08-19 18:04:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config 2022-08-19 18:04:19 INFO (SyncWorker_3) [homeassistant.loader] Loaded automation from homeassistant.components.automation 2022-08-19 18:04:19 INFO (SyncWorker_2) [homeassistant.loader] Loaded script from homeassistant.components.script 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded http from homeassistant.components.http 2022-08-19 18:04:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded blueprint from homeassistant.components.blueprint 2022-08-19 18:04:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded application_credentials from homeassistant.components.application_credentials 2022-08-19 18:04:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded trace from homeassistant.components.trace 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded auth from homeassistant.components.auth 2022-08-19 18:04:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api 2022-08-19 18:04:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud 2022-08-19 18:04:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded counter from homeassistant.components.counter 2022-08-19 18:04:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded dhcp from homeassistant.components.dhcp 2022-08-19 18:04:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded energy from homeassistant.components.energy 2022-08-19 18:04:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded history from homeassistant.components.history 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder 2022-08-19 18:04:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend 2022-08-19 18:04:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded api from homeassistant.components.api 2022-08-19 18:04:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded config from homeassistant.components.config 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation 2022-08-19 18:04:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded diagnostics from homeassistant.components.diagnostics 2022-08-19 18:04:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace 2022-08-19 18:04:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded analytics from homeassistant.components.analytics 2022-08-19 18:04:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded person from homeassistant.components.person 2022-08-19 18:04:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded image from homeassistant.components.image 2022-08-19 18:04:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded search from homeassistant.components.search 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log 2022-08-19 18:04:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean 2022-08-19 18:04:20 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_button from homeassistant.components.input_button 2022-08-19 18:04:20 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_datetime from homeassistant.components.input_datetime 2022-08-19 18:04:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number 2022-08-19 18:04:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select 2022-08-19 18:04:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text 2022-08-19 18:04:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook 2022-08-19 18:04:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded map from homeassistant.components.map 2022-08-19 18:04:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded media_source from homeassistant.components.media_source 2022-08-19 18:04:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app 2022-08-19 18:04:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded tag from homeassistant.components.tag 2022-08-19 18:04:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded my from homeassistant.components.my 2022-08-19 18:04:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded network from homeassistant.components.network 2022-08-19 18:04:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp 2022-08-19 18:04:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health 2022-08-19 18:04:21 INFO (SyncWorker_1) [homeassistant.loader] Loaded timer from homeassistant.components.timer 2022-08-19 18:04:21 INFO (SyncWorker_0) [homeassistant.loader] Loaded usb from homeassistant.components.usb 2022-08-19 18:04:21 INFO (SyncWorker_3) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf 2022-08-19 18:04:21 INFO (SyncWorker_2) [homeassistant.loader] Loaded zone from homeassistant.components.zone 2022-08-19 18:04:21 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.353 seconds 2022-08-19 18:04:22 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.217 seconds 2022-08-19 18:04:22 INFO (MainThread) [homeassistant.bootstrap] Domains to be set up: {'auth', 'ssdp', 'lovelace', 'person', 'input_text', 'http', 'tag', 'network', 'image', 'timer', 'input_boolean', 'trace', 'map', 'recorder', 'history', 'tts', 'scene', 'met', 'cloud', 'media_source', 'config', 'zeroconf', 'input_datetime', 'onboarding', 'frontend', 'diagnostics', 'analytics', 'sun', 'radio_browser', 'counter', 'application_credentials', 'zone', 'usb', 'websocket_api', 'device_automation', 'default_config', 'dhcp', 'system_log', 'system_health', 'search', 'input_number', 'input_select', 'my', 'logbook', 'script', 'api', 'mobile_app', 'blueprint', 'input_button', 'webhook', 'automation', 'energy'} 2022-08-19 18:04:22 INFO (MainThread) [homeassistant.bootstrap] Setting up logging: {'recorder', 'system_log'} 2022-08-19 18:04:31 INFO (MainThread) [homeassistant.setup] Setting up recorder 2022-08-19 18:04:31 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-99' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 9.252 seconds 2022-08-19 18:04:31 INFO (MainThread) [homeassistant.setup] Setting up system_log 2022-08-19 18:04:31 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds 2022-08-19 18:04:31 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-100' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.111 seconds 2022-08-19 18:04:32 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 1.1 seconds 2022-08-19 18:04:32 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'auth', 'ssdp', 'lovelace', 'person', 'http', 'network', 'image', 'cloud', 'config', 'zeroconf', 'onboarding', 'frontend', 'diagnostics', 'analytics', 'usb', 'websocket_api', 'device_automation', 