  • 17
The_Immortal
Всех приветствую!
Le ecureuil:
  • Thanks 2
  • Answers 2k
  • Created
  • Last Reply
Top Posters For This Question
10 hours ago, McMCC said:
Yes! It's not xPON connection, it's simple ethernet to optical conversion. In your SFP no need web interface and set ip address, it should work as simple media convertor. If you really GPON SFP module, then you need to connect to the OLT, not to the media converter.
Under this title, many people ordered the same module from the same seller. Whose i remember is @biman @Pavel Grechishkin @alexich @taravasya
Ordered SFP GPON ONU with MAC-inside https://tr.aliexpress.com/item/4000086970977.html?gatewayAdapt=glo2tur&spm=a2g0o.9042311.0.0.47a64c4d3YpLTW
This device has Realtek chip. RTL9601
Also, I ordered it after seeing that this device has an interface in 2 more forums I read. Some can access their interfaces with the FO cable plugged in, some unplugged. Also how did they change serial number and ploam?
Link1  Link2 Link3
I have another gpon with this same chip. With the media converter, I can access its own interface and even be 05 (operational state). I just can't get an IP. I ordered it just because I saw that the module I ordered can also act as a router.
13 hours ago, McMCC said:
He was using tp-link media converter for SFP GPON module, not for connection with other ONU...
Same for me too. I'm not trying to connect it to another ONU. Is there a misunderstanding?
I am trying to terminate my fiber line in GPOn module. 05 becomes operational state. I can't be online even though I do the vlan values. That's my only issue.
15 часов назад, biman сказал:
Более месяца без перезагрузки)))))
4 месяца - полет стабильный. Кстати, ни кто не знает где нарыть прошивку? У многих она отличается, а где достать - хз
2 часа назад, Maxsim “Crazy Maxs” сказал:
не могу понять где взять мне нужны параметры для SFP модуля?
для ростелекома серийника достаточно ,который вы зачеркнули
  • Thanks 2
1 час назад, Maxsim “Crazy Maxs” сказал:
а если серийник из РТКшного роутера не влезает весь в SFP модуль?
на али где продают свисток в первом же отзыве ответ на ваш вопрос
Цитата
При смене серийного номера, можно внести только 12 знаков, если вам необходимо внести серийник из 16 знаков, то его необходимо внести в другом формате. Вместо префикса GPON, вписываем ID Вендора 4 символа + 8 последних с вашего устройства. DLNK - D-Link HWTC - Huawei SCOM - Sercomm ZTEG - ZTE ELTX - Eltex
Всем привет. Тоже озадачился настройкой.
Заказал стик sfp onu stick (с ссылки на али выше) и к нему есть keenetic giga.
Провайдер Ростелеком.
Сейчас стоит маршрутизатор rt-gm-3.
Подскажите по смене серийника на sfp onu:
1. Правильно понимаю, что ID вендора в серийнике указывается в зависимости от оборудования провайдера на том конце оптоволоконного кабеля?
2. ID вендора можно как то узнать из настроек маршрутизатора или надо просто подбирать, пока не заработает?
3. Нужно ли вносить какие-то изменения в LOID, LOID Password, PLOAM password и если да, то где узнать значения?
4. Как-то можно посмотреть логи этого sfp, чтобы понять почему он получает статус O3/O2?
5. Какие настройки в wan необходимо указывать если нужен только internet?
6. Нужно ли после изменения серийника делать commit and reboot каждый раз? Через какое время ориентировочно статус sfp onu обновляется?
Буду благодарен за ответы :)
Edited by morohon
1 нет. От твоего оборудования.
2. Основные моменты обозначены в этом сообщении - https://4pda.to/forum/index.php?showtopic=848460&st=2180#entry91188171
3. В основном нет.
4. Нет. По крайней мере в веб интерфейсе нет.
5. В этой теме уже разжевано.
6. При смене серийника - да. В остальных случаях мне не требовалась перезагрузка.
