MuKu Posted August 4, 2023 Author Posted August 4, 2023 To keep track of the experimental branch, subscribe to the Changelog 4.1 4
MuKu Posted August 17, 2023 Author Posted August 17, 2023 Release 4.0.3 (preview): IPsec: fixed saving the "Multiple sign-in" checkbox (reported by @ian) [NDM-2853] IPv4: fixed some websites not loading with traffic shaping enabled (reported by @VKN3) [SYS-953] IPv4: fixed source IP address selection when "ip alias" addresses are configured (reported by @Leonid K.) [SYS-945] IPv4: fixed timeouts when accessing websites via policy with multipath enabled [NDM-2792] IPv6: fixed cyclic restart of dhcp6d after saving segment settings [NDM-2916] IPv6: fixed the incompatibility with A1 Belarus [SYS-930] ISW: fixed an error when determining Internet connection via PPPoE/DSL [NDM-2914] KeenDNS: fixed the use of static record 78.47.125.180 in the direct mode [NDM-2905] MWS: fixed duplicates detection when extender IP address is changed (reported by @bigpu) [NDM-2892] OpenSSL: updated to 3.0.10 [SYS-949]: CVE-2023-3817 CVE-2023-3446 CVE-2023-2975 OpenVPN: fixed default route through the tunnel configured in IP policy (reported by @Deks) [NDM-2888] Opkg: fixed ifstatechanged.d arguments; added new iflayerchanged.d (reported by @Freize) [NDM-2897] PPPoE: fixed connection breakdown when renewing a DHCP address on a parent interface [NDM-2904] Wi-Fi: fix "wind: failed to make ioctl call: network is down" errors [NDM-2887] 3 1
MuKu Posted August 21, 2023 Author Posted August 21, 2023 Release 4.0.4 (preview): DNS: fixed "socket is not ready for request" error (reported by @dimon27254) [SYS-971] 2
MuKu Posted October 5, 2023 Author Posted October 5, 2023 Release 4.0.5 (preview ⇨ stable): Chilli: fixed client bandwidth limitation configured via RADIUS server options [NDM-2947] DNS: fixed "Could not bind on given addresses: Address in use" error when using DNS-over-TLS [SYS-1007] Ethernet: fixed loop detection on Ethernet ports of MT7531 switch (KN-1811) [SYS-879] IP: fixed missing traffic statistics for a number of registered devices approaching 200 [SYS-1014] MWS: fixed extender's wireless backhaul connection when access points are turned off [NDM-2912] MWS: fixed timezone synchronization on extenders [NDM-2918] PPE: aligned the maximum number of sessions with conntrack settings [SYS-980] SIP: fixed the "hash-ends-dial" function to retain the disabled state after reboot [VOX-298] USB: fixed error 125001 when polling Huawei E3276 modem [NDM-2967] Web: added RDP to the list of protocols for redirecting and blocking TCP and UDP [NWI-2890] Web: fixed traffic priority sorting (reported by @Nemeriz) [NWI-2889] Web: fixed Force UDP and IKEv2 checkboxes behavior in EoIP settings [NWI-2981] Web: fixed the display of the band steering setting (reported by @mva113) [NWI-2993] Wi-Fi: enabled AX mode by default for KN-3610 when used as an extender [SYS-997] Wi-Fi: fixed broken CLI command 'no rekey-interval' [SYS-990] Wi-Fi: fixed connection of HP LaserJet printers using WPS [SYS-988] Wi-Fi: fixed kernel crash in FT_KDP_EventInform [SYS-994] Wi-Fi: fixed termination of concurrent dual-band site survey [SYS-989] Wireguard: fixed reinstalling default route when changing priorities in the routing policy (reported by @Andyroll) [NDM-2933] 4
MuKu Posted November 10, 2023 Author Posted November 10, 2023 Release 4.0.6 (preview): AFP: fixed password-protected access (reported by @Levon Osipov) [SYS-1030] DNS: fixed applying profiles to hosts with assigned routing policies (reported by @t800) [NDM-2928] DNS: fixed proxy process entering infinite loop during intensive use of TCP requests (reported by @T@rkus) [SYS-1034] IPsec: fixed multiple connections under the same login [NDM-2986] IPsec: fixed null pointer dereference when applying strongSwan configuration [SYS-1033] IPsec: fixed tunnel connection after device restart (reported by @Владислав Сергеев) [NDM-3019] IPv6: disabled global scope in ULA prefix announcements [NDM-2993] ISW: fixed an issue causing incorrect installation of the system language [NDW3-1041] OpenVPN: fixed "Not Connected" state after rebooting (reported by @AbeL) [NDM-2874] Wi-Fi: fixed client rejection with "STA had re-associated from 00:00:00:00:00:00" message [SYS-1029] Wi-Fi: fixed system crash in CmdSetTxPowerCtrl on mt7603-based devices [SYS-1026] Wi-Fi: fixed termination of concurrent dual-band site survey [SYS-989] 4
MuKu Posted November 15, 2023 Author Posted November 15, 2023 Release 4.0.7 (preview): DNS: fixed proxy process entering infinite loop during intensive use of TCP requests (reported by @T@rkus) [SYS-1034] USB: added support for Huawei e3331s-2 modem [NDM-2810] USB: added support for Vodafone K5150 (1c26) modem [NDM-2994] 3