'dhcp', 'system_log', 'search', 'api', 'webhook'} 2022-08-19 18:04:32 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.193 seconds 2022-08-19 18:04:33 INFO (MainThread) [homeassistant.setup] Setting up lovelace 2022-08-19 18:04:33 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-138' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-159' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.766 seconds 2022-08-19 18:04:33 INFO (MainThread) [homeassistant.setup] Setting up http 2022-08-19 18:04:34 INFO (MainThread) [homeassistant.setup] Setting up device_automation 2022-08-19 18:04:34 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds 2022-08-19 18:04:34 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-152' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.105 seconds 2022-08-19 18:04:35 INFO (MainThread) [homeassistant.setup] Setting up dhcp 2022-08-19 18:04:35 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds 2022-08-19 18:04:35 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-153' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.404 seconds 2022-08-19 18:04:35 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 2.1 seconds 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setup of domain http took 2.3 seconds 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setting up auth 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setting up config 2022-08-19 18:04:36 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-144' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.118 seconds 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setting up diagnostics 2022-08-19 18:04:36 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-148' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.139 seconds 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setting up websocket_api 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setting up api 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setting up webhook 2022-08-19 18:04:36 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds 2022-08-19 18:04:39 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-206' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 2.384 seconds 2022-08-19 18:04:39 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-207' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.139 seconds 2022-08-19 18:04:39 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-211' coro=<async_setup.<locals>.setup_panel() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/config/__init__.py:42> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.101 seconds 2022-08-19 18:04:40 INFO (MainThread) [homeassistant.setup] Setting up image 2022-08-19 18:04:40 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-142' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-257' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.464 seconds 2022-08-19 18:04:40 INFO (MainThread) [homeassistant.setup] Setup of domain config took 4.2 seconds 2022-08-19 18:04:40 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 4.0 seconds 2022-08-19 18:04:40 INFO (MainThread) [homeassistant.setup] Setting up search 2022-08-19 18:04:40 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds 2022-08-19 18:04:40 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-154' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.140 seconds 2022-08-19 18:04:43 INFO (MainThread) [homeassistant.setup] Setting up analytics 2022-08-19 18:04:43 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-149' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-264' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.519 seconds 2022-08-19 18:04:43 INFO (SyncWorker_2) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant 2022-08-19 18:04:43 INFO (SyncWorker_0) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa 2022-08-19 18:04:43 INFO (MainThread) [homeassistant.setup] Setup of domain image took 3.3 seconds 2022-08-19 18:04:43 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.6 seconds 2022-08-19 18:04:44 INFO (SyncWorker_3) [homeassistant.loader] Loaded camera from homeassistant.components.camera 2022-08-19 18:04:44 INFO (MainThread) [homeassistant.setup] Setting up network 2022-08-19 18:04:44 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds 2022-08-19 18:04:44 INFO (MainThread) [homeassistant.setup] Setting up person 2022-08-19 18:04:44 INFO (MainThread) [homeassistant.setup] Setting up usb 2022-08-19 18:04:45 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 1.0 seconds 2022-08-19 18:04:45 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-150' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.249 seconds 2022-08-19 18:04:45 INFO (SyncWorker_1) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player 2022-08-19 18:04:48 INFO (MainThread) [homeassistant.setup] Setting up zeroconf 2022-08-19 18:04:48 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-145' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 2.267 seconds 2022-08-19 18:04:52 INFO (MainThread) [homeassistant.setup] Setting up cloud 2022-08-19 18:04:52 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-143' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-312' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 4.539 seconds 2022-08-19 18:04:53 INFO (MainThread) [homeassistant.setup] Setting up ssdp 2022-08-19 18:04:53 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds 2022-08-19 18:04:53 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-137' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.456 seconds 2022-08-19 18:04:53 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 5.3 seconds 2022-08-19 18:04:54 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-143' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.597 seconds 2022-08-19 18:04:54 WARNING (MainThread) [homeassistant.setup] Setup of person is taking over 10 seconds. 