Albram Posted July 23 Share Posted July 23 В 20.07.2024 в 15:42, Jokes сказал: Правильно я понимаю, что поставить сейчас Entware на 1811 не возможно ? Вам сюда. Quote Link to comment Share on other sites More sharing options...
Mihan Posted August 1 Share Posted August 1 (edited) Здравствуйте. В Entware есть свои настройки DNS ? Нашёл, как и в любом Linux /etc/resolv.conf 😄 Edited August 1 by Mihan Quote Link to comment Share on other sites More sharing options...
Mihan Posted August 4 Share Posted August 4 Ещё раз здравствуйте Подскажите пожалуйста как сделать так, чтобы при запуске роутера выполнялись 2 команды? Quote Link to comment Share on other sites More sharing options...
Artanisky Posted August 10 Share Posted August 10 Здравствуйте. После перезапуска роутера entware не включается. Еще до перезапуска в ssh выводил Segmentation fault. Куда копать что исправить проблему? [I] Aug 10 22:50:20 ndm: UPnP::Service: "System": forward rule added: tcp FastEthernet0/Vlan2 -> 192.168.1.116:32400. [I] Aug 10 22:50:20 ndhcps: sending ACK of 192.168.1.61 to 4e:84:eb:77:cf:ac. [I] Aug 10 22:54:05 ndm: Opkg::Manager: unmount existing /opt disk: 32b9b7eb-cc8e-b447-a55d-cf5d0851d11e:/. [C] Aug 10 22:54:05 kernel: EXT4-fs error (device sda1): __ext4_iget:4641: inode #262266: comm ndm: bad extra_isize (418 != 256) [C] Aug 10 22:54:05 ndm: Process: system failed [0xcffd0ab9]. [E] Aug 10 22:54:05 ndm: Process: unable to create and initialize "Opkg shell" process. [E] Aug 10 22:54:05 ndm: Io::Process: "Opkg shell" is broken. [E] Aug 10 22:54:05 ndm: Opkg::Manager: process /opt/etc/init.d/rc.unslung: failed to start. [I] Aug 10 22:54:05 ndm: Opkg::Manager: disk unmounted. [I] Aug 10 22:54:05 ndm: Opkg::Manager: disk is unset. [I] Aug 10 22:54:05 ndm: Opkg::Manager: init script reset to default: /opt/etc/initrc. [I] Aug 10 22:54:05 ndm: Core::System::StartupConfig: saving (http/rci). [I] Aug 10 22:54:10 ndm: Opkg::Manager: disk is set to: 32b9b7eb-cc8e-b447-a55d-cf5d0851d11e:/. [I] Aug 10 22:54:10 kernel: EXT4-fs (sda1): re-mounted. Opts: (null) [I] Aug 10 22:54:10 ndm: Opkg::Manager: /tmp/mnt/32b9b7eb-cc8e-b447-a55d-cf5d0851d11e mounted to /tmp/mnt/32b9b7eb-cc8e-b447-a55d-cf5d0851d11e. [I] Aug 10 22:54:10 ndm: Opkg::Manager: /tmp/mnt/32b9b7eb-cc8e-b447-a55d-cf5d0851d11e mounted to /opt/. [I] Aug 10 22:54:10 ndm: Opkg::Manager: /tmp/mnt/32b9b7eb-cc8e-b447-a55d-cf5d0851d11e initialized. [I] Aug 10 22:54:10 ndm: Opkg::Manager: configured init script: "/opt/etc/init.d/rc.unslung". [C] Aug 10 22:54:10 kernel: EXT4-fs error (device sda1): __ext4_iget:4641: inode #262266: comm ndm: bad extra_isize (418 != 256) [C] Aug 10 22:54:10 ndm: Process: system failed [0xcffd0ab9]. [E] Aug 10 22:54:10 ndm: Process: unable to create and initialize "Opkg shell" process. [E] Aug 10 22:54:10 ndm: Io::Process: "Opkg shell" is broken. [E] Aug 10 22:54:10 ndm: Opkg::Manager: process /opt/etc/init.d/rc.unslung: failed to start. [I] Aug 10 22:54:10 ndm: Core::System::StartupConfig: configuration saved. [I] Aug 10 22:54:10 ndm: Core::System::StartupConfig: saving (http/rci). [I] Aug 10 22:54:15 ndm: Core::System::StartupConfig: configuration saved. [I] Aug 10 22:56:07 ndm: UPnP::Service: "System": redirect and forward rules deleted: tcp 29971. [I] Aug 10 22:56:07 ndm: UPnP::Service: "System": redirect rule added: tcp FastEthernet0/Vlan2:29971 -> 192.168.1.116:32400. [I] Aug 10 22:56:07 ndm: UPnP::Service: "System": forward rule added: tcp FastEthernet0/Vlan2 -> 192.168.1.116:32400. Quote Link to comment Share on other sites More sharing options...
