yes, i know, it sounds crazy, but it really looks like this
steps to reproduce:
1. Buy 4-pack of voyager pro.
2. take one as main router, configure it, etc.
3. take another one from the box. turn switch to B, connect to network, see button "accure" in web-interface of main switch.
till this step all ok.
BAD step - 4. change ip address of main router (this is easiest step to reproduce bug)
oops, all extenders are gone. is looks ok for this step, but ... now you are in stuck. you lost all extenders as extender. now - forever.
what i try:
- reset extenders by pressing reset button. indicator blinking for some seconds, and return to amber. after some time devices are switches to "dumb access point". Whey are visible in wifi, i can connect to them (by password on back) and get access to network by main router. but i cannot access to dashboard of "damaged switch"
and sure, no any sign in "Mesh Wi-Fi System" page
- turn switch to position A. they are start working as usual router, I can access them, configure, etc. I can even ask "reset to factory state" - all ok, they refreshed, I got initial startup wizard, etc... No extender mode, only router. For extender mode - turn switch
- return switch to position B - still no luck. no any sign of device. you can reset it again by button or repeat reset to factory from router mode - it does not matter. amber light and all
kiltum
steps to reproduce:
what i try:
Now I has 7 "routers" and no extenders
OS 4.0.7
12 answers to this question