2022-08-19 18:04:54 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 1.6 seconds 2022-08-19 18:04:54 INFO (MainThread) [homeassistant.setup] Setup of domain person took 10.5 seconds 2022-08-19 18:04:55 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-340' coro=<ZeroconfDiscovery._process_service_update() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/zeroconf/__init__.py:390> result=None created at /opt/lib/python3.10/asyncio/tasks.py:337> took 0.225 seconds 2022-08-19 18:04:55 INFO (MainThread) [homeassistant.setup] Setting up onboarding 2022-08-19 18:04:55 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.1 seconds 2022-08-19 18:04:55 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-147' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.114 seconds 2022-08-19 18:04:55 INFO (SyncWorker_0) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio 2022-08-19 18:04:55 INFO (SyncWorker_3) [homeassistant.loader] Loaded group from homeassistant.components.group 2022-08-19 18:04:55 INFO (SyncWorker_2) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker 2022-08-19 18:04:55 INFO (SyncWorker_1) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom 2022-08-19 18:04:55 INFO (MainThread) [homeassistant.setup] Setting up frontend 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.1 seconds 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'input_text', 'timer', 'tag', 'input_boolean', 'trace', 'map', 'history', 'tts', 'scene', 'met', 'media_source', 'input_datetime', 'sun', 'radio_browser', 'counter', 'application_credentials', 'zone', 'default_config', 'system_health', 'input_number', 'input_select', 'my', 'logbook', 'script', 'mobile_app', 'blueprint', 'input_button', 'automation', 'energy'} 2022-08-19 18:04:56 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:101> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.287 seconds 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setting up input_text 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setting up timer 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setting up tag 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setting up input_boolean 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setting up trace 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.0 seconds 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setting up map 2022-08-19 18:04:56 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setting up history 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds 2022-08-19 18:04:57 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-423' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.104 seconds 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setting up scene 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setting up met 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds 2022-08-19 18:04:57 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-426' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.114 seconds 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setting up media_source 2022-08-19 18:04:57 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-427' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.321 seconds 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setting up input_datetime 2022-08-19 18:04:57 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-428' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.101 seconds 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setting up sun 2022-08-19 18:04:57 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setting up radio_browser 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setup of domain radio_browser took 0.0 seconds 2022-08-19 18:04:59 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-430' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.560 seconds 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setting up counter 2022-08-19 18:04:59 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-431' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-484' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.107 seconds 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setting up application_credentials 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setting up zone 2022-08-19 18:04:59 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-434' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.158 seconds 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setting up system_health 2022-08-19 18:04:59 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-435' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.208 seconds 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setting up input_number 2022-08-19 18:04:59 INFO (MainThread) [homeassistant.setup] Setting up input_select 2022-08-19 18:05:00 INFO (MainThread) [homeassistant.setup] Setting up my 2022-08-19 18:05:00 INFO (MainThread) [homeassistant.setup] Setup of domain my took 0.0 seconds 2022-08-19 18:05:00 INFO (MainThread) [homeassistant.setup] Setting up logbook 2022-08-19 18:05:00 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-439' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.511 seconds 2022-08-19 18:05:00 INFO (MainThread) [homeassistant.setup] Setting up blueprint 2022-08-19 18:05:00 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds 2022-08-19 18:05:00 INFO (MainThread) [homeassistant.setup] Setting up input_button 2022-08-19 18:05:02 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-424' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:195> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.428 seconds 2022-08-19 18:05:02 INFO (SyncWorker_1) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 5.5 seconds 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 5.2 seconds 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 2.9 seconds 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 2.4 seconds 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.setup] Setting up automation 2022-08-19 18:05:02 INFO (SyncWorker_0) [asyncio] Getting address info aa015h6buqvih86i1.api.met.no:443, type=<SocketKind.SOCK_STREAM: 2>, flags=<AddressInfo.AI_ADDRCONFIG: 32> took 212.013ms: [(<AddressFamily.AF_INET: 2>, <SocketKind.SOCK_STREAM: 2>, 6, '', ('157.249.81.141', 443))] 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.setup] Setting up energy 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.setup] Setup of domain energy took 0.0 seconds 2022-08-19 18:05:02 INFO (MainThread) [asyncio] <Server sockets=(<asyncio.TransportSocket fd=29, family=AddressFamily.AF_INET, type=SocketKind.SOCK_STREAM, proto=6, laddr=('0.0.0.0', 8123)>, <asyncio.TransportSocket fd=30, family=AddressFamily.AF_INET6, type=SocketKind.SOCK_STREAM, proto=6, laddr=('::', 8123, 0, 0)>)> is serving 2022-08-19 18:05:02 