Maksim Smirnov Posted August 23 Share Posted August 23 В 15.01.2024 в 00:48, Arabezar сказал: Отвечаю сам себе... переустановить Entware просто: - отсоединить Накопитель в OPKG (значение "Не выбран") - вытащить из роутера USB, форматнуть раздел USB на компе, вставить USB обратно в роутер - снова подключить Накопитель в OPKG - установить, как описано, Entware Т.к. "Сервер SSH" у меня уже установлен, то SSH Entware поднялся на 222 порту, поэтому соединение установилось без проблем. Вот за это спасибо. Спрашивал в другой группе, там никто не знал. Quote Link to comment Share on other sites More sharing options...
TheBB Posted August 27 Share Posted August 27 В 10.08.2024 в 14:07, Artanisky сказал: [C] Aug 10 22:54:10 kernel: EXT4-fs error (device sda1): __ext4_iget:4641: inode #262266: comm ndm: bad extra_isize (418 != 256) Quote Link to comment Share on other sites More sharing options...
Daurus Posted August 28 Share Posted August 28 Доброго времени суток. Устанавливаю Entware по этой инструкции Модель Giga (KN-1011) EAEU, версия ос 4.1.7. Ставлю на флешку sandisk 32 ГБ usb 3.0, порт тоже 3.0. Название "sandisk". Пакеты все нужные включены. Дал доступы на чтение и запись флешки. Создал install папку, подкинул mipsel-installer.tar.gz. Выбираю в OPKG флешку. Вижу такой лог: Скрытый текст Opkg::Manager: disk is set to: SanDisk32:/. Авг 28 21:32:45 ndm Opkg::Manager: init script reset to default: /opt/etc/initrc. Авг 28 21:32:45 ndm Core::System::StartupConfig: saving (http/rci). Авг 28 21:32:45 ndm Opkg::Manager: /tmp/mnt/66CF-5C57 mounted to /tmp/mnt/66CF-5C57. Авг 28 21:32:45 ndm Opkg::Manager: /tmp/mnt/66CF-5C57 mounted to /opt/. Авг 28 21:32:45 npkg inflating "mipsel-installer.tar.gz". Авг 28 21:32:45 npkg failed to inflate "mipsel-installer.tar.gz": bin/telnet: operation not permitted. Авг 28 21:32:45 ndm Opkg::Manager: system failed [0xcffd0259], exit code 147. Авг 28 21:32:45 ndm Opkg::Manager: invalid initrc "/opt/etc/initrc": no such file or directory, trying /opt/etc/init.d/. Авг 28 21:32:49 ndm Core::System::StartupConfig: configuration saved. Ставлю тот же архив в nand память - всё проходит успешно. Порезул флешку до ~12 ГБ, тот же лог: Цитата failed to inflate "mipsel-installer.tar.gz": bin/telnet: operation not permitted Пробовал второй usb порт с 2.0, тот же лог. Пробовал FAT32. Форматировал и macOS и windows 10. Подскажите пожалуйста, куда еще копнуть можно? (еще ssd внешний пробовал подкинуть, но он подлагивает и результат такой же) Quote Link to comment Share on other sites More sharing options...
