4.14 alpha 13 выход в интернет сломался насовсем
t800
Версия нормально установилась, но насмерть убила интенет: сначала роутер писал, что соединение установлено, но без выхода в интернет, после перезагрузки пишет да pppoe «выключено». Включить не удалось
Edited by t800
  • Need more info 1
14 answers to this question
  • 2
В 20.10.2023 в 17:41, admin сказал:
Резюме такое, что при загрузке систему клинит на разрешении имен DoT/DoH-серверов, особенно если их много, и если настроены политики. Будет добавлена асинхронность в этом месте. В 4.1 Alpha 14 должно стать заметно лучше.
Лучше не стало.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy1": using "8.8.8.8:853:8.8.8.8" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy1": using "8.8.4.4:853:8.8.4.4" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy1": using "1.0.0.1:853:1.0.0.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy1": using "1.1.1.1:853:1.1.1.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy2": using "8.8.8.8:853:8.8.8.8" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy2": using "8.8.4.4:853:8.8.4.4" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy2": using "1.0.0.1:853:1.0.0.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy2": using "1.1.1.1:853:1.1.1.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy3": using "8.8.8.8:853:8.8.8.8" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy3": using "8.8.4.4:853:8.8.4.4" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy3": using "1.0.0.1:853:1.0.0.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy3": using "1.1.1.1:853:1.1.1.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy4": using "8.8.8.8:853:8.8.8.8" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy4": using "8.8.4.4:853:8.8.4.4" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy4": using "1.0.0.1:853:1.0.0.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy4": using "1.1.1.1:853:1.1.1.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy5": using "8.8.8.8:853:8.8.8.8" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy5": using "8.8.4.4:853:8.8.4.4" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy5": using "1.0.0.1:853:1.0.0.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::DotConfigurator: "Policy5": using "1.1.1.1:853:1.1.1.1" as upstream.
[I] Oct 22 00:17:45 ndm: Dns::Secure::Tools: fallback to recursive DNS to resolve "dns.google".
[I] Oct 22 00:17:45 ndm: Dns::Secure::Tools: unable to obtain addresses for "dns.google".
[I] Oct 22 00:17:45 ndm: Dns::Manager: rescheduling DNS-over-HTTPS bootstrap.
[I] Oct 22 00:17:45 ndm: Network::Interface::Ip: "UsbQmi1": IP address cleared.
[I] Oct 22 00:17:45 ndm: Network::Interface::Ip: "UsbQmi1": removing default route via UsbQmi1.
[I] Oct 22 00:17:47 stubby: starting Stubby 0.4.0
[I] Oct 22 00:17:47 stubby: Core::Syslog: last message repeated 20 times.
[I] Oct 22 00:17:48 stubby: Core::Syslog: last message repeated 6 times.
[I] Oct 22 00:19:26 stubby: starting Stubby 0.4.0
[I] Oct 22 00:19:26 stubby: Core::Syslog: last message repeated 2 times.
[I] Oct 22 00:19:26 ndm: Network::Interface::Usb: "UsbQmi1": started 5000 ms. power cycle.
Селф-теста пока нет и не будет, мне надо оперативно восстановить интернет, откат на 4.0.4 не помог pppoe фатально не включается. Так качественно альфы мне ещё ни разу не ломали сеть
11 минуту назад, t800 сказал:
KN2710 c PPPoE без проблем, канал работает.
1 час назад, vasek00 сказал:
Выяснилось, что не проходила команда Up из web-интерфейса, ну и конфигурация погибла при откате.
В 13 альфе явно не работает коннект с DOH/DOT серверами. Вообще что-то сильно сломано было с DNS, рутер писал "нет доступа в интернет", не мог ни обновить компоненты, ни прошивку с любого канала вытянуть.
Только что, n1ck222 сказал:
1810 giga3 обновились без проблем…
Складывается ощущение, что работа DNS, DOH, DOT сильно зависит от модели рутера.
В 20.10.2023 в 16:41, admin сказал:
В 4.1 Alpha 15 при активном Ping Check у основного провайдера соединение не поднимается, как только отключаю ему Ping Check тут же соединение устанавливается. Self-test приложил следующим постом.
как раз баг проявился после перезагрузки роутера с 4.1 Alpha 14, обновление на 4.1 Alpha 15 ситуацию не исправило.
Edited by bigpu
Вероятно столкнулся с той же проблемой на stable 4.0.5. Высокая (23-29%) загрузка процессора, много DoT/DoH-серверов, которые не отвечали. Отвал сети. Помогло ручное удаление DoT/DoH-серверов, переключение на авто-dns провайдера, перезагрузка роутера
Начиная с 4.1а13 и по 4.1а19 при установленном DOH, фильтрации контента, игнорировании DNS провайдера доступа в интернет нет. При возврате на 4.0.5, 4.0.7 доступ в интернет появляется.
В 29.10.2023 в 08:41, bigpu сказал:
В 4.1 Beta 0.1 наконец исправлено, спасибо!