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123 2022-08-19 18:05:03 INFO (MainThread) [homeassistant.setup] Setup of domain tag took 6.2 seconds 2022-08-19 18:05:03 INFO (MainThread) [homeassistant.setup] Setup of domain application_credentials took 3.7 seconds 2022-08-19 18:05:03 INFO (MainThread) [homeassistant.setup] Setting up script 2022-08-19 18:05:03 INFO (MainThread) [homeassistant.setup] Setting up tts 2022-08-19 18:05:03 INFO (SyncWorker_3) [homeassistant.components.tts] Create cache dir /opt/var/lib/homeassistant/tts 2022-08-19 18:05:03 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-424' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.262 seconds 2022-08-19 18:05:04 INFO (SyncWorker_0) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor 2022-08-19 18:05:04 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 7.8 seconds 2022-08-19 18:05:04 INFO (SyncWorker_2) [asyncio] Getting address info nl1.api.radio-browser.info:443, type=<SocketKind.SOCK_STREAM: 2>, flags=<AddressInfo.AI_ADDRCONFIG: 32> took 228.662ms: [(<AddressFamily.AF_INET: 2>, <SocketKind.SOCK_STREAM: 2>, 6, '', ('95.179.139.106', 443))] 2022-08-19 18:05:04 INFO (MainThread) [homeassistant.setup] Setup of domain counter took 5.4 seconds 2022-08-19 18:05:04 INFO (MainThread) [homeassistant.setup] Setting up sensor 2022-08-19 18:05:04 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds 2022-08-19 18:05:05 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-632' coro=<ConfigEntry.async_setup() done, defined at /opt/lib/python3.10/site-packages/homeassistant/config_entries.py:282> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.234 seconds 2022-08-19 18:05:05 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 2.7 seconds 2022-08-19 18:05:05 INFO (SyncWorker_3) [homeassistant.loader] Loaded notify from homeassistant.components.notify 2022-08-19 18:05:06 INFO (MainThread) [homeassistant.setup] Setup of domain script took 2.8 seconds 2022-08-19 18:05:06 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 9.4 seconds 2022-08-19 18:05:06 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 8.7 seconds 2022-08-19 18:05:06 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 6.5 seconds 2022-08-19 18:05:06 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.energy 2022-08-19 18:05:07 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds. 2022-08-19 18:05:07 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 10.7 seconds 2022-08-19 18:05:07 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 8.0 seconds 2022-08-19 18:05:07 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 7.6 seconds 2022-08-19 18:05:08 INFO (MainThread) [homeassistant.setup] Setting up mobile_app 2022-08-19 18:05:08 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-441' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-772' coro=<Store._async_load() running at /opt/lib/python3.10/site-packages/homeassistant/helpers/storage.py:116> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup(), Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.098 seconds 2022-08-19 18:05:08 INFO (MainThread) [homeassistant.setup] Setup of domain input_button took 8.1 seconds 2022-08-19 18:05:12 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-582' coro=<ConfigEntry.async_setup() done, defined at /opt/lib/python3.10/site-packages/homeassistant/config_entries.py:282> result=None created at /opt/lib/python3.10/asyncio/tasks.py:636> took 3.748 seconds 2022-08-19 18:05:12 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 9.2 seconds 2022-08-19 18:05:13 WARNING (MainThread) [asyncio] Executing <TimerHandle when=3041.733188885007 async_track_point_in_utc_time.<locals>.run_action(<Job HassJobT...ove_horizon>>>) at /opt/lib/python3.10/site-packages/homeassistant/helpers/event.py:1286 created at /opt/lib/python3.10/site-packages/homeassistant/helpers/event.py:1308> took 0.112 seconds 2022-08-19 18:05:13 INFO (SyncWorker_1) [homeassistant.loader] Loaded weather from homeassistant.components.weather 2022-08-19 18:05:13 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 4.7 seconds 2022-08-19 18:05:13 INFO (MainThread) [homeassistant.setup] Setting up weather 2022-08-19 18:05:13 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds 2022-08-19 18:05:13 INFO (MainThread) [homeassistant.setup] Setting up notify 2022-08-19 18:05:13 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds 2022-08-19 18:05:13 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met 2022-08-19 18:05:15 INFO (MainThread) [homeassistant.setup] Setting up default_config 2022-08-19 18:05:15 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-434' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:235> wait_for=<Task pending name='Task-841' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:145> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 1.855 seconds 2022-08-19 18:05:15 INFO (SyncWorker_2) [homeassistant.loader] Loaded backup from homeassistant.components.backup 2022-08-19 18:05:16 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app 2022-08-19 18:05:16 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-841' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:182> wait_for=<_GatheringFuture pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:665> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.112 seconds 2022-08-19 18:05:16 INFO (SyncWorker_3) [asyncio] Getting address info de1.api.radio-browser.info:443, type=<SocketKind.SOCK_STREAM: 2>, flags=<AddressInfo.AI_ADDRCONFIG: 32> took 176.216ms: [(<AddressFamily.AF_INET: 2>, <SocketKind.SOCK_STREAM: 2>, 6, '', ('91.132.145.114', 443))] 2022-08-19 18:05:17 INFO (MainThread) [homeassistant.setup] Setting up backup 2022-08-19 18:05:17 INFO (MainThread) [homeassistant.setup] Setup of domain backup took 0.0 seconds 2022-08-19 18:05:17 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-841' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.243 seconds 2022-08-19 18:05:17 INFO (SyncWorker_1) [homeassistant.loader] Loaded stream from homeassistant.components.stream 2022-08-19 18:05:17 INFO (MainThread) [homeassistant.setup] Setting up stream 2022-08-19 18:05:17 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.1 seconds 2022-08-19 18:05:17 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-863' coro=<_async_setup_component() running at /opt/lib/python3.10/site-packages/homeassistant/setup.py:265> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/site-packages/homeassistant/core.py:482> took 0.104 seconds 2022-08-19 18:05:17 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 1.9 seconds 2022-08-19 18:05:18 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 59.18s 2022-08-19 18:05:18 INFO (MainThread) [homeassistant.core] Starting Home Assistant 2022-08-19 18:05:18 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-1' coro=<setup_and_run_hass() running at /opt/lib/python3.10/site-packages/homeassistant/runner.py:109> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[_run_until_complete_cb() at /opt/lib/python3.10/asyncio/base_events.py:184] created at /opt/lib/python3.10/asyncio/tasks.py:636> took 0.136 seconds 2022-08-19 18:05:18 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast 2022-08-19 18:05:19 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-908' coro=<async_setup.<locals>._async_zeroconf_hass_start() running at /opt/lib/python3.10/site-packages/homeassistant/components/zeroconf/__init__.py:202> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/homeassistant/core.py:450> took 0.124 seconds 2022-08-19 18:05:19 INFO (SyncWorker_1) [homeassistant.loader] Loaded homekit_controller from homeassistant.components.homekit_controller 2022-08-19 18:05:19 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-890' coro=<SsdpAdvertisementListener._async_on_data() running at /opt/lib/python3.10/site-packages/async_upnp_client/advertisement.py:64> wait_for=<Future pending cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> created at /opt/lib/python3.10/site-packages/async_upnp_client/ssdp.py:233> took 0.179 seconds 2022-08-19 18:05:28 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-928' coro=<FlowManager._async_init() done, defined at /opt/lib/python3.10/site-packages/homeassistant/data_entry_flow.py:215> result=(<homeassistan... at 0x3af0010>, {'data_schema': <Schema({'pai... at 0x3afa1f8>, 'description_placeholders': {'name': 'HASS Bridge 3C1A28'}, 'errors': {}, 'flow_id': 'a97461688607...58c31a204c025', ...}) created at /opt/lib/python3.10/asyncio/tasks.py:337> took 8.953 seconds 2022-08-19 18:05:29 INFO (SyncWorker_2) [homeassistant.loader] Loaded keenetic_ndms2 from homeassistant.components.keenetic_ndms2 2022-08-19 18:05:37 INFO (SyncWorker_1) [homeassistant.util.package] Attempting install of ndms2_client==0.1.1 2022-08-19 18:05:37 WARNING (MainThread) [asyncio] Executing <Task pending name='Task-940' coro=<FlowManager._async_init() running at /opt/lib/python3.10/site-packages/homeassistant/data_entry_flow.py:223> wait_for=<Future pending cb=[_chain_future.<locals>._call_check_cancel() at /opt/lib/python3.10/asyncio/futures.py:384, Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/base_events.py:429> cb=[Task.task_wakeup()] created at /opt/lib/python3.10/asyncio/tasks.py:337> took 7.701 seconds 2022-08-19 18:05:37 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 0.138 seconds 2022-08-19 18:05:48 WARNING (MainThread) [asyncio] Executing <TimerHandle when=3076.546323238748 async_track_point_in_utc_time.<locals>.run_action(<Job HassJobT...at 0x1939d10>>) at /opt/lib/python3.10/site-packages/homeassistant/helpers/event.py:1286 created at /opt/lib/python3.10/site-packages/homeassistant/helpers/event.py:1308> took 1.027 seconds 2022-08-19 18:05:54 WARNING (MainThread) [asyncio] Executing <Handle _SelectorDatagramTransport._read_ready() created at /opt/lib/python3.10/asyncio/selector_events.py:254> took 2.120 seconds 2022-08-19 18:06:09 WARNING (MainThread) [asyncio] Executing <TimerHandle when=3099.29319144 _ServiceBrowserBase._async_send_ready_queries_schedule_next() created at /opt/lib/python3.10/site-packages/zeroconf/_services/browser.py:480> took 0.134 seconds [Ctrl+C] ^C2022-08-19 18:08:33 INFO (MainThread) [homeassistant.components.stream] Stopped stream workers 2022-08-19 18:08:33 INFO (Recorder) [homeassistant.components.recorder.pool.RecorderPool] Pool recreating 2022-08-19 18:08:33 WARNING (MainThread) [asyncio] Executing <Task finished name='Task-1796' coro=<async_setup.<locals>.stop_server() done, defined at /opt/lib/python3.10/site-packages/homeassistant/components/http/__init__.py:187> result=None created at /opt/lib/python3.10/site-packages/homeassistant/core.py:450> took 0.163 seconds ~ # ~ # /opt/etc/init.d/S99hass start Starting hass... done. ~ # Версия core-2022.6.7 Тип установки Unknown Среда разработки false Supervisor false Docker false Пользователь root Виртуальное окружение false Версия Python 3.10.5 Семейство операционных систем Linux Версия операционной системы 3.4.113 Архитектура ЦП mips Часовой пояс Europe/Moscow За сим усё. 1 Quote Link to comment Share on other sites More sharing options...
vpivci Posted September 1, 2022 Share Posted September 1, 2022 В 19.08.2022 в 18:55, TheBB сказал: За сим усё. Установка фронтенда валилась, потому что я не отключил zram🤫 Не отключил, потому что не сразу вкурил, что это надо сделать в CLI роутера🤔 Добавил swap-раздел в HDD, отключил zram. Повторил шаги TheBB из "попытка нумер 0". В браузере 404, в логах: ERROR: Cannot set filter: libpcap is not available. Cannot compile filter ! 2022-08-20 11:15:03 ERROR (SyncWorker_0) [scapy.runtime] Cannot set filter: libpcap is not available. Cannot compile filter ! ... 2022-08-20 11:15:17 ERROR (SyncWorker_0) [homeassistant.components.dhcp] Cannot watch for dhcp packets without a functional packet filter: libpcap is not available. Cannot compile filter ! Снёс всё, поставил заново. И, чтобы наверняка, сделал opkg install libcap. Заработало👍 TheBB, спасибо за помощь! Quote Link to comment Share on other sites More sharing options...
udavst Posted September 1, 2022 Share Posted September 1, 2022 (edited) Поставил так: echo "src/gz ha http://bin.entware.net/mipselsf-k3.4/test/HA" >> /opt/etc/opkg.conf opkg update opkg install gcc ldd make gawk sed patch diffutils coreutils-install libffi opkg install python3-pip pip3 install --upgrade pip setuptools python -m pip install pip==21.2.4 opkg install homeassistant /opt/etc/init.d/S99hass start Всё заработало, но не ставятся интеграции: Не удалось загрузить мастер настройки: undefined PS Переустановил по инструкции TheBB, всё заработало. Edited September 2, 2022 by udavst Quote Link to comment Share on other sites More sharing options...
