Ahmed Ensar Posted August 27, 2022 Posted August 27, 2022 Google Translate: I don't understand what is this?. Router orange light is on.
0 PriSonerS61 Posted August 27, 2022 Posted August 27, 2022 (edited) Dpn = device privacy notice As far as I understand, it's like a contract. Updated and causing this error. I entered "dpn accept" to accept, no results. When I entered the "show dpn document" command, I got a no content message... For now I'm back to 3.9 alpha 6 version again. I will wait for the bug to be fixed. By the way, I already reported the error. #592179 Edited August 27, 2022 by PriSonerS61 1
0 Ahmed Ensar Posted August 27, 2022 Author Posted August 27, 2022 41 minutes ago, PriSonerS61 said: Dpn = device privacy notice As far as I understand, it's like a contract. Updated and causing this error. I entered "dpn accept" to accept, no results. When I entered the "show dpn document" command, I got a no content message... For now I'm back to 3.9 alpha 6 version again. I will wait for the bug to be fixed. By the way, I already reported the error. #592179 Evet dediğin gibi bende sözleşmeden dolayı hata verdi sanıyorum. mesajı google yamuk çevirmiş 🙂. Sürüm düşürmeye gerek yok benim için şuan internetde bir sorun yok çalışıyor. Sadece turuncu ışık yanıyor.
0 KYTECHNGAMING Posted August 27, 2022 Posted August 27, 2022 1 hour ago, Ahmed Ensar said: Evet dediğin gibi bende sözleşmeden dolayı hata verdi sanıyorum. mesajı google yamuk çevirmiş 🙂. Sürüm düşürmeye gerek yok benim için şuan internetde bir sorun yok çalışıyor. Sadece turuncu ışık yanıyor. this will cause keendns services to not work.
0 Ahmed Ensar Posted August 27, 2022 Author Posted August 27, 2022 Just now, KYTECHNGAMING said: this will cause keendns services to not work. Evet cloud hizmetleri çalışmıyor ama bu internet kullanmama engel değil. Sorun düzeltilene kadar bekleyeceğim.
0 admin Posted August 27, 2022 Posted August 27, 2022 Please, reinstall 3.9 Alpha 7 from the server. We've recently published a hotfix with the same version title. First, you need to install some older backup firmware (hopefully, you saved it), and then update to the current draft version. 3
0 Ahmed Ensar Posted August 27, 2022 Author Posted August 27, 2022 20 minutes ago, admin said: Please, reinstall 3.9 Alpha 7 from the server. We've recently published a hotfix with the same version title. First, you need to install some older backup firmware (hopefully, you saved it), and then update to the current draft version. 🙄 👍
Ahmed Ensar
Google Translate:
6 answers to this question