В 11.02.2022 в 11:20, Maxsim “Crazy Maxs” сказал:
А какие настройки vlan‘ов? Кто Ростелеком подключал подскажите по настройкам vlan на sfp модуле.
Только что настроил по инструкции @Максим Одобеско для РТ СПб, завелось сразу, попробуй так же. 5ю страницу треда почитай.
Здравствуйте. Друзья, есть роутер МГТС Sercomm 6699 v4, белый IP, переведён в бридж. К нему подключён keenetic peak ,  в настройках wan указан mac адрес sercomm, по DHCP получаю адрес. Any service отключён. IP tv МТС на 4 порту Sercomm.
подключаю SFP вместо sercomm (прописан серийник и пароль) получаю статус О5, а дальше всё. Keenetic не получает адреса. Всю голову сломал. Какие VLAN прописывать и где?
Спасибо.
Добрый день!
Благодаря топику и вашему опыту все таки смог завести Giga с SFP модулем для GPON от МГТС.
Правда возникли следующие мелкие косяки:
- при поднятом инете не могу войти в вебморду самого свистка;
- в одно утро после стандартного ребута свисток решил инет не поднимать.
Есть ли возможность поправить мои косяки и рукожопство?)
Готов дать информацию и скрины с настройками.
Заранее благодарю!
13 минуты назад, Максим Одобеско сказал:
Приветствую! С подключением)
Подскажи, что пишет роутер в логах диагностики в момент, когда не может поднять инет?
Спасибо!)
К сожалению, сохранить логи не смог, он ребутается в 5 утра. Я банально спал)
Вообще подозреваю, что ругался он на конфликт адресов. При попытке выставить какие-либо параметры (прописать VLAN, поменять DNS) подключения, то он собственно вместо того, чтобы его переподнять, ругается на конфликт адресов, ровно до ребута.
Вот что он пишет в этот момент:
Цитата
[I] Feb 15 16:38:06 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Feb 15 16:38:06 ndm: Core::Session: client disconnected.
[I] Feb 15 16:38:07 ndhcpc: GigabitEthernet1/Vlan30: NDM DHCP Client, v3.2.49.
[I] Feb 15 16:38:07 ndhcpc: GigabitEthernet1/Vlan30: created PID file "/var/run/ndhcpc-eth3.30.pid".
[I] Feb 15 16:38:07 ndhcpc: GigabitEthernet1: NDM DHCP Client, v3.2.49.
[I] Feb 15 16:38:07 ndhcpc: GigabitEthernet1: created PID file "/var/run/ndhcpc-eth3.pid".
[I] Feb 15 16:38:08 ndhcpc: GigabitEthernet1/Vlan30: received OFFER for 100.96.243.38 from 100.96.0.1.
[I] Feb 15 16:38:09 ndm: Core::System::Configuration: configuration saved.
[E] Feb 15 16:38:09 coalagent: [SecLayer_OnSend] Coala_Send: Network unreachable.
[E] Feb 15 16:38:09 coalagent: failed to handle event "ConfigurationSaved".
[I] Feb 15 16:38:22 ndhcpc: GigabitEthernet1: received OFFER for 100.96.243.38 from 100.96.0.1.
[I] Feb 15 16:38:23 ndhcpc: GigabitEthernet1: received ACK for 100.96.243.38 from 100.96.0.1 lease 300 sec.
[I] Feb 15 16:38:23 ndm: Dhcp::Client: configuring interface ISP.
[I] Feb 15 16:38:23 ndm: Network::Interface::Ip: "GigabitEthernet1": IP address is 100.96.243.38/16.
[I] Feb 15 16:38:23 ndm: Dhcp::Client: obtained IP address 100.96.243.38/16.
[I] Feb 15 16:38:23 ndm: Dhcp::Client: interface "ISP" is not global.
[I] Feb 15 16:38:23 ndm: Dhcp::Client: name server 62.112.106.130 is ignored.