udavst Posted September 5, 2022 Share Posted September 5, 2022 (edited) Подскажите, как подцепить Bluetooth стик. На малинке и банане ставил пакет blueman, и BLE прокидывался в Home Asistant, но тут нет такого пакета. PS Хочется с HA на BT-колонку выводить сообщения и собирать данные с BLE-термометров. Edited September 5, 2022 by udavst Quote Link to comment Share on other sites More sharing options...
ajs Posted September 5, 2022 Share Posted September 5, 2022 1 час назад, udavst сказал: и собирать данные с BLE-термометров Добавить Есп32 с БЛЕ Шлюзом ... Ну или в 2022.09 будет БЛЕ Прокси который будет поддерживать встроенная БТ интеграция ... Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 10, 2022 Share Posted September 10, 2022 bump to 2022.9.1 (aarch64||mipsel) (прим. - отключить "zram") 2 Quote Link to comment Share on other sites More sharing options...
al12s Posted September 10, 2022 Share Posted September 10, 2022 (edited) 3 часа назад, TheBB сказал: bump to 2022.9.1 (aarch64||mipsel) (прим. - отключить "zram") Спасибо. Обновился, полет нормальный! Edited September 10, 2022 by al12s Quote Link to comment Share on other sites More sharing options...
Евгений Шаньгин Posted September 11, 2022 Share Posted September 11, 2022 Добрый день, возможно как-то установить mosquitto broker и zigbee2mqtt на данную сборку (entware)? может через custom_components или еще каким образом? и хватит ли ресурсов Giga 1011 на это дело? Quote Link to comment Share on other sites More sharing options...
SenatoR Posted September 13, 2022 Share Posted September 13, 2022 У меня вопрос, просто для общего развития, почему надо выключать zram? Я просто хорошо знаком с этим модулем, никогда не думал, что он может принести вред, ну кроме доп. нагрузки на CPU, в чем особенность данной ситуации у роутера? Заранее спасибо! Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 14, 2022 Share Posted September 14, 2022 16 часов назад, SenatoR сказал: У меня вопрос, просто для общего развития, почему надо выключать zram? Я просто хорошо знаком с этим модулем, никогда не думал, что он может принести вред, ну кроме доп. нагрузки на CPU, в чем особенность данной ситуации у роутера? Заранее спасибо! Если по простому - "игра в напёрстки": когда напёрсточник (zram) начинает свою игу - "Кручу-верчу, запутать хочу", кладёт шарик (данные) под напёрсток (по адресу), а клиент (приложение) пытается его (шарик-данные) найти. Проблема осложнена тем, что шариков (данных) и напёрстков (адресов) дофигища, и клиенту (приложению) угадать конкретный адрес с конкретными данными... устройство становится колом-раком, пока не придёт "злобный мент" (OOM-Killer) и не разгонит всех нафиг. Для нативной сборки, zram - зло. 1 Quote Link to comment Share on other sites More sharing options...
udavst Posted September 14, 2022 Share Posted September 14, 2022 (edited) В 05.09.2022 в 10:39, ajs сказал: Добавить Есп32 с БЛЕ Шлюзом ... Шлюз на esp32 даёт большие тормоза или может не все пакеты он принимает, а тк собираю по ble не только термометры, а ещё и датчики, открытия двери в т.ч., то это критично. В 05.09.2022 в 10:39, ajs сказал: Ну или в 2022.09 будет БЛЕ Прокси который будет поддерживать встроенная БТ интеграция ... bump to 2022.9.1 - это не оно? И что такое ble-прокси? Ведь в самом entware стик не устанавливается. Edited September 18, 2022 by udavst Quote Link to comment Share on other sites More sharing options...
panama Posted September 14, 2022 Share Posted September 14, 2022 В 10.09.2022 в 18:16, TheBB сказал: bump to 2022.9.1 (aarch64||mipsel) (прим. - отключить "zram") Обновился штатно, все ок! 👌🤝 Quote Link to comment Share on other sites More sharing options...
udavst Posted September 16, 2022 Share Posted September 16, 2022 В 14.09.2022 в 10:51, panama сказал: Обновился штатно opkg remove / opkg install ? Quote Link to comment Share on other sites More sharing options...
iN1KEL Posted September 17, 2022 Share Posted September 17, 2022 19 часов назад, udavst сказал: opkg remove / opkg install ? Ага opkg update /opt/etc/init.d/S99hass stop opkg remove homeassistant opkg upgrade opkg install homeassistant /opt/etc/init.d/S99hass start 1 Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 18, 2022 Share Posted September 18, 2022 bump to 2022.9.4 (aarch64||mipsel) (прим. - отключить "zram") 1 Quote Link to comment Share on other sites More sharing options...
panama Posted September 19, 2022 Share Posted September 19, 2022 В 16.09.2022 в 20:40, udavst сказал: opkg remove / opkg install ? неа, /opt/etc/init.d/S99hass stop opkg update opkg upgrade /opt/etc/init.d/S99hass start Ждать правда долго приходится 1 Quote Link to comment Share on other sites More sharing options...
al12s Posted September 19, 2022 Share Posted September 19, 2022 В 18.09.2022 в 09:41, TheBB сказал: bump to 2022.9.4 (aarch64||mipsel) (прим. - отключить "zram") Спасибо, обновился. Полет нормальны. P.S. только обновился, смотрю 2022.9.5 вышла Quote Link to comment Share on other sites More sharing options...
ajs Posted September 19, 2022 Share Posted September 19, 2022 В 14.09.2022 в 09:31, udavst сказал: Шлюз на esp32 даёт большие тормоза или может не все пакеты он принимает Никаких тормозов, в хозяйстве 2 шлюза, обрабатывают пакеты с разных датчиков, порядка 2000 в час каждый ... В 14.09.2022 в 09:31, udavst сказал: И что такое ble-прокси? Новый компонент ЕСПХоум для новой БТ интеграции в НА ... Quote Link to comment Share on other sites More sharing options...