Denis P Posted August 29 Share Posted August 29 (edited) 5 часов назад, Daurus сказал: Пробовал FAT32 А надо ext4. Edited August 29 by Denis P Quote Link to comment Share on other sites More sharing options...
Daurus Posted August 31 Share Posted August 31 И Ext и Fat32. Это к тому что еще пробовал Quote Link to comment Share on other sites More sharing options...
SerP256 Posted September 1 Share Posted September 1 Keenetic ULTRA KN-1811 Пробую ставить opkg по инструкции. Файл aarch64-installer.tar.gz Пробовал и с внешним диском и с флешкой. Форматирую Gnome-Utils [I] Sep 1 11:57:13 ndm: Opkg::Manager: disk is set to: 38452870-7bd4-4c6f-ae57-4e34476f89be:/. [I] Sep 1 11:57:13 ndm: Opkg::Manager: init script reset to default: /opt/etc/initrc. [I] Sep 1 11:57:13 ndm: Core::Authenticator: user "admin" tagged with "opt". [I] Sep 1 11:57:13 ndm: Core::System::StartupConfig: saving (http/rci). [I] Sep 1 11:57:13 kernel: EXT4-fs (sda): re-mounted. Opts: (null) [I] Sep 1 11:57:13 ndm: Opkg::Manager: /tmp/mnt/38452870-7bd4-4c6f-ae57-4e34476f89be mounted to /tmp/mnt/38452870-7bd4-4c6f-ae57-4e34476f89be. [I] Sep 1 11:57:13 ndm: Opkg::Manager: /tmp/mnt/38452870-7bd4-4c6f-ae57-4e34476f89be mounted to /opt/. [I] Sep 1 11:57:13 ndm: Opkg::Manager: none mounted to /opt/proc/. [I] Sep 1 11:57:13 ndm: Opkg::Manager: none mounted to /opt/sys/. [I] Sep 1 11:57:13 ndm: Opkg::Manager: /dev mounted to /opt/dev/. [I] Sep 1 11:57:13 ndm: Opkg::Manager: /tmp mounted to /opt/tmp. [I] Sep 1 11:57:13 ndm: Opkg::Manager: none mounted to /opt/dev/pts/. [E] Sep 1 11:57:13 ndm: Io::File: unable to open "/etc/shells": no such file or directory. [C] Sep 1 11:57:13 ndm: Opkg::Manager: system failed [0xcffd03a8], unable to copy /etc/shells -> /opt/etc/shells. [E] Sep 1 11:57:13 ndm: Io::File: unable to open "/etc/profile": no such file or directory. [C] Sep 1 11:57:13 ndm: Opkg::Manager: system failed [0xcffd03b0], unable to copy /etc/profile -> /opt/etc/profile. [I] Sep 1 11:57:13 npkg: inflating "aarch64-installer.tar.gz". [I] Sep 1 11:57:13 ndm: Opkg::Manager: /tmp/mnt/38452870-7bd4-4c6f-ae57-4e34476f89be initialized. [E] Sep 1 11:57:13 ndm: Opkg::Manager: invalid initrc "/opt/etc/initrc": no such file or directory, trying /opt/etc/init.d/. [C] Sep 1 11:57:13 ndm: Process: system failed [0xcffd0b0c], "/opt/bin/sh" executable not found. [E] Sep 1 11:57:13 ndm: Process: unable to create and initialize "Opkg shell" process. [E] Sep 1 11:57:13 ndm: Io::Process: "Opkg shell" is broken. [E] Sep 1 11:57:13 ndm: Opkg::Manager: process /opt/etc/init.d/doinstall: failed to start. Пролистал тут много страничек, смотрю что все успешные установки были с другой архитектурой. Может это проблема именно arm64 Quote Link to comment Share on other sites More sharing options...
zyxmon Posted September 1 Author Share Posted September 1 40 минут назад, SerP256 сказал: Пробую ставить opkg по инструкции. Поиск по chroot поможет Quote Link to comment Share on other sites More sharing options...