[I] Feb 15 16:38:23 ndm: Dhcp::Client: name server 62.112.113.170 is ignored.
[I] Feb 15 16:38:23 ndm: Http::Nginx: loaded SSL certificate for "___".
[I] Feb 15 16:38:24 ndm: Http::Nginx: loaded SSL certificate for "___".
[I] Feb 15 16:38:24 ndm: Http::Nginx: activated proxy ___ to http://192.168.0.1:80.
[I] Feb 15 16:38:24 ndm: Core::Server: started Session /var/run/ndm.core.socket.
[I] Feb 15 16:38:24 ndm: Core::Session: client disconnected.
[I] Feb 15 16:38:24 ndm: Http::Manager: updated configuration.
[I] Feb 15 16:38:30 ndhcpc: GigabitEthernet1/Vlan30: received ACK for 100.96.243.38 from 100.96.0.1 lease 300 sec.
[I] Feb 15 16:38:30 ndm: Dhcp::Client: configuring interface ISP-Vlan.
[E] Feb 15 16:38:30 ndm: Network::Interface::Ip: "GigabitEthernet1/Vlan30": network 100.96.0.0/16 conflicts with interface "ISP".
[E] Feb 15 16:38:30 ndhcpc: GigabitEthernet1/Vlan30: NDM feedback failed (I/O error).
[E] Feb 15 16:38:30 ndhcpc: GigabitEthernet1/Vlan30: failed to send feedback.
Честно говоря, с такой проблемой на Кинетиках я вообще ранее не встречался.
13 минуты назад, Кирилл Андреев сказал:
Спасибо!)
МГТС видимо по другому чуть работает. А модуль как у нас Оди? Вланы взяты из старого устройства или оператор предоставил?
1 минуту назад, Максим Одобеско сказал:
Модуль точно такой же Odi, брал по ссылкам в топике. VLAN'ы взяты непосредственно с ранее стоявшего Iskratel.
По факту похожая ситуация у меня была с самим Iskratel. Причем, Кинетик до этого его видел как устройство LAN. Может быть просто сбросить до заводских сам Кинетик?
В 23.01.2022 в 19:36, mrkuk сказал:
им уже сами научились менять серийники из под соответствующей учетки без участия РТ, как раз данный sfp люди и берут из за того ,что можно самими всё прописать от вашей старой железки, если в вашем филиале без проблем прописывают серийники у себя, то можно взять на юлито sfp за 300 р. список совместимых с РТ в поиске найдете без проблем,ставил подобный терминал от Huawei товарищу называемую у них pon розетка прописал серийник переключил в режим моста и отключил dhcp и вуаля глючный роутер всё в одном от iskratel ушел на свалку истории, теперь кинетик рулит всем процессом.
И на второй вопрос ответ ,когда я прописал vlanы на кинетики хрен, что завелось ,но прописав в терминале всё норм поднялось. Позже, спросив у представи
Про серийный номер я написал в том ключе, что если я продам свой терминал, а ростелеком упрется прописывать номер с купленной sfp, то у меня начнутся проблемы, я конечно могу поменять серийник как у себя на терминале, так и на sfp. По vlan спасибо за информацию, жалко конечно что кинетик не может разрулить vlan без настройки на модуле.
17 часов назад, Igor St сказал:
это был мой опыт ,но в этой теме писали, что на кинетике настраивали vlanы и у них работало норм.
В 30.12.2021 в 17:50, Pavel Grechishkin сказал:
Пока только технически, юридически собираюсь после НГ, сдам им роутер с заявлением.  30 рублей в месяц за аренду оборудования - конечно не деньги. Но если бы это было оборудование...
Добрый день! Удалось провернуть отказ от оборудования с сохранением id?
14 часа назад, Naytilys сказал:
К сожалению нет, прописывать SN стороннего оборудования отказываются. Ну я особо и не напирал, не хочу время тратить на бодания с ними.