Jabber Posted September 21, 2022 Share Posted September 21, 2022 Коллеги, а кому-то удалось установить Tuya Local? В процессе первого запуска этого приложения на экране вывалилось что не смогла, в логе появилось куча движений и в финале вот это error: command 'gcc' failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. error: legacy-install-failure Г— Encountered error while trying to install package. в•°в”Ђ> pycryptodome Попытка opkg install gcc завершилась There are no *-dev packages in Entware(with few exceptions)! вот так в подробностях Installing gcc (8.4.0-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/gcc_8.4.0-1_mipsel-3.4.ipk Installing libintl-full (0.21-2) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libintl-full_0.21-2_mipsel-3.4.ipk Installing libbfd (2.38-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libbfd_2.38-1_mipsel-3.4.ipk Installing libopcodes (2.38-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libopcodes_2.38-1_mipsel-3.4.ipk Installing libctf (2.38-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libctf_2.38-1_mipsel-3.4.ipk Installing objdump (2.38-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/objdump_2.38-1_mipsel-3.4.ipk Installing ar (2.38-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/ar_2.38-1_mipsel-3.4.ipk Installing binutils (2.38-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/binutils_2.38-1_mipsel-3.4.ipk Installing libzstd (1.5.2-1) to root... Downloading http://bin.entware.net/mipselsf-k3.4/libzstd_1.5.2-1_mipsel-3.4.ipk Configuring libintl-full. Configuring libbfd. Configuring libopcodes. Configuring libctf. Configuring objdump. Configuring ar. Configuring binutils. Configuring libzstd. Configuring gcc. There are no *-dev packages in Entware(with few exceptions)! Please install headers as described in the wiki: https://github.com/Entware/Entware/wiki И соответственно Tuya Local все еще не работает. Очень нужное, альтернативная LocalTuya подошла не ко всем девайсам. Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 22, 2022 Share Posted September 22, 2022 В 19.09.2022 в 09:57, al12s сказал: P.S. только обновился, смотрю 2022.9.5 вышла пробуйте ))) bump to 2022.9.5 (aarch64||mipsel) (прим. - отключить "zram") Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 22, 2022 Share Posted September 22, 2022 22 часа назад, Jabber сказал: Попытка opkg install gcc завершилась There are no *-dev packages in Entware(with few exceptions)! Так в wiki и написано, что нужно для нативной сборки: gcc, python. Список dev-пакетов ограничен следующими: ~ # opkg list | grep '\-dev ' libncurses-dev - 6.3-1a - Development files for the ncurses library libxml2-dev - 2.9.14-1 - A library for manipulating XML and HTML resources. This package contains the headers and xml2-config binary. perl-dev - 5.28.1-7 - Perl development files python3-dev - 3.10.5-1 - Python 3.10 development files ruby-dev - 3.1.2-1 - Header files for compiling extension modules for the Ruby 3.1 zlib-dev - 1.2.12-1 - zlib is a lossless data-compression library. This package includes the development support files. ~ # 1 Quote Link to comment Share on other sites More sharing options...
Jabber Posted September 26, 2022 Share Posted September 26, 2022 В 22.09.2022 в 10:49, TheBB сказал: Так в wiki и написано, что нужно для нативной сборки: gcc, python. Список dev-пакетов ограничен следующими: ~ # opkg list | grep '\-dev ' libncurses-dev - 6.3-1a - Development files for the ncurses library libxml2-dev - 2.9.14-1 - A library for manipulating XML and HTML resources. This package contains the headers and xml2-config binary. perl-dev - 5.28.1-7 - Perl development files python3-dev - 3.10.5-1 - Python 3.10 development files ruby-dev - 3.1.2-1 - Header files for compiling extension modules for the Ruby 3.1 zlib-dev - 1.2.12-1 - zlib is a lossless data-compression library. This package includes the development support files. ~ # Сам к сожалению не осилю без пошаговой процедуры. Из списка стоит python3-dev Quote Link to comment Share on other sites More sharing options...
al12s Posted September 26, 2022 Share Posted September 26, 2022 установите их, opkg install имя пакета Quote Link to comment Share on other sites More sharing options...
Jabber Posted September 26, 2022 Share Posted September 26, 2022 23 минуты назад, al12s сказал: установите их, opkg install имя пакета Все по списку выше которых нет? Quote Link to comment Share on other sites More sharing options...
TheBB Posted September 27, 2022 Share Posted September 27, 2022 В 21.09.2022 в 12:09, Jabber сказал: Коллеги, а кому-то удалось установить Tuya Local? Эта что ли? Как ставить пытались? С пол пинка залетела, ничего не собирала: дальше не пройду, т.к. нет железа... Quote Link to comment Share on other sites More sharing options...
SenatoR Posted September 28, 2022 Share Posted September 28, 2022 В 14.09.2022 в 11:24, TheBB сказал: Если по простому - "игра в напёрстки": когда напёрсточник (zram) начинает свою игу - "Кручу-верчу, запутать хочу", кладёт шарик (данные) под напёрсток (по адресу), а клиент (приложение) пытается его (шарик-данные) найти. Проблема осложнена тем, что шариков (данных) и напёрстков (адресов) дофигища, и клиенту (приложению) угадать конкретный адрес с конкретными данными... устройство становится колом-раком, пока не придёт "злобный мент" (OOM-Killer) и не разгонит всех нафиг. Для нативной сборки, zram - зло. Большое спасибо! Интересно, конечно, что приводит к такому поведению, т.к. по идее модуль старый и уже давным-давно опробован, но тут видимо сочетание частых обращений + слабого CPU + большое количество адресов. Подскажите, пожалуйста, в этой связи вопрос. Я давно хотел к Home Assistant прикрутить какой-нибудь сервер БД, т.к. чтение с диска идет крайне медленно. У вас не было опыта реальной работы какого-нибудь MariaDB на Giga с базой данных и частотой обращений, характерной для HA? Я боюсь, что все колом встанет мгновенно как по причине памяти, так и по причине CPU. Quote Link to comment Share on other sites More sharing options...
Jabber Posted September 28, 2022 Share Posted September 28, 2022 (edited) Вот эта Tuya Local позволяет управлять девайсами локально, а не через облако как оригинальная интеграция, поддерживает заметно больше девайсов чем TuyaLocal (устанавливалась успешно) Заселяется через HACS, затем стандартным путем - Запускается установка И через некоторое время заканчивается вот этим Вместо последнего варианта должно появится окно с вводом разных ID и паролей и тд.. В процессе установки на экране браузера появляется "Соединение потеряно" - websocket connection faled core.110d7967.js а в консоли запуска HA с дебагингом INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [73040344] Connection closed by client И все это видимо в процессе установки 2022-09-28 20:29:28.483 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pycryptodome~=3.15.0: ERROR: Operation cancelled by user Edited September 28, 2022 by Jabber Quote Link to comment Share on other sites More sharing options...
Jabber Posted September 29, 2022 Share Posted September 29, 2022 (edited) 14 часа назад, Jabber сказал: В процессе установки на экране браузера появляется "Соединение потеряно" - websocket connection faled core.110d7967.js а в консоли запуска HA с дебагингом INFO (MainThread) [homeassistant.components.websocket_api.http.connection] [73040344] Connection closed by client И все это видимо в процессе установки 2022-09-28 20:29:28.483 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pycryptodome~=3.15.0: ERROR: Operation cancelled by user Похоже дело было в способе подключения, сидя в локалке с сервером заходил браузером по имени сервера через keen.dns, соединение падало, установка приложения замирала.. Вошел локально, запустил, несколько минут подождал, вероятно что-то доставлялось, так как ранее в процессе с установкой Tuya Local были неудачные попытки установки pycryptodome: 2022-09-28 20:27:58.681 INFO (SyncWorker_3) [homeassistant.util.package] Attempting install of pycryptodome~=3.15.0 2022-09-28 20:29:28.483 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pycryptodome~=3.15.0: ERROR: Operation cancelled by user Traceback (most recent call last): И соответственно перед установкой Tuya Local добавить opkg install gcc который ранее был затребован при установке ycryptodome. Установка пакета gcc заканчивается этим - There are no *-dev packages in Entware(with few exceptions)! Please install headers as described in the wiki:https://github.com/Entware/Entware/wiki Можно игнорировать, в Tuya Local девайсы добавляются, все работает. Итак, если совсем кратко, для установки Tuya Local - 1. Локальное подключение, не должно быть отвалов от сервера. 2. opkg install gcc сообщение There are no *-dev packages in Entware(with few exceptions)! игнорируем 3. Устанавливаем Tuya Local, первый запуск долго, терпеливо ждем, окно браузера не закрываем. Видео инструкция установки и настройки Tuya Local Первый запуск после установки должен заканчиваться таким окном Edited September 29, 2022 by Jabber Quote Link to comment Share on other sites More sharing options...
SenatoR Posted October 2, 2022 Share Posted October 2, 2022 В 28.09.2022 в 22:44, SenatoR сказал: Подскажите, пожалуйста, в этой связи вопрос. Я давно хотел к Home Assistant прикрутить какой-нибудь сервер БД, т.к. чтение с диска идет крайне медленно. У вас не было опыта реальной работы какого-нибудь MariaDB на Giga с базой данных и частотой обращений, характерной для HA? Я боюсь, что все колом встанет мгновенно как по причине памяти, так и по причине CPU. Может у кого-нибудь был реальный опыт? Или все используют штатный db файл? Я поставил mariadb и она даже работает, но боюсь мигрировать, т.к. времени на дамп уйдет уйма, а толку может и не быть вообще. Quote Link to comment Share on other sites More sharing options...